70 Chall rear valance mounting bracket screws #301497
04/27/09 10:42 PM
04/27/09 10:42 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
On a 70 Challenger, does anyone know what the screws that hold the rear valance to the two mounting brackets looks like? Are they body colored (painted)?
Thanks!
1970 Dodge Challenger T/A
Re: 70 Chall rear valance mounting bracket screws [Re: jeff968] #301498
04/28/09 10:48 AM
04/28/09 10:48 AM
Dallas, TX
70challrtse Offline
super gas
70challrtse  Offline
super gas
Dallas, TX
Not painted. They are the same as the screws used on the RT hood inserts.
Re: 70 Chall rear valance mounting bracket screws [Re: 70challrtse] #301499
04/29/09 12:26 AM
04/29/09 12:26 AM
I would have to say that they were not painted since they had to remove the rear valance to install the fuel tank. I can not imagine that they would have kept the hardware that was painted and just put new in.
Re: 70 Chall rear valance mounting bracket screws [Re: ] #301500
04/29/09 08:30 PM
04/29/09 08:30 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Can someone post a pic of the screw?
Re: 70 Chall rear valance mounting bracket screws [Re: rayztoy] #301501
04/29/09 09:13 PM
04/29/09 09:13 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: 70 Chall rear valance mounting bracket screws [Re: Challenger 1] #301502
04/29/09 09:53 PM
04/29/09 09:53 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Gary, THANK YOU!
Re: 70 Chall rear valance mounting bracket screws [Re: rayztoy] #301503
04/30/09 10:05 AM
04/30/09 10:05 AM
Cincinnati, Ohio
Cincinnati, Ohio
Gary, THANK YOU!
Your welcome.
Re: 70 Chall rear valance mounting bracket screws [Re: Challenger 1] #301504
04/30/09 01:42 PM
04/30/09 01:42 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
Great stuff, thanks!
Now, are the brackets body colored or black? Mine appear to be body colored but i don't know why, you really can't see them.
Re: 70 Chall rear valance mounting bracket screws [Re: jeff968] #301505
05/01/09 10:38 AM
05/01/09 10:38 AM
Ohio
B5TA Offline
B5TA  Offline
Ohio
should be body color. Kev
Re: 70 Chall rear valance mounting bracket screws [Re: jeff968] #301506
05/01/09 02:36 PM
05/01/09 02:36 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
Here is what they really look like, and yes, they are the identical ones that hold the Challenger rallye hood inserts to the hood. I don't see how the pics posted from that book could hold the inserts in place on a rallye hood. I do not believe they were painted. Comments please.
Re: 70 Chall rear valance mounting bracket screws [Re: m46rat] #301507
05/01/09 03:04 PM
05/01/09 03:04 PM
Cincinnati, Ohio
Cincinnati, Ohio
Are we talking about these screws/bolts? I'm 99% sure these are the bolts that came out of this 71 model when I got it.
Re: 70 Chall rear valance mounting bracket screws [Re: Challenger 1] #301508
05/01/09 03:18 PM
05/01/09 03:18 PM
m46rat Offline
m46rat  Offline
There are four of these used, two per bracket. They attach from the outside of the valence and into the two rectangular "studs" at the bottom and top of each bracket. Remember, we are talking 1970 Challenger here.
Re: 70 Chall rear valance mounting bracket screws [Re: m46rat] #301509
05/01/09 03:29 PM
05/01/09 03:29 PM
Cincinnati, Ohio
Cincinnati, Ohio
These bracket here, right?
I'm not arguing with you because I don't know anything for sure. It's just when I took my car apart I keep all the screws in order and used very few repos.
But who knows what happened to the car before I got it. Yes I realize we are talking 70 only here. Are these brackets like what is on a 70? Because these were on my 71 car.
Re: 70 Chall rear valance mounting bracket screws [Re: m46rat] #301510
05/01/09 04:07 PM
05/01/09 04:07 PM
Dallas, TX
70challrtse Offline
super gas
70challrtse  Offline
super gas
Dallas, TX
Re: 70 Chall rear valance mounting bracket screws [Re: Challenger 1] #301511
05/01/09 04:08 PM
05/01/09 04:08 PM
m46rat Offline
m46rat  Offline
They are the ones, but they are a 1970 only item. I suspect the previous owner has attached a 70 rear valence to your car. Here is a pic. of a 70(top) and a 71(bottom) rear valence. The 71 valence does not have the four holes for the brackets like a 70 does. It should be noted that 71 cars DID have the four stud holes on the brace under the rear pan, but they were not used to intall the rear valence. That center bracket on the 71 valence was used for that.
Re: 70 Chall rear valance mounting bracket screws [Re: 70challrtse] #301512
05/01/09 04:13 PM
05/01/09 04:13 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
My original 70 Cuda has the bolt head. Maybe both a phillips head and bolt head were used.
Re: 70 Chall rear valance mounting bracket screws [Re: rayztoy] #301513
05/01/09 04:46 PM
05/01/09 04:46 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Are you talking about the four threaded holes in the rear filler panel? Are those holes only used on the 70 model? I believe my 73 has the braket like the "lower" one in your picture but the rear filler panel still has the four threaded holes in it.
Re: 70 Chall rear valance mounting bracket screws [Re: burdar] #301514
05/01/09 05:10 PM
05/01/09 05:10 PM
m46rat Offline
m46rat  Offline
The holes are not threaded, they are just four punched holes.
Re: 70 Chall rear valance mounting bracket screws [Re: m46rat] #301515
05/01/09 06:25 PM
05/01/09 06:25 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The holes that are show on the right side of this picture are the ones I'm talking about. It looks like there is a square nut tacked to the filler panel. I thought they were threaded.
Re: 70 Chall rear valance mounting bracket screws [Re: Challenger 1] #301516
05/02/09 12:48 PM
05/02/09 12:48 PM
cataclysm80 Offline
cataclysm80  Offline
Yes, that's the 70 style. Is your 71 car built in late 70? Perhaps they were using up old parts.
Tav
