Page 1 of 5 1 2 3 4 5
Header thread #3014064
02/10/22 04:05 PM
02/10/22 04:05 PM
Shelby Twp. Mi
HardcoreB Online content OP
HardcoreB  Online Content OP
Shelby Twp. Mi
Let's see your headers! How'd they snake thru all the obstacles? What can be done within stock frame rails? These are 2 1/8 to 3.5 on current combo about 33" long. I'm using a tube/rack front end from an undisclosed manufacturer.
Re: Header thread [Re: HardcoreB] #3014066
02/10/22 04:10 PM
02/10/22 04:10 PM
Shelby Twp. Mi
Shelby Twp. Mi
These are on Dartin's hoopty. 2" x 3.5" built for a target 700HP still using them at about 850HP.
Re: Header thread [Re: HardcoreB] #3014069
02/10/22 04:19 PM
02/10/22 04:19 PM
Shelby Twp. Mi
Shelby Twp. Mi
I remade tube #4 without the clearance ripples. But i pretty much used every ounce of space i could near the port exits. I mainly posted this for Tony, I'd like to see what he's working with on his Scamp. From what i remember they were quite long. But that was what I saw when the car had -1 heads. It's difficult to get A SERIES of big tubes with good trajectory under the floor. Here's another pic I stored I think Al made for his B1 valiant.
Re: Header thread [Re: HardcoreB] #3014080
02/10/22 04:38 PM
02/10/22 04:38 PM
Shelby Twp. Mi
Shelby Twp. Mi
Other ideas I saved before I built any sets. The red/pink one is Steff's B1 Challenger. Mango green was DemonGups (which seemed to run ok)...
Re: Header thread [Re: HardcoreB] #3014109
02/10/22 05:52 PM
02/10/22 05:52 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Not the best pic but this was the hard side, 2 1/4 into a 4" merge. E Body. Around 900hp on a good day, though we have made a few changes since this was taken (TR) but the same headers.
Edit: Found a couple more.
Re: Header thread [Re: Tig] #3014125
02/10/22 06:56 PM
02/10/22 06:56 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Here are a couple of a 64 you may have seen. We will likely be replacing these as well when engine gets freshenedand a number f changes made there too, but they fit very well. Carb on it was axed to.
Also some more Valiant stuff all under chassis stuff as I had intended to reinstall the inner fenders but never did.Someone on here ended up with those tubes..Dont recall whom. All I have for stocktype stuff that did not get axed with photobucket. Unless you wanna see the ones on the Camaro smoke
Re: Header thread [Re: Al_Alguire] #3014145
02/10/22 08:09 PM
02/10/22 08:09 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Here are the headers I made for my Road Runner. 2.125-2.250, into a 4” collector. Did not want to cut anything on the car to make them fit.
69 GTX 68 Road Runner
Re: Header thread [Re: JERICOGTX] #3014147
02/10/22 08:42 PM
02/10/22 08:42 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Amazingly nice!
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Header thread [Re: B3422W5] #3014162
02/10/22 09:38 PM
02/10/22 09:38 PM
Superfreak
Superfreak
Where could one get a pair of flanges for Stage V hemi heads? I would like to make my own as well.
Re: Header thread [Re: ] #3014233
02/11/22 08:05 AM
02/11/22 08:05 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
SPD Exhaust has nice cnc machined flanges. Stainless Headers in Minnesota makes nice water jet (or laser cut) flanges.
Re: Header thread [Re: HardcoreB] #3014807
02/12/22 08:22 PM
02/12/22 08:22 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Yes, we’ve been using the ones you built for a lot of years. Can remove or install either side easily in a quick amount of time. No complaints here for sure.
Re: Header thread [Re: Dartin] #3016007
02/16/22 02:15 PM
02/16/22 02:15 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Dumb question...other than durability and $$$ is there any difference between stainless and mild steel ???
Oh and i have some A body big block headers for sale in the race parts section whistling
....BAD A$$ STREET CAR.....
Re: Header thread [Re: n20mstr] #3016021
02/16/22 02:34 PM
02/16/22 02:34 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
My stainless ones are heavy...
Re: Header thread [Re: JERICOGTX] #3016026
02/16/22 02:46 PM
02/16/22 02:46 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Been our experience too
Re: Header thread [Re: n20mstr] #3016031
02/16/22 03:04 PM
02/16/22 03:04 PM
Shelby Twp. Mi
Shelby Twp. Mi
When you throw in the durability part, I'm not sure if i was building my own I'd use M/S anymore, especially if you're spraying. Specifically for your application, the general pathway of "UP and OVER" then out the fender might be the best. You could error on the small side of pipemax if the lengths are shorter and the trajectory is nice. Thanks for all the additional pics that have been added! I have a decent inventory of bends yet but, apparently the materials cost has gone up a bunch. That may be your deciding factor. So, you're saying your old headers that served you well are for sale in the for sale section!?
Re: Header thread [Re: HardcoreB] #3016036
02/16/22 03:17 PM
02/16/22 03:17 PM
N
n20mstr Offline
n20mstr  Offline
N
The old headers ive been using ......yes they are for sale up. I brought them to a very reputable engine shop for a dyno session and....they kind of told me [censored] are these shruggy??? And they are not the correct size and length. To get what i really need, they are going to have to be fender exits. Short and BIGGER. weld Yea im a special case because im using a power adder and NA is of really no concern
Re: Header thread [Re: Al_Alguire] #3016041
02/16/22 03:34 PM
02/16/22 03:34 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I'll likely never attempt this, but curious: what gauge tubing are you guys using?
Rich H.
Esse Quam Videri
Re: Header thread [Re: n20mstr] #3016045
02/16/22 03:39 PM
02/16/22 03:39 PM
Shelby Twp. Mi
Shelby Twp. Mi
Now that I'm remembering, after looking at the pics, you might do well going up and out. Moving the master cyl might be in order and the smartest. Dartin's are on an RB with -1's so you can get a visual of what a gang of tubes may look like. The worst flowing will be #2 by far. Orient them firing into the collector in a circle too. Should be easier to fab putting the collector above the mid-level body line...
Re: Header thread [Re: HardcoreB] #3016059
02/16/22 04:15 PM
02/16/22 04:15 PM
N
n20mstr Offline
n20mstr  Offline
N
Yes master cyl is going inside with a wilwood reverse pedal assembly. Im really leaning towards front of the tire exit because i dont want to chop up the firewall....but who knows. Right now im stripping it all down to get the frame straight and get the inner fender wells out.
Re: Header thread [Re: Al_Alguire] #3016178
02/16/22 10:52 PM
02/16/22 10:52 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
5% heavier. Next time use 18ga.
