Locking up the VVT, springs needed? #3015617
02/15/22 11:47 AM
02/15/22 11:47 AM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
Hi!
I'm locking out the VVT cam sprocket using comp cams 5760 liock up kit. Screwed it up, and the springs got loose.
The question is, what do I need the springs for since the timing will be locked up? I can't see any reason I couldn't run without them.
Plynouth VIP '67 TT IC EFI
Re: Locking up the VVT, springs needed? [Re: jyrki] #3016453
02/18/22 09:16 AM
02/18/22 09:16 AM
ghinmi Offline
ghinmi  Offline
Mine has been locked out with the springs removed since 2016. It's fine.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street.
9.97 @ 140 slicks, 10.74 in autox trim
Re: Locking up the VVT, springs needed? [Re: ghinmi] #3017268
02/21/22 07:44 AM
02/21/22 07:44 AM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
That's what I thought, thank you for tyhe confirmation!
