Raised exhaust port hemi in a b body. #3012772
02/06/22 04:16 PM
02/06/22 04:16 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
What are the draw backs, if any to the exhaust raised port location in a b/e body stock engine location/stock suspension situation? My goal is 600 horse 426 cu inch street build. To that end I have Hooker slip together headers, mild solid lift crane cam, Milodon gear drive, Indy single 4 intake, 850 Holley. I need to buy heads next,so here I am looking for advice.
Thanks Guys!
Re: Raised exhaust port hemi in a b body. [Re: crowbait] #3012775
02/06/22 04:19 PM
02/06/22 04:19 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Raised ports for 600hp?
Sounds like a completely avoidable headache to me.
Re: Raised exhaust port hemi in a b body. [Re: fast68plymouth] #3012801
02/06/22 05:24 PM
02/06/22 05:24 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
This is what I am hoping to hear! Thanks!
Re: Raised exhaust port hemi in a b body. [Re: crowbait] #3012890
02/06/22 09:43 PM
02/06/22 09:43 PM
4.15 stroke crankshaft, 10.5 to 1 0 or less comp ratio and a decent cam and your over 625 HP on pump gas up wrench twocents
Re: Raised exhaust port hemi in a b body. [Re: Cab_Burge] #3012925
02/06/22 11:49 PM
02/06/22 11:49 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
Great idea Cab except I already have this 426 inch
short block.
Re: Raised exhaust port hemi in a b body. [Re: crowbait] #3012931
02/07/22 12:10 AM
02/07/22 12:10 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
for that hp range do standard port. you would need custom headers for raised port.
JAKES AUTOMOTIVE
Re: Raised exhaust port hemi in a b body. [Re: JAKE68] #3013013
02/07/22 12:49 PM
02/07/22 12:49 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Standard port will be fine for that cubic inch and horse power range. I am making alot more than that with Standard port Heads still with a 10.5:1 pump gas street engine. However, mine is 528".
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Raised exhaust port hemi in a b body. [Re: 6PKRTSE] #3013038
02/07/22 02:16 PM
02/07/22 02:16 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Nobody cares that I agree, but iagree
Stock replacement type heads is all that's needed.
Rich H.
Esse Quam Videri
Re: Raised exhaust port hemi in a b body. [Re: ZIPPY] #3013042
02/07/22 02:22 PM
02/07/22 02:22 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I care LOL smile
Re: Raised exhaust port hemi in a b body. [Re: ZIPPY] #3013045
02/07/22 02:27 PM
02/07/22 02:27 PM
moparx Online content
moparx  Online Content
my limited knowledge of the Gen2 [426cin] Hemi indicates with a simple cleanup of the ports, and a mild cam, plus a good tune, 625-650 should be an easy goal to meet.
make sure to use a 3" or 3 1/2" set of pipes to the rear bumper with good mufflers.
beer
Re: Raised exhaust port hemi in a b body. [Re: crowbait] #3013110
02/07/22 05:05 PM
02/07/22 05:05 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Originally Posted by crowbait
What are the draw backs, if any to the exhaust raised port location in a b/e body stock engine location/stock suspension situation? My goal is 600 horse 426 cu inch street build. To that end I have Hooker slip together headers, mild solid lift crane cam, Milodon gear drive, Indy single 4 intake, 850 Holley. I need to buy heads next, so here I am looking for advice.
As stated above, any head will fit your needs. That being said, the best bang for the buck is still the Edelbrocks. The price has gone up but any head will end up costing as much by the time you get them done. I haven't heard of the raised ports causing an interference problem for anybody. The only minor thing you have to do is use a sanding roll to clearance the top of the cylinder for the large intake valve because you are 4.25" bore. Easy-peasy. What this will give you is brand new aluminum heads and the best high flowing ports. There's no way I'm going to pay the same money and not get brand new, latest tech, good stuff.
2011 Drag Pak Challenger
Re: Raised exhaust port hemi in a b body. [Re: rickseeman] #3013152
02/07/22 07:49 PM
02/07/22 07:49 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
^ I just wonder if Edelbrocks are a good match for stock displacement, if what I'm reading is correct, 245cc intake runners out of the box.
My iron heads after porting measured 196cc intake port. I'm running a decent sized cam and it's peaking at 7250rpm and not falling off by 7600.
Re: Raised exhaust port hemi in a b body. [Re: INTMD8] #3013159
02/07/22 08:19 PM
02/07/22 08:19 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
100% agree on the Edelbrock bang for the buck. What about the tipped valve angle head vs the standard valve angle piston relief? Is collision likely? I agree the port volume is probably a touch high.
Re: Raised exhaust port hemi in a b body. [Re: 6PKRTSE] #3013292
02/08/22 09:32 AM
02/08/22 09:32 AM
an8sec70cuda Offline
[s][/s]
iagree I have the old style Mopar Performance aluminum heads (std port location) on my 11:1 pump gas 572" hemi. Basically aluminum versions of the stock iron heads. Had MCH cnc port them and makes somewhere in the 850 hp ballpark naturally aspirated.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Raised exhaust port hemi in a b body. [Re: crowbait] #3013339
02/08/22 01:34 PM
02/08/22 01:34 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I wouldn't think that would be an issue with the cam he will be running.
Re: Raised exhaust port hemi in a b body. [Re: crowbait] #3013351
02/08/22 01:56 PM
02/08/22 01:56 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Thanks Guys!
Other than the headers needing to match the heads there is no other fit issues that I know of going with a raised port head.
Please chime in if you know different.
Re: Raised exhaust port hemi in a b body. [Re: rickseeman] #3013363
02/08/22 02:22 PM
02/08/22 02:22 PM
i thought he already had some heads, but since he doesn't, the E-brock heads are the way to go. up
beer
Re: Raised exhaust port hemi in a b body. [Re: moparx] #3013364
02/08/22 02:24 PM
02/08/22 02:24 PM
crowbait has so many projects going, i forget what he has parts wise, for each. laugh2
beer
Re: Raised exhaust port hemi in a b body. [Re: moparx] #3013573
02/08/22 11:33 PM
02/08/22 11:33 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
beer
It keeps me young!
No heads yet,but I do have new stands and shafts with used rockers arms
Cam is a crane 661201 solid flat tappet .238/.248@.050 112deg LSA .502/.507 lift with the correct springs
Header is 2 1/8" dia with 3 1/2" collector stock port location
