Mancini had some unfinished small block forgings a while back and i looked into having one finished.
It was less than 400.00 for the forging , but the finish machining was closer to 1000.00.
That , and the fact that forgings would not accommodate enough stroke for what I wanted to do made up my mind.
To have a competent shop true them up , finish size , index and equalize and do the thrust surfaces should not be cheap , and if it were , I'd be suspicious.
Those were not a high end steel either , and that should be a factor.
When I could get a decent crankshaft from Molnar for less , the die was cast.
