69 B-Body mini-tub/inboard springs with 3" tailpipes pics
#3017710
02/22/22 02:12 PM
02/22/22 02:12 PM
Posts: 182 USA
Nitrofish
USA
Anyone have any pictures of a 69 B-body with a mini-tub, leaf springs moved inboard with full length 3" tailpipes? If so, please share.
Looking to see fitment and clearance to the leaf spring shackles.
Thanks in advance!
Re: 69 B-Body mini-tub/inboard springs with 3" tailpipes pics
[Re: Nitrofish]
#3017758
02/22/22 03:37 PM
02/22/22 03:37 PM
Posts: 17,846 S.E. Michigan
ZIPPY
S.E. Michigan
Going to be a pretty tight squeeze if you have a stock gas tank. A narrowed gas tank/something skinnier from another vehicle would help a bunch.
Most mini tubbbed cars I've seen either have no tailpipes, or they have a fuel cell in the trunk, or both.
Rich H.
Esse Quam Videri
[Re: AndyF]
#3017831
02/22/22 08:05 PM
02/22/22 08:05 PM
Posts: 8,873 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Vehicle is equipped with a fuel cell, so fuel tank clearance is not an issue. Then why are you even asking this question?!?! Run the pipes wherever the hell you want .
[Re: Stanton]
#3017924
02/23/22 04:19 AM
02/23/22 04:19 AM
Posts: 43,193 Bend,OR USA
Cab_Burge
Big difference between a 66/7 gas tank and a 68-70 Dat be true The later B body are a lot easier to work on the exhaust system with their gas tanks: up: I had to bend up the outboard gas tank flanges and maneuver the pipes to the clear the front edges of the gas tank above the Dana 60 rear end that I moved forward three inches
[Re: Nitrofish]
#3017997
02/23/22 12:40 PM
02/23/22 12:40 PM
ZIPPY
S.E. Michigan
I want to use the stock location if possible for a clean stock look with 68-70 exhaust tips in the factory location!
Okay, The metal shackle itself is fine, but the rubber bushings in both the spring and the shackle probably won't be too happy with the heat of an exhaust pipe (assuming this will be driven enough to get the exhaust hot: bushing damage). Two ideas I'd consider, or maybe a combination of them: -A slider instead of a shackle, which is more compact/takes up less real estate, and does not contain any rubber, eliminating the concern of melting damage by having the tailpipe in close proximity. -move the tailpipes inboard a small amount, just enough. Maybe 1 and 1/2 to 2 inches. Not enough to be very noticeable as far as overall visual appearance. Slightly longer versions of the factory style tip hanger as attached could be fabricated pretty easily to help this along. This is easily possible especially with the stock gas tank gone, and I'm sure it's been done. Good luck.
Rich H.
Esse Quam Videri
[Re: AndyF]
#3018193
02/23/22 07:51 PM
02/23/22 07:51 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
The Road Runner ended up with a full 3 inch exhaust all the way out the back with factory looking tips. It has a full size EFI gas tank and the springs are moved under the frame. The springs are Calvert mono-leafs so they are a little thinner than stock but just as wide. The job came out looking perfect but it took time and cost money. Got any more photos of that car? I have so many questions !!!
[Re: Stanton]
#3018636
02/24/22 09:12 PM
02/24/22 09:12 PM
Superfreak
Superfreak
And maybe a few more pics of the whole car.
