Re: 73 Dart Caliper Rattle...
[Re: MNobody]
#301170
04/27/09 05:51 PM
04/27/09 05:51 PM
RapidRobert
bend the tabs on the one pad so you have to tap it in place into the caliper & the other pad fits in loosely(file it on each end if it doesn't) & use some disc brake quiet on the backs where they contact the caliper
[Re: MNobody]
#301174
04/27/09 06:23 PM
04/27/09 06:23 PM
RapidRobert
Oh Ok. With the caliper making contact in the grooves that let it slide each way what about taking the caliper out & greasing the grooves w some grey antisieze paste? Wire brushing them clean for a few seconds 1st.
[Re: MNobody]
#301176
04/27/09 06:37 PM
04/27/09 06:37 PM
RapidRobert
bend the holddowns as they should be bending a little as you snug them down onto the caliper & be under tension. EDIT I have gotten(myself) off track here yes just bend them a good amt so that they bend & are under a fair amount of tension by the time the bolt is all the way in.
