4 speeds #3015293
02/14/22 10:55 AM
02/14/22 10:55 AM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
Is a 70 E body 4 speed the same length as an A body.
1969 340 4 Speed Swinger R4,
black vinyl, white butt stripe, 3:91
Re: 4 speeds [Re: 6T9Hemi] #3015295
02/14/22 11:00 AM
02/14/22 11:00 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
No, the tailshaft is longer on the E body.
Re: 4 speeds [Re: slantzilla] #3015313
02/14/22 11:48 AM
02/14/22 11:48 AM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
Thanks!
Re: 4 speeds [Re: 6T9Hemi] #3015317
02/14/22 11:58 AM
02/14/22 11:58 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
And E-Body has two pads to mount the shifter, universal at that point for B and E...
JB Rhinehart, Realist
A-Body's RULE!
Re: 4 speeds [Re: Rhinodart] #3015390
02/14/22 03:11 PM
02/14/22 03:11 PM
Cab_Burge Online work
Cab_Burge  Online Work
1970 and up B&E body tranny have the two shifter mounts, all A bodies tail shaft and output shafts are quite a bit shorter.
1964 to 1969 B body tail shafts had one mount and the tail shaft were longer than the A bodies are.
Re: 4 speeds [Re: Cab_Burge] #3015678
02/15/22 02:55 PM
02/15/22 02:55 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Cab dont forget 64 65 had the ball and trunion on the outputs for 4 speed.66 first year for slip in yoke Rocky
Chrysler Firepower
Re: 4 speeds [Re: therocks] #3015776
02/15/22 08:38 PM
02/15/22 08:38 PM
You are absolutely correct on the 4 speeds and the front ball and trunnion U Joints up Why Mopar switch the automatics to the slip yokes in 1965 and didn't do all the stick shift trannies at the same time is still a mystery to me: confused:
Re: 4 speeds [Re: Cab_Burge] #3015945
02/16/22 11:54 AM
02/16/22 11:54 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
904 still had Ball and Trunnion in 1965, at least part of the year. My old '65 300 727 may have had one, as well. I just know that it wasn't a normal u-joint.
Re: 4 speeds [Re: Jim_Lusk] #3015946
02/16/22 11:56 AM
02/16/22 11:56 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
My 65 Cuda has the B&T setup as well. It was built in Dec 64
Re: 4 speeds [Re: Sniper] #3016010
02/16/22 02:19 PM
02/16/22 02:19 PM
I had several 1965 B body, Dodge Coronet and Plymouth, the automatic cars had slip yokes front U joints and the 4 speeds had ball and trunnions' shruggy
I'm not sure if I owned or worked on a 1965 C and A body 4 speed car confused
Re: 4 speeds [Re: Cab_Burge] #3016017
02/16/22 02:28 PM
02/16/22 02:28 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Might have been a matter of using up existing stocks? Who knows for sure.
Re: 4 speeds [Re: Cab_Burge] #3016095
02/16/22 06:04 PM
02/16/22 06:04 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
My 65 with 273 and 904 has the ball and trunnion joint.
Re: 4 speeds [Re: cudaman1969] #3016099
02/16/22 06:17 PM
02/16/22 06:17 PM
Which Body brand and model?
