Core support #3012848
02/06/22 07:36 PM
02/06/22 07:36 PM
florida dade
cesar perez Offline OP
florida dade
Is the core support of a 68 dart the same as a 71 dart
Re: Core support [Re: cesar perez] #3012894
02/06/22 09:47 PM
02/06/22 09:47 PM
Cab_Burge Online work
Cab_Burge  Online Work
It can be, depending on which size radiator were in both cars when produced scope
Don't forget about all brands of Mopar's stamping the radiator core support with the VIN sequence # on them work shruggy
Re: Core support [Re: Cab_Burge] #3012911
02/06/22 10:54 PM
02/06/22 10:54 PM
florida dade
florida dade
Don't care about radiator location I care about light and bucket location
Re: Core support [Re: cesar perez] #3012947
02/07/22 02:12 AM
02/07/22 02:12 AM
The head lights buckets are part of the fenders, not the body scope
Re: Core support [Re: Cab_Burge] #3012950
02/07/22 07:27 AM
02/07/22 07:27 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Correct.
69 GTX 68 Road Runner
Re: Core support [Re: JERICOGTX] #3012997
02/07/22 12:14 PM
02/07/22 12:14 PM
florida dade
florida dade
How can I install head lights on a tilt fiberglass frontend
Re: Core support [Re: cesar perez] #3013010
02/07/22 12:45 PM
02/07/22 12:45 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Im pretty sure Unlimited Products used to sell the fiberglass headlight buckets.
I have also used old steel fenders, drilled out the headlight bucket spot welds, bonded that to a fiberglass fender for headlight and bolting to core support.
I am sure though if you are looking for weight reduction, this is not the best way. I think you can drill the spot welds on just the headlight bucket and bolt or bond that in place.
....BAD A$$ STREET CAR.....
Re: Core support [Re: cesar perez] #3013012
02/07/22 12:49 PM
02/07/22 12:49 PM
N
n20mstr Offline
n20mstr  Offline
N
There may be some variances in rad hole size and maybe some bolt holes, but the core support from 67 to 76 a body should be the same, or at least be made to work
Re: Core support [Re: n20mstr] #3013077
02/07/22 03:28 PM
02/07/22 03:28 PM
moparx Offline
moparx  Offline
if the fenders are race weight, i don't think you would be adding much to the fender with just the bracketry for the lights.
i think the bulbs, the buckets and retaining hardware is where the weight is.
you could remove a few ounces by drilling holes with a hole saw in the fender bracketry before mounting/glassing those to the fender[s].
then drill a bunch of holes in the bulb bucket.
an ounce here, and an ounce there, and before you know it, you have a pound or two.
beer
