speaking of one wire alternators ?? #3012002
02/03/22 07:59 PM
02/03/22 07:59 PM
Seaford, Va
Kindafast Offline OP
Seaford, Va
I have another post about going to 16 Volt battery and it looks like a great idea. I see these 1 wire advertised alternators but when I look closer at them there is another plug area for another two wires What is that for ?? Most likely a dumb question but I dont want to buy the wrong alternator and have to figure out another plug . Thanks , What type . Brand are most guys using ??
6.50 @105.26
Re: speaking of one wire alternators ?? [Re: Kindafast] #3012073
02/04/22 02:11 AM
02/04/22 02:11 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Absent any pictures, I'd guess it's a GM alternator and what you are seeing is the regulator. There are prongs on it that are not needed or used on a one wire alternator. Some sellers / manufacturers put a rubber plug in the hole that covers the prongs so they can't be seen.
Re: speaking of one wire alternators ?? [Re: John Brown] #3012083
02/04/22 07:27 AM
02/04/22 07:27 AM
Seaford, Va
Seaford, Va
thank you
6.50 @105.26
Re: speaking of one wire alternators ?? [Re: Kindafast] #3012113
02/04/22 11:02 AM
02/04/22 11:02 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
my GM delco-remy 1 wire from napa had a rubber plug over 2 prong hole
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: speaking of one wire alternators ?? [Re: 440lebaron] #3012144
02/04/22 01:26 PM
02/04/22 01:26 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Old Delcotron. I used one for years. A little big, a little heavy, but it works. Kept the batteries up. Doesn't cost hundreds of dollars, And what I like about it, the thing is easy to work on in the field. I carried parts for it and had to fix it at the track one or twice.
Self exciting regulator makes it a one wire. Most companies plug the hole so the two wire plug can't be used.
Re: speaking of one wire alternators ?? [Re: CMcAllister] #3012178
02/04/22 03:00 PM
02/04/22 03:00 PM
Seaford, Va
Seaford, Va
Thanks Guys , I figured as much but was a little confused when I saw that plug spot.
6.50 @105.26
Re: speaking of one wire alternators ?? [Re: Kindafast] #3012390
02/05/22 09:50 AM
02/05/22 09:50 AM
Connellsville
71Demon528 Offline
71Demon528  Offline
Connellsville
Ya don't worry about that plug. I know that can be confusing as I was confused as well but it is not used.
Re: speaking of one wire alternators ?? [Re: 71Demon528] #3012449
02/05/22 01:23 PM
02/05/22 01:23 PM
moparx Offline
moparx  Offline
which begs the question, why are the two wires there, but plugged ?
can this alternator be used with an external regulator using these wires ?
beer
Re: speaking of one wire alternators ?? [Re: moparx] #3012455
02/05/22 01:48 PM
02/05/22 01:48 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
beer
No. Do not plug anything in there. Self exciting internal regulator. Typically, start the engine, the alternator will not work until you bring the RPM up to ~2000. Then it turns on and charges.
NHRA would do tech and check the master switch by having you start the engine and then turning off the switch to verify everything stops. Those of us who had the alternators wired into the system had to be careful not to rev the engine and turn the alternator on. Then they got wise to that and made you bring the engine up to 3000 before turning off the master. So we had to fix the wiring.
Re: speaking of one wire alternators ?? [Re: CMcAllister] #3013050
02/07/22 02:35 PM
02/07/22 02:35 PM
moparx Offline
moparx  Offline
understood about not plugging anything into those two wires, but if the serve NO purpose, WHY are they there ? shruggy
if serving NO purpose, look at how much money could be saved in the manufacture of these things. 1/2 of a penny adds up fast when you are talking millions of units installed and replaced when necessary.
there is obviously a reason [to me anyway] the bean counters allowed that connection to stay. i'm just curious as to why ?
beer
Re: speaking of one wire alternators ?? [Re: moparx] #3013057
02/07/22 02:51 PM
02/07/22 02:51 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Standard regulator...
One wire regulator kit kit with the cover....
I don't know the answer. I expect the difference is a simple change in the circuit board.
Maybe it's cheaper to use what they produce and modify it than make a large change.
I think I've seen them without the spades. Most have them.
Re: speaking of one wire alternators ?? [Re: CMcAllister] #3013081
02/07/22 03:38 PM
02/07/22 03:38 PM
moparx Offline
moparx  Offline
interesting sir. Thank You ! bow
i have never had one apart. i have just went to the Nippondenso 95 and 120 amp alternators.
Thanks again for the explanation.
the spiders in my old noggin fight to keep out other brand info, while making the cobwebs tough enough i can't remember Ma's info i have stuffed into there my entire life. laugh2
beer
