Re: Are there any good spray can primers? [Re: 360view] #3031566
04/07/22 12:57 PM
04/07/22 12:57 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Last time I looked at the PPG DPLF data sheet I think it says you can spray it over clean galvanized coated metal with no sanding or scuffing required.
Re: Are there any good spray can primers? [Re: 360view] #3031757
04/08/22 04:18 AM
04/08/22 04:18 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Originally Posted by 360view
If a product has been sprayed with a first coat of galvanizing paint,
is there a special primer that can be a 2nd coat over the galvanizing
that will enable a 3rd coat of paint chosen because it holds up good against sunlight?
What primers do automakers use that will enable paint to stick to zinc coated sheet metal?
Gulf of Mexico off-shore platforms are commonly sandblasted to white metal, primed with zinc-rich primer, primed again with regular primer, and then top coated with paint. You can mimic this marine paint system with good cleaning, zinc-rich primer, followed by regular primer, then top coated. Several times I have used any good rattle can primer over zinc-rich primer and then top coated with good result.
Auto makers use paintable zinc coated steel sheet called Galvanneal, which is cold rolled steel sheet that has been hot dip galvanized or electro-zinc plated followed by annealing. The annealing process causes iron atoms in the base metal to mix with the zinc atoms on the surface, making the surface paintable. So galvanized steel sheet is not paintable, but heat treated galvanized sheet is paintable. Galvanneal is also the non-rusting metal most often used in painted and un-painted electronic and computer cabinets/frames, and it is often automotive gauge, 0.032", because that is a common and economical thickness with high availability in the steel market.
Re: Are there any good spray can primers? [Re: kentj340] #3031777
04/08/22 08:27 AM
04/08/22 08:27 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Thank you Neil and kentj340 for the info.
Re: Are there any good spray can primers? [Re: 360view] #3031838
04/08/22 12:44 PM
04/08/22 12:44 PM
Nor here, Nor there
Dart 500 Offline
Dart 500  Offline
Nor here, Nor there
Carquest has the best spray can primers. They sell legit epoxy primers and more, even accurate paint codes in a can
Re: Are there any good spray can primers? [Re: Dart 500] #3036263
04/23/22 10:37 AM
04/23/22 10:37 AM
moparx Offline
moparx  Offline
what brand is the carquest paint ?
or is it just "carquest" brand on the label ?
who makes it for carquest ? i can't believe carquest makes paint in their labeled spray bombs, but i have been wrong more times than right, and the older i get, the dumber i find i really am ! whistling biggrin
beer
Re: Are there any good spray can primers? [Re: moparx] #3036269
04/23/22 10:46 AM
04/23/22 10:46 AM
las vegas,nv
mopar muscle7271 Offline
las vegas,nv
Spray max brand is a good primer
Re: Are there any good spray can primers? [Re: 340SIX] #3036330
04/23/22 02:24 PM
04/23/22 02:24 PM
IMGTX Offline
IMGTX  Offline
I used these to prime and paint the underside of my convertible in the early 80's and it is still good paint. Not show quality shiny but solid.
Mix your preferred primer/paint, even catalyzed paint, pour it in the bottle and go to town. Nozzle assembly gets tossed when it is empty so no worries about a clogged nozzle from paint with hardener's in it.
Re: Are there any good spray can primers? [Re: IMGTX] #3036340
04/23/22 02:46 PM
04/23/22 02:46 PM
moparx Offline
moparx  Offline
those things work good, but you would think by now, as many years as they have been available, they would have a fan spray nozzle. wonder why they don't ? shruggy
beer
