Re: Callies vs Bill Mitchell
[Re: rebel]
#3011788
02/03/22 06:44 AM
02/03/22 06:44 AM
Posts: 12,397 Taxes & Virus's R-US, NY
Dragula
I wouldn't buy another BM block unless it was free....Mine had the head deck holes drilled into the water jackets. +20 years of owning and buying Hemi's, and that's never happened, let alone on a brand new block....Called him on it, and he treated me worse than Indy if you can believe that....With service like his, no thanks, been there, done that.
Other than that, the blocks are very similar. I will have to look mine over a little more, but they are very close.
[Re: Dragula]
#3011791
02/03/22 07:26 AM
02/03/22 07:26 AM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
Other than that, the blocks are very similar. I will have to look mine over a little more, but they are very close. What Deck holes are you talking about?
[Re: Dragula]
#3011824
02/03/22 10:08 AM
02/03/22 10:08 AM
Posts: 879 Missouri
jwb123
Missouri
Other than that, the blocks are very similar. I will have to look mine over a little more, but they are very close. Funny every small block chevy ever built has the head bolts drilled into the water jackets, never seen it as a deal breaker. A lot of engines have the head bolts drilled into the water jackets, that is what they make teflon pipe sealer for.
[Re: jwb123]
#3011840
02/03/22 11:25 AM
02/03/22 11:25 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I bought a BMP block a year ago. It is one of the first produced in 2021. Machining was good. My machinist did align hone it as one bearing bore was a bit tight. Also took . 005 off the decks. The cylinders were smaller than 4.490, at 4.486 if i recall. The bushed lifterbores were a challenge to get honed to size but that i believe is a good thing, as my lifters are . 9030. Cost about $1,000.00 to get it assembly ready. I didn't consider that out of line given the block comes with sleaved lifter bores that need to be machined to your lifters, and have oil feed holes in them for hydraulic type lifters. Also the bores took time to get brought out to 4.500, which added to the final cost. The block ready for assembly weighs 143 lbs (cheap bathroom scale) and my megablock weighs 148 lbs for a weight savings of 105 lbs. All in all, so far i am happy with it. I got as far as final assembly before changing directions on the heads. That decision required new( different) pistons which are still on order along with the heads. So far i see it as a good purchase.
[Re: blowndart]
#3011883
02/03/22 02:19 PM
02/03/22 02:19 PM
Dragula
Bill Mitchell is aluminum and Callies is iron. So.. that's a difference. I just bought a BM block, and so far, I don't see anything wrong with it. That was after they stopped making the iron ones. I had one of the iron ones a while back. Some kind of agreement with Chrysler/Mopar.... I wouldn't buy another BM block unless it was free....Mine had the head deck holes drilled into the water jackets. +20 years of owning and buying Hemi's, and that's never happened, let alone on a brand new block....Called him on it, and he treated me worse than Indy if you can believe that....With service like his, no thanks, been there, done that.
Other than that, the blocks are very similar. I will have to look mine over a little more, but they are very close. Funny every small block chevy ever built has the head bolts drilled into the water jackets, never seen it as a deal breaker. A lot of engines have the head bolts drilled into the water jackets, that is what they make teflon pipe sealer for. That's great if you know about it. BBM was never this way, and we have never had to put sealer on every head deck bolt on a BBM before...So going to the track and block fills with coolant and locks up is not cool.....
[Re: Dragula]
#3011904
02/03/22 03:30 PM
02/03/22 03:30 PM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
Bill Mitchell is aluminum and Callies is iron. So.. that's a difference. I just bought a BM block, and so far, I don't see anything wrong with it. That was after they stopped making the iron ones. I had one of the iron ones a while back. Some kind of agreement with Chrysler/Mopar.... Sure. Back then they were know as World or Mopar Performance blocks. The Op was asking about Callies or Bill Mitchel which are current blocks, so I assumed he was asking about the aluminum block since BM hasn't made iron in somewhere like over a decade.
[Re: blowndart]
#3012140
02/04/22 01:10 PM
02/04/22 01:10 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
Basically the same block one in aluminum one in iron. The Callies block is based off the "megablock" castings that Mitchell/World were making. Not saying World blocks didnt have issues but it seems the BMP stuff seems to be much better machining wise. I had three iron and two aluminum World/BMP blocks and definitely had some issues. But not unusual for this stuff to reuire some work to be perfect. I did have one that required way to much work and the conclusion was drawn that it was possibly a blem deal.
