Re: Holley Retro-Bright LEDs
[Re: TJP]
#3017538
02/21/22 10:18 PM
02/21/22 10:18 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Normal... Their dispersion is lower and wide... I compared their output to my standard OE headlights against the garage door, about the same height but wider and brighter. To date only been driven @ nite 2X times but no issues from on-coming traffic... Just my $0.02...
[Re: Sinitro]
#3017543
02/21/22 10:30 PM
02/21/22 10:30 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
So there's no separate lo/high - high beam bulb? I see three 5.3/4" bulbs, yellow, regular white and bright white, all with three wire connections.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#3017544
02/21/22 10:46 PM
02/21/22 10:46 PM
Posts: 5,439 So Cal
Sinitro
So Cal
The LEDs are low/high, there is no high only LED. For my setup, I fabricated a "Y" harness using (3) prong H4 connectors so each pair of LEDs are wired in parallel.. So (4) low beams or (4) high beams, but the low beams are pretty bright I don't see using the high beams very much.. Just my $0.02...
[Re: Sinitro]
#3017545
02/21/22 10:49 PM
02/21/22 10:49 PM
3hundred
Colleyville
Thank you, I just wanted to be sure I wasn't missing anything.
[Re: Sinitro]
#3017876
02/22/22 10:14 PM
02/22/22 10:14 PM
Posts: 15,350 Omaha Ne
TJP
Omaha Ne
Normal... Their dispersion is lower and wide... I compared their output to my standard OE headlights against the garage door, about the same height but wider and brighter. To date only been driven @ nite 2X times but no issues from on-coming traffic... Just my $0.02... thanks for the reply
