Powdercoating threaded parts question.
#301119
04/27/09 03:20 PM
04/27/09 03:20 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
This may be a dumb question but since I have never had anything powdercoated before I'm going to ask. Do you need to mask or protect the threads when you have something powdercoatd to avoid excessive build-up? In other words, will the nuts still screw on to the threads if you the stud threads get powdercoated?
Thanks in advance. Joe
65 Barracuda 70 Challenger
Re: Powdercoating threaded parts question.
[Re: jrwoodjoe]
#301120
04/27/09 03:36 PM
04/27/09 03:36 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
That's a good question. I'm sure they handle these things all the time. But from my discussion Friday with a coater,, they spray/coat the negatively charged clean component with a powder that's positively charged as it leaves the spray gun. This polarity difference causes the powder to adhere well to the component. Then, the componet is placed in an "oven" where the high temperatures cause the powder to "melt" persay and become fluid this creating a smooth finish.. I guess the textured powders retain that texture. So, as long as you have something taping off the threads and can deal with the oven temps, you're ok.. My rookie ![](/ubbthreads/images/graemlins/Twocents.gif)
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#301121
04/27/09 04:10 PM
04/27/09 04:10 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Your powdercoater will/should have whatever masks, tapes, etc that are needed to do the job, just point out areas such as threading, that you don't need powder on,......when preping any part for a powdercoater the ONLY thing you can do to lower the cost, and actually help the coater, is sandblasting the part(s), no chemical strippers
[Re: DAYCLONA]
#301122
04/27/09 04:17 PM
04/27/09 04:17 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
Thanks for the input. I'm getting ready to batch clean some suspension parts and have considered having them powdercoated. I was going to have my media blaster shop blast them clean for me and then possibly drop them off. I thought masking would be necessary but was not sure. Thanks again for answering my "dumb" question.
Joe
[Re: jrwoodjoe]
#301125
04/27/09 05:54 PM
04/27/09 05:54 PM
Posts: 733 Long Island NY
yellow sixpack
Long Island NY
Did my whole front end with powdercoat except changable parts such as tie rod ends ect..even the hardware and strut rods bolts all powder coated. Everything went on fine. Here are some pics look ant the bolts and nuts.
If you can't be smart.....don't be stupid!
[Re: maundmotorworks]
#301127
04/27/09 08:39 PM
04/27/09 08:39 PM
Posts: 2,808 Wisconsin
wkroncke17
Wisconsin
The powdercoater will have a special high heat masking tape that is used specifically for covering threads and other areas that cannot have powder. They also use ordinary corks to plug threaded holes.
![](/ubbthreads/images/graemlins/iagree.gif) I powdercoat in my garage,the powdercoat company will use high temp tape to cover anything needed,for big areas, tin foil held on by tape. The plugs are actually a high temp silicone material. It all works real good, If I can do it in my shop with great results, you should have no worries bringing it to a professional. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: jrwoodjoe]
#301128
04/27/09 09:08 PM
04/27/09 09:08 PM
hemi68charger
Houston, Tx
Does ANYONE know a source for the proper OEM suede black for dashes, upper headliner trim and steering column? Troy EDIT Mike, I just saw your other post to me... ![](/ubbthreads/images/graemlins/thumbs.gif) Troy
[Re: Stanton]
#301131
11/17/09 08:31 PM
11/17/09 08:31 PM
Posts: 872 Charlotte NC
DCI
Charlotte NC
Powder cures at 375-400 not 600.
Coater should have everything needed to cover or plug threads. Just point them out when you drop it off. I ask them to just put a little masking tape on the areas they want left bare. I normally blast the threads clean (120 grit) to make it easier on re-assembly.
"Turbo will be easiest, and at the HP level will also be easiest on parts. Spend the money to do it right, and you can build a 500 HP street motor that will live a long and happy life, and probably with a very basic short block."
Those words must have left a bad taste in his mouth!
[Re: DCI]
#301132
11/18/09 12:43 AM
11/18/09 12:43 AM
Posts: 8,926 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Ok, even better for the tape !!
[Re: Stanton]
#301133
11/18/09 09:34 AM
11/18/09 09:34 AM
DCI
Charlotte NC
JMHO - Do not leave the masking tape on for the cure cycle. I have seen the masking tape dry out and start flaking off. The flakes could/can fall on the coated part and ruin the coating. Your coater will have high temp tape or silicone plugs. When someone drops things off at our shop one of us goes over the parts and marks(if they have not already been marked) what needs to be powder free. Simple to cover after blasting and safer.
