Re: Best custom racing carb? [Re: 469runner] #3015966
02/16/22 12:51 PM
02/16/22 12:51 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Dominic worked with me on the build of my carbs. Although, I haven't changed anything but 1 jet size from his baseline values. I really don't expect MUCH more than what it's given already! That is based on both performance and O2 sensor feedback so, I have to call that a 'nailed-it'. I will add the metering is on the safe side which again in my book is 'nailed-it'. But for some reason we don't talk much anymore. Like anywhere else, I believe many pic his brain and don't reciprocate/compensate.
Re: Best custom racing carb? [Re: HardcoreB] #3015984
02/16/22 01:22 PM
02/16/22 01:22 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Dominic does some beautiful work as I follow him on Facebook. He lives in a beautiful but cold part of the country since his move. Future plans should work out great for him and his customers. I wish him nothing but good luck
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Best custom racing carb? [Re: 70satelliteguy] #3016001
02/16/22 02:00 PM
02/16/22 02:00 PM
coquille oregon
1savoyracer Offline
1savoyracer  Offline
coquille oregon
I have one from Luke Seibert, a 1050 dominator, and I am very happy with it.
Re: Best custom racing carb? [Re: HardcoreB] #3018775
02/25/22 11:05 AM
02/25/22 11:05 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I'm actually busier than ever from FB or word of mouth but yes, you can still call me and yes I'm here for you guys. I'm very impressed with how your bad azz car is running and I appreciate the props....
Re: Best custom racing carb? [Re: pittsburghracer] #3018784
02/25/22 11:33 AM
02/25/22 11:33 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
He's morphed from Desert Rat to Snowman wink
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Best custom racing carb? [Re: Brad_Haak] #3018816
02/25/22 01:16 PM
02/25/22 01:16 PM
MD
HEMI472 Offline
HEMI472  Offline
MD
why not pro systems ??? are they bad ???
Re: Best custom racing carb? [Re: HEMI472] #3018835
02/25/22 02:27 PM
02/25/22 02:27 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
popcorn
Re: Best custom racing carb? [Re: HEMI472] #3018838
02/25/22 02:42 PM
02/25/22 02:42 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Mine was great. We switched from an off the shelf 1050 Dominator (on a well used and scienced out 528 motor), to a Pro Systems dom that was built for my new (at the time) 572. I think it was rated around 1200cfm, I can't remember. Anyway, we also swapped out the manifold (440-3) to a 440-3X (again for the 572) and picked up 2 10th's. We ran it for the rest of the season, after a little tweaking, it ran a best of 10.003 @ 137 compared to the 10.3?? (it's previous best). So a solid 3 10th's overall. Pretty sure this was about 12 - 13 years ago.
Re: Best custom racing carb? [Re: Brad_Haak] #3018846
02/25/22 03:05 PM
02/25/22 03:05 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
popcorn
Both mine was so far off, car wouldn't leave the garage under its own power. Go with Thumper and have one of the best carbs you will ever have....
Re: Best custom racing carb? [Re: HEMI472] #3018885
02/25/22 05:21 PM
02/25/22 05:21 PM
PA
Harry's Taxi 2 Offline
PA
I was pretty hard on Pro Systems a while back, but after tuning with an O2 recorder, they (2-750ish's tunnel ram) weren't that far off as far as fuel curve and jetting.
Where i was really irritated was the idle and off idle initial performance.
Moving the idle jet to the lower position and some minor tweaking got them working quite well. I'm working with a pair of Dambest's now, so we'll see how they compare this season.
My brother bought a 906hp Hemi from Barton a while back and it came with a Pro Systems 1250 on it.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Best custom racing carb? [Re: Dragula] #3018889
02/25/22 05:25 PM
02/25/22 05:25 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Against his better judgement, last year a friend had a Dominator redone by Pro Systems, and similar experiences. The carb came back with a ton of work done to it, and might have still been ok at WOT, but he absolutely ruined the part throttle drivability. He couldn't go around the block anymore without the plugs getting fouled. Was a super common combo too, just an LS7 big block Chevy shortblock with a normal sized roller cam and single 4 intake.
Re: Best custom racing carb? [Re: Blusmbl] #3019321
02/27/22 10:16 AM
02/27/22 10:16 AM
Penna
70satelliteguy Offline OP
Penna
I have contacted Dominic and he is currently building my carb. Customer service and your recommendations was what sold me. I like the fact that he was willing to talk with me extensively about my combination on several occasions. I can't wait to try the new carb out!
Mike
Re: Best custom racing carb? [Re: 70satelliteguy] #3019323
02/27/22 10:22 AM
02/27/22 10:22 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I appreciate the opportunity to build what I and many others feel are one of the best carbs out there and I don't know anyone who hasn't picked up unless they didn't say anything to me and if so, I will always try and make whatever right....
Re: Best custom racing carb? UPDATE! [Re: Thumperdart] #3023411
03/12/22 09:50 PM
03/12/22 09:50 PM
Penna
Penna
Here is my new custom carb from Dominic(THUMPER CARBS) that is on the way! Great Fast customer service. Can't wait for racing season to start and give it a try.
Mike
p.s. Sure it pretty
Re: Best custom racing carb? [Re: pittsburghracer] #3023415
03/12/22 10:00 PM
03/12/22 10:00 PM
NC
440Jim Offline
440Jim  Offline
NC
We use nothing but APD with our alcohol carbs. I did some horse trading for a 1250 gas carb but haven’t tried it yet
I bought an APD alcohol carb a couple years ago, and love it. Calibration was great.
I originally borrowed the carb from another racer who was running race gas. I liked it so much I gave him the money to buy a brand new one from APD and kept the used one....
Re: Best custom racing carb? [Re: 440Jim] #3023419
03/12/22 10:34 PM
03/12/22 10:34 PM
AndyF Offline
AndyF  Offline
A good carb is hard to find. If you find one, keep it.
We tested several custom carbs last week on the dyno and they all sucked. We have a box stock Holley Gen 3 Dominator that just flat out works. It consistently runs better and makes more power than any of the "tuner" carbs that customers bring in. I don't have any explanation for it, just the way it goes.
Re: Best custom racing carb? [Re: AndyF] #3023442
03/12/22 11:57 PM
03/12/22 11:57 PM
Dragula Offline
Dragula  Offline
Everyone keeps buying the Thumper carbs I get, and then I have to order another. Its like telling people isn't always enough...Show them the plugs after a day at the track and the performance you got out if it, and man they offer up the money....
His carbs respond to the smallest changes. You can dial them right to the edge....There are very few people I would order a 4500 carb from and feel comfortable that when I got it, it would be close enough for an idiot like me to tune it with a little over the phone help.
