Page 3 of 4 1 2 3 4
Re: anyone using an 8.8 Ford in a B body? [Re: Mr T2U] #3009088
01/26/22 08:14 AM
01/26/22 08:14 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Originally Posted by Mr T2U
the biggest advantage is the 8 3/4 will use a little less HP to turn over the 8.8 and that really isn't a consideration in this conversation.
Horsepower lost to friction wise,
does the Ford 8.8 have design features that make it lower loss than a Ford 9 inch diff?
Re: anyone using an 8.8 Ford in a B body? [Re: 360view] #3009091
01/26/22 08:36 AM
01/26/22 08:36 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
from what i am told the ring gear/ pinion gear friction is less in the 8 3/4 than in the 8.8.
also the ford 9" is probably one of the worse rears made in pinion / ring gear friction. the biggest advantage and why so many people install it is the strength in both the gears and the large bearings in the axles and ease of changing gears like the 8 3/4.
availability of both parts and service techs to repair it and price of the parts is also a consideration of the ford 9".
perception is 90% of reality
Re: anyone using an 8.8 Ford in a B body? [Re: Mr T2U] #3009412
01/26/22 09:28 PM
01/26/22 09:28 PM
Minn
SportF Offline
SportF  Offline
Minn
I really really wish someone would test the 9" and give us an ACTUAL percentage loss against a few other rears. This "rumor" idea/statement about power loss has never been tested rear for rear, yet this idea just hangs around and around. The magazine that tested rears drove it via the engine and there is so much not scientific about that its hard to believe they actual took the time to do it.
Re: anyone using an 8.8 Ford in a B body? [Re: SportF] #3009433
01/26/22 10:08 PM
01/26/22 10:08 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Mark Williams had a display at Indy one year with a 9" setup tied to an electric motor. The purpose was to show how much power it took to accelerate the ring gear through a 1/4 mile run.
It was 1/3 hp. boogie
Re: anyone using an 8.8 Ford in a B body? [Re: SportF] #3009439
01/26/22 10:22 PM
01/26/22 10:22 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The lower pinion position in relation to the ring gear means more contact but also more drag.
If you had a pinion that intersected the ring gear at the 9:00 position instead of well below centerline like all other axles, it would have the least drag, the smallest pinion, the weakest rating and the most noise.
Re: anyone using an 8.8 Ford in a B body? [Re: Kern Dog] #3009444
01/26/22 10:43 PM
01/26/22 10:43 PM
Minn
SportF Offline
SportF  Offline
Minn
I realize that, but does that mean 0.002 percent lose, or does it mean 10% loss? See, no one can tell you that, its just the same statement that its a power loss.
Some of the best race advice I got was "If everybody is doing it, its probably a pretty good idea". Well, when you go to the track and look at the cars that are going 5 seconds and faster in the 1/8, there is no dana's down there. None.
So, take a rear, put a load sensor on the input, and a dyno brake on the output and compare them subtracting the bearing preload while you are at it. Then, we'd all know. But, right now, everybody doesn't know (yeah, I said it that way on purpose).
Where is Roadkill garage or some other car show that would do that?
Re: anyone using an 8.8 Ford in a B body? [Re: SportF] #3009484
01/27/22 06:59 AM
01/27/22 06:59 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I know a facility that has the equipment to do that. Willingness?
Angry white pureblood male
Re: anyone using an 8.8 Ford in a B body? [Re: ruderunner] #3009496
01/27/22 07:55 AM
01/27/22 07:55 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The 8.8 out will long outlive an 8.75 when it comes to power. Lots and lots of guys running 8s in the 1/4 on mildly built 8.8s, some manual transmission cars even.
68 Barracuda Formula S 340
Re: anyone using an 8.8 Ford in a B body? [Re: SportF] #3009500
01/27/22 08:24 AM
01/27/22 08:24 AM
USA
3
360view Offline
360view  Offline
3
USA
Silly me almost paid for a Quickchange differential to be installed in a 1995 Ram.
$1400 plus $1100 installation about the year 1999.
Quickchange and 9” Ford are cousins, if I remember correctly.
Like an itch ya just gotta scratch,
I wanted to know how engine rpm and throttle opening
affected vehicle MPG, engine Brake Specific Fuel consumption, and acceleration.
I probably would have done some quarter mile runs with different ratios and 0-60 mph runs at Rockingham.
I could have further amused myself by towing different loads up my favorite steady 4% grade hill.
This might all sound crazy
but there is an old SAE paper from a British group
that took a vehicle,
fitted two Laycock overdrive units in series
behind the 5 speed manual transmission,
and drove around collecting a huge amount of on road data
that they condensed into interesting graphs of
speed, engine rpm, manifold vacuum, fuel economy, etc.
