Re: Tunability: 2 x 4150 vs 1 x Dom
[Re: hemienvy]
#3018977
02/25/22 11:44 PM
02/25/22 11:44 PM
Posts: 43,181 Bend,OR USA
Cab_Burge
I have a couple of (long term) big inch engine projects. On one of them I am debating whether to go with a 1 x 4 spider intake with a Dom or go with a tunnel ram with 2 x 750's, or 950's.
With the two fours I get 4 needle & seats, 4 accelerator pumps, 8-corner idle, and I think better cylinder - to - cylinder distribution.
With one big Dominator, everything is "simpler", (or is it ?)
I am speaking in generalities on purpose, this is a street engine and once the fuel curve is pretty close I don't really want/need to keep adjusting it like a bracket car.
Can 2 fours be dialed in a little closer cylinder to cylinder than a single Dominator ? Absolutely Every BB Mopar that I have added more fuel and air through the top end made more power and ran quicker and faster as long as the fuel delivery system would keep up I'm going to assume you're going to mount the dual 750 Holley sideways so the front carb will feed the front four cylinders and the back carb will feed the back four cylinders so you will need and should tune the idle and transition circuits to feed all 8 cylinders as evenly as possible first Then work on the primary for light part throttle driving under 2500 RPM next and lastly work on the WOT tuning to get all 8 cylinders perfect Now get to WORK and go faster than you ever have BTW, I'm getting ready to convert two sets of dual tunnel ram Carbs to E85, one set of 1050 CFM Dominator and another set of 1000 CFM HP 4150 annular carbs, both for 440- heads tunnel ram intakes, one low deck and the other for RB motors and maybe use one set of them later on the B1 NOS motor later
[Re: hemienvy]
#3018993
02/26/22 01:17 AM
02/26/22 01:17 AM
Posts: 31,036 Oregon
AndyF
I wouldn't consider either of those options for a street engine. For a bracket engine I'd go with a single Dominator.
[Re: hemienvy]
#3019005
02/26/22 07:33 AM
02/26/22 07:33 AM
Posts: 2,923 A shed in England
Tig
A shed in England
I'd also invest in a dual AFR system to monitor and get the tune done quicker, whichever way you decide to go
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: hemienvy]
#3019015
02/26/22 09:44 AM
02/26/22 09:44 AM
Posts: 8,040 Mt Morris Michigan
mopar dave
Mt Morris Michigan
I have 2 of Dom's 650's(1.375 venturi) im told they flow 750+. They are very street tunable and thru my tuning i found square jetted worked best. A bit quicker in response and quicker in my freeway runs from 55 to 120+. They are so streetable you could tell anyone you are injected and they would believe without looking. Mine starts right up with one throttle pump and idles on its own right away. The downside is you will be adding some weight to the car with a t ram and 2 carbs. Don't worry about your streetability, it will be there with 2 of Dom's carbs.
[Re: hemienvy]
#3019026
02/26/22 10:20 AM
02/26/22 10:20 AM
Posts: 10,000 Frostbitefalls MN (Rocky&Bullw...
gregsdart
You asked about a carb versus two carbs, but with the cost of everything for two carbs, wouldn't it approach or surpass the cost of a EFI individual runner system, like a TR manifold or crossram fitted for injectors? The flexability of the EFI for type of fuel might be worth it. Might be the time to step up to a" do all" electronic system.
[Re: gregsdart]
#3019035
02/26/22 10:29 AM
02/26/22 10:29 AM
Posts: 4,457 Washington
madscientist
Washington
The tunnel ram with two carbs will put drive, out run and generally out perform ANY single 4 intake every time. Anyone who claims otherwise is doing something wrong. Your best money will be spent on carbs from a custom builder. In no particular order is Thumpr carbs (Dom) Lighting Carbs (Mark Whitener) and Baldwin Performance (William). Any one of those three will hook you up. Then you’ll wonder why you weren’t running a TR on the street years ago.
[Re: AndyF]
#3019064
02/26/22 12:29 PM
02/26/22 12:29 PM
Posts: 3,395 Pa
Hot 340
Pa
I wouldn't consider either of those options for a street engine. For a bracket engine I'd go with a single Dominator. Well I certainly would. A ram with two BIG fours is by far the best setup I've used. Probably cleaner and faster than the f.i. setups
[Re: Hot 340]
#3019141
02/26/22 05:10 PM
02/26/22 05:10 PM
Cab_Burge
I wouldn't consider either of those options for a street engine. For a bracket engine I'd go with a single Dominator. Well I certainly would. A ram with two BIG fours is by far the best setup I've used. Probably cleaner and faster than the f.i. setups Maybe,maybe not It depends on the parts and tuner, correct?
[Re: madscientist]
#3019322
02/27/22 10:18 AM
02/27/22 10:18 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Yes sir and I just wish I would of went with duals years ago. Cold altitude starts can be a pain cos now I'm in Utah at 6400 feet but they drive, run and fly like EFI but of course BETTER and cheaper......NO WIRES needed....
[Re: Thumperdart]
#3019468
02/27/22 05:56 PM
02/27/22 05:56 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I run 2 1050 Dominators on my 528 Hemi on the street with no issues.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
