Fuel Pressure Gauge On 440 Six Pack? #3015797
02/15/22 09:09 PM
02/15/22 09:09 PM
South San Francisco, Ca
70sixpkrt Offline OP
I want to install a fuel pressure gauge on my 440 sixpack but don't know where. Has anybody installed a fuel pressure gauge on a Six Pack setup? Any pics? Thanks.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Fuel Pressure Gauge On 440 Six Pack? [Re: 70sixpkrt] #3015805
02/15/22 09:18 PM
02/15/22 09:18 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Just take one of the tee fittings, drill and tap it for 1/8 pipe.
Re: Fuel Pressure Gauge On 440 Six Pack? [Re: 70sixpkrt] #3015822
02/15/22 09:54 PM
02/15/22 09:54 PM
Chicago
PurpleBeeper Offline
Chicago
I've got mine mounted on the cowl area and tapped in with a "T" in the non-stock rubber fuel line right after the fuel pressure regulator, before it goes up to the carbs. It's been that way for a long, long time and works great. Remember that mechanical guages need to be mounted outside of the car, but electic guages with sending units can go inside the car. If you have a mechanical pump, you can tap in anywhere after the fuel pump.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