The two added gears on the Quickchange diff do add their own increased friction.
Re: anyone using an 8.8 Ford in a B body? [Re: 360view] #3009584
01/27/22 01:30 PM
01/27/22 01:30 PM
moparx Offline
moparx  Offline
by quick change, do you mean like a franklin or winters rear ?
beer
Re: anyone using an 8.8 Ford in a B body? [Re: SportF] #3009622
01/27/22 02:58 PM
01/27/22 02:58 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Frieberger(?) did that test years ago, D60 vs 12 bolt vs 9". Not sure that article is online though. And Mark Williams claim of a 1/3hp is patently BS.
Re: anyone using an 8.8 Ford in a B body? [Re: Sniper] #3009643
01/27/22 03:43 PM
01/27/22 03:43 PM
Kirkland, Washington
Pacnorthcuda Offline
Seems like a pretty good idea of frictional loss could be calculated easily since transmission losses are pretty well known and Dyno tests of both flywheel and rear wheel have been done of the same exact cars several times.
Re: anyone using an 8.8 Ford in a B body? [Re: moparx] #3009679
01/27/22 05:02 PM
01/27/22 05:02 PM
USA
3
360view Offline
360view  Offline
3
USA
Winter’s I think was first design,
“Quickchange” a second “improved” durability design.
https://www.circletracksupply.com/d...mag-center-tubes-imca-legal.html?cat=194
Re: anyone using an 8.8 Ford in a B body? [Re: 360view] #3010909
01/31/22 06:12 PM
01/31/22 06:12 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Personally, I find it hard to fork out $500 or more for an 8 3/4 SG center section that is used and my or may not need rebuilding. And (at least to me) forking over $1K or more for a new one is equally hard to swallow. blush
An 8.8 for about $150 or so with 3.73s or 4.10s and a posi is a reasonable alternative. shruggy
It's not like they were abused in those Exploders. biggrin
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: anyone using an 8.8 Ford in a B body? [Re: I_bleed_MOPAR] #3011037
02/01/22 08:33 AM
02/01/22 08:33 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
The fact that the 9" has more drag is due to the pinion shaft being far below the ring gear centerline. This is also what makes it strong, lots of tooth contact. Power drag isn't enough to worry about unless your trying to run for some type of class record. Dana's have their place. Cheap strong in factory form. Why is everything that is really quick a 9"? Aftermarket support. Tons of parts available. Including center sections designed for 12 bolt Chevy gears. Which have the least drag of nearly any rear axle. A 5 second flat car isn't cheap. So cost generally isn't an issue. But a good 9" isn't cheap. Me? I'm cheap. My car runs well into the 5's. It uses a home built Dana that cost me less than $900 to build. Now a days on the street or general track use? I'd seriously look into the 8.8 Ford for sure. Watch what cars are running them. Plenty of fast stuff. They're modern, plentiful, cheap, disc brakes, factory gear 3.73/4.10. I'd be going to the junkyard if I didn't have 8 3/4 or Dana stuff in the car to start with. Even if you have 8 3/4, the sure grip, gear, and labor exceeds the junkyard cost. of an 8.8. Obviously the spring pads and drive shaft need mods to use an 8.8. But if you didn't have an 8 3/4 you probably needed a better drive shaft anyway.
Doug
Re: anyone using an 8.8 Ford in a B body? [Re: dvw] #3011085
02/01/22 11:44 AM
02/01/22 11:44 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
These 8.8 axles don't appear to have a pinion snubber so do people just go without?
Re: anyone using an 8.8 Ford in a B body? [Re: Neil] #3011282
02/01/22 07:40 PM
02/01/22 07:40 PM
Mr T2U Offline
Mr T2U  Offline
on my 08 mustang i had a 3 link rear suspension. this design doesn't need a pinion snubber.
couldn't tell you where they do this. just thinking maybe you could just bolt the snubber to the floor instead of the axle.
the 9" they make a bracket that uses the bolts by the pinion seal to mount it.
Re: anyone using an 8.8 Ford in a B body? [Re: Mr T2U] #3011313
02/01/22 09:01 PM
02/01/22 09:01 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
A snubber is pretty application specific. Do you have the power and tires to need one? If so, you probably need something stronger than an 8.8 to begin with.
Re: anyone using an 8.8 Ford in a B body? [Re: ruderunner] #3011318
02/01/22 09:06 PM
02/01/22 09:06 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Oh for crying out loud, the 7 1/4 has a pinion snubber. Let's try to keep the outlandish rhetoric within reasonable bounds.
Re: anyone using an 8.8 Ford in a B body? [Re: Sniper] #3011664
02/02/22 06:48 PM
02/02/22 06:48 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Doesn't mean it does anything. They're known to be marginal behind slant sixes.
Page 3 of 4 1 2 3 4
