4 speeds
#3015293
02/14/22 10:55 AM
02/14/22 10:55 AM
Posts: 935 Elizabethtown, KY
6T9Hemi
Elizabethtown, KY
Is a 70 E body 4 speed the same length as an A body.
1969 340 4 Speed Swinger R4, black vinyl, white butt stripe, 3:91
Re: 4 speeds
[Re: 6T9Hemi]
#3015317
02/14/22 11:58 AM
02/14/22 11:58 AM
Posts: 43,575 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
And E-Body has two pads to mount the shifter, universal at that point for B and E...
JB Rhinehart, Realist
A-Body's RULE!
Re: 4 speeds
[Re: Rhinodart]
#3015390
02/14/22 03:11 PM
02/14/22 03:11 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
And E-Body has two pads to mount the shifter, universal at that point for B and E... 1970 and up B&E body tranny have the two shifter mounts, all A bodies tail shaft and output shafts are quite a bit shorter. 1964 to 1969 B body tail shafts had one mount and the tail shaft were longer than the A bodies are.
Re: 4 speeds
[Re: Cab_Burge]
#3015678
02/15/22 02:55 PM
02/15/22 02:55 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Cab dont forget 64 65 had the ball and trunion on the outputs for 4 speed.66 first year for slip in yoke Rocky
Chrysler Firepower
Re: 4 speeds
[Re: therocks]
#3015776
02/15/22 08:38 PM
02/15/22 08:38 PM
Cab_Burge
Cab dont forget 64 65 had the ball and trunion on the outputs for 4 speed.66 first year for slip in yoke Rocky You are absolutely correct on the 4 speeds and the front ball and trunnion U Joints Why Mopar switch the automatics to the slip yokes in 1965 and didn't do all the stick shift trannies at the same time is still a mystery to me: confused:
Re: 4 speeds
[Re: Cab_Burge]
#3015945
02/16/22 11:54 AM
02/16/22 11:54 AM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
Cab dont forget 64 65 had the ball and trunion on the outputs for 4 speed.66 first year for slip in yoke Rocky You are absolutely correct on the 4 speeds and the front ball and trunnion U Joints Why Mopar switch the automatics to the slip yokes in 1965 and didn't do all the stick shift trannies at the same time is still a mystery to me: confused: 904 still had Ball and Trunnion in 1965, at least part of the year. My old '65 300 727 may have had one, as well. I just know that it wasn't a normal u-joint.
Re: 4 speeds
[Re: Jim_Lusk]
#3015946
02/16/22 11:56 AM
02/16/22 11:56 AM
Posts: 6,281 nowhere
Sniper
nowhere
Cab dont forget 64 65 had the ball and trunion on the outputs for 4 speed.66 first year for slip in yoke Rocky You are absolutely correct on the 4 speeds and the front ball and trunnion U Joints Why Mopar switch the automatics to the slip yokes in 1965 and didn't do all the stick shift trannies at the same time is still a mystery to me: confused: 904 still had Ball and Trunnion in 1965, at least part of the year. My old '65 300 727 may have had one, as well. I just know that it wasn't a normal u-joint. My 65 Cuda has the B&T setup as well. It was built in Dec 64
Re: 4 speeds
[Re: cudaman1969]
#3016099
02/16/22 06:17 PM
02/16/22 06:17 PM
Cab_Burge
Which Body brand and model?
