Re: Header thread
[Re: n20mstr]
#3016181
02/16/22 11:00 PM
02/16/22 11:00 PM
Posts: 11,779 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Dumb question...other than durability and $$$ is there any difference between stainless and mild steel ??? Oh and i have some A body big block headers for sale in the race parts section Rust. Mild steel will rust inside, even if coated. Some of the rust scale will end up back in the cylinder. Heat conduction. SS doesn't conduct heat as well. More heat stays in the exhaust gas.
Re: Header thread
[Re: CMcAllister]
#3016223
02/17/22 08:08 AM
02/17/22 08:08 AM
Posts: 1,841 NW Indiana
fbs63
NW Indiana
Dumb question...other than durability and $$$ is there any difference between stainless and mild steel ??? Oh and i have some A body big block headers for sale in the race parts section Rust. Mild steel will rust inside, even if coated. Some of the rust scale will end up back in the cylinder. Heat conduction. SS doesn't conduct heat as well. More heat stays in the exhaust gas. Plus you can use 18 gauge tube.
Re: Header thread
[Re: fbs63]
#3016286
02/17/22 01:14 PM
02/17/22 01:14 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Dumb question...other than durability and $$$ is there any difference between stainless and mild steel ??? Oh and i have some A body big block headers for sale in the race parts section Rust. Mild steel will rust inside, even if coated. Some of the rust scale will end up back in the cylinder. Heat conduction. SS doesn't conduct heat as well. More heat stays in the exhaust gas. Plus you can use 18 gauge tube. 16 gauge set, 30", 2.125 d, with 3/8" full flange and a merge collector is heavy. No doubt.
Re: Header thread
[Re: CMcAllister]
#3016356
02/17/22 06:23 PM
02/17/22 06:23 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
3/8 Flanges with added center bolts, no gaskets. 1 7/8" 321 stainless tube. Made a poor choice of having them ceramic coated. Burned off after the first few launches. Very expensive even doing it all myself. Worth every cent. Never needed any repairs even with torturous zero degree launch strategies.
Re: Header thread
[Re: Cab_Burge]
#3016382
02/17/22 08:21 PM
02/17/22 08:21 PM
TRENDZ
Milwaukee WI
broke more than one exhaust rocker… that pic was to show the exhaust flange with center studs between the ports.
Re: Header thread
[Re: HardcoreB]
#3016521
02/18/22 01:18 PM
02/18/22 01:18 PM
Posts: 19,398 Las Vegas
Al_Alguire
Las Vegas
While definitely not a Mopar thought I would share some more headers. Vettes old small, pump gas street car headers to it's current racey ones ![boogie boogie](/ubbthreads/images/graemlins/custom/boogie.gif) This is a stock front end car, stock steering, control arms and frame rails. Street car days ![[Linked Image]](https://i.postimg.cc/DzTfWs8P/FD8-E293-E-C6-CE-459-E-9-BE3-4-A76-D0-DD3-CB0.jpg) Current headers ![[Linked Image]](https://i.postimg.cc/1zrmDtFh/6-E90-C195-70-C4-4078-8043-42-FF26-EAB6-C4.jpg)
Re: Header thread
[Re: Al_Alguire]
#3016537
02/18/22 02:14 PM
02/18/22 02:14 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
While definitely not a Mopar thought I would share some more headers. Vettes old small, pump gas street car headers to it's current racey ones ![boogie boogie](/ubbthreads/images/graemlins/custom/boogie.gif) This is a stock front end car, stock steering, control arms and frame rails. Street car days ![[Linked Image]](https://i.postimg.cc/DzTfWs8P/FD8-E293-E-C6-CE-459-E-9-BE3-4-A76-D0-DD3-CB0.jpg) Current headers Ovaled tube in the second pic is interesting. You ever talk to someone at one of the big race shops about the effects of doing that? Maintaining the area as opposed to just beating a dent in it seems a better solution. Just wonder if it hurts it. Sometimes you just have to make it fit.
Re: Header thread
[Re: CMcAllister]
#3016548
02/18/22 02:40 PM
02/18/22 02:40 PM
Al_Alguire
Las Vegas
Many other changes to those heads between those two pics. The last revision before the new headers was to move the exhaust valve guide/valve over to make more room for the largest intake valve we could get in that small chamber. The entire exhaust port was then reshaped for a much smaller valve. All the work was done by Slawko of course. But good catch ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) FWIW these headers were done by REF in Kingman, Greg and the guys have YEARS of experience with everything from bracket stuff to comp. We hold the shop record for the longest amount of time a car has spent in the shop getting headers made. It was there 4.5 days. As Jay pointed out most stuff is in at breakfast and done by lunch or shortly there after.
Re: Header thread
[Re: CMcAllister]
#3056833
07/06/22 05:57 PM
07/06/22 05:57 PM
Posts: 1,201 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I used to have the magazine this article was in originally, but just came across it online. It may be from 2003, but I believe most of the info is still pertinent. LINK
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
