Silocon bronze welding headers
#3010669
01/30/22 09:23 PM
01/30/22 09:23 PM
Posts: 10,006 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Bought a welder, Eastwood Elite MP250i. Mig, Tig, stick, 250 amp max. I heard about silicon bronze so i bought a couple of pounds. $58! I had a large argon tank from forty years ago; still full of argon! Obviously i don't weld a lot. I have . 030 Silocon bronze wire, and once i get some practice in it will work well for me. Here are pics of collecter parts i started on tonight. The bronze can be smoothed out or ground down very easily, important for my skill level
Re: Silocon bronze welding headers
[Re: gregsdart]
#3010700
01/30/22 11:30 PM
01/30/22 11:30 PM
Posts: 11,578 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Go to Burns, and some of the other stainless header people, maybe some you tubes from guys who do a bunch of it. See what they are doing. 304 stainless should use 307L wire for most of the fab work. Small stuff. I bought a roll of .035 MIG 307 wire and use that, Same stuff as TIG wire. Tubes need to be back purged. If the joints are kept tight, you can actually fuse it using little filler. SiBR is only used for the outside of the flange to tube joint. The silicon bronze is less tensile than the stainless. It's "softer" and has some give. It helps to keep the headers from cracking there while supporting them. It also has a lower melting point so you don't have to make the header material "wet" or melt it. It's more of a brazing process. Making the steel melt is way too hot for the silicon. And the outside doesn't need to be completely welded. The seal is the inside weld at the end of the tube. The silicone outside is a support/reinforcement. Material is expensive. I would get some cheaper straight pieces and practice. Cutting, making perfect joints, setting up your back purge rig and your torch, and welding joints. It's a different animal than mild steel.
[Re: CMcAllister]
#3010714
01/31/22 12:49 AM
01/31/22 12:49 AM
gregsdart
My headers are all mild steel. I definately need some practice. I plan on leaving a somewhat wide raised bead of weld so the tube welds will be plenty strong. Header wrap will be used also. I am using the mig gun.
[Re: gregsdart]
#3010735
01/31/22 07:14 AM
01/31/22 07:14 AM
Posts: 10,027 MN
JERICOGTX
MN
My headers are all mild steel. I definately need some practice. I plan on leaving a somewhat wide raised bead of weld so the tube welds will be plenty strong. Header wrap will be used also. I am using the mig gun. Let me know when you want to meet up for templates.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3010746
01/31/22 09:49 AM
01/31/22 09:49 AM
Posts: 10,721 North Dakota
6PakBee
North Dakota
When I was gainfully employed did quite a bit of stainless piping projects. TIG welding in place with piping up to 12" made back purging problematic. The fitters would use this painted on the back side of the weld prior to fitup. Worked like a charm. May be an alternative to back purging for these types of projects. Solar Flux
[Re: 6PakBee]
#3010749
01/31/22 10:00 AM
01/31/22 10:00 AM
Posts: 8,873 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
setting up your back purge rig and your torch, and welding joints. It's a different animal than mild steel. You're obviously talking "tig" but the OP's reference to .030 wire would indicate he's using "mig". As for using mig, you're using the wrong gas. Straight argon is for tig ... ONLY ... PERIOD. For mig you want a co2/argon mix. And for what you're doing I would suggest not trying to run a bead but rather a series of spaced tacks. You seem to have too much heat in your parts as well, cool off the tacks with compressed air.
[Re: Stanton]
#3010759
01/31/22 10:28 AM
01/31/22 10:28 AM
Posts: 35 Livonia,MI
1968fury
Livonia,MI
setting up your back purge rig and your torch, and welding joints. It's a different animal than mild steel. You're obviously talking "tig" but the OP's reference to .030 wire would indicate he's using "mig". As for using mig, you're using the wrong gas. Straight argon is for tig ... ONLY ... PERIOD. For mig you want a co2/argon mix. And for what you're doing I would suggest not trying to run a bead but rather a series of spaced tacks. You seem to have too much heat in your parts as well, cool off the tacks with compressed air. I think you need to re read the original post.
71 scamp 340 509 cam 456 gear,68 fury1 318 3spd on the tree,50 merc flathead 3x2 3spd w/overdrive
[Re: Forest]
#3010836
01/31/22 01:49 PM
01/31/22 01:49 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Silicon bronze is brazing when used correctly. If you're melting the base metal, it's too hot for the SiBR and it will crack.
[Re: CMcAllister]
#3010955
01/31/22 09:43 PM
01/31/22 09:43 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Silicon bronze is brazing when used correctly. If you're melting the base metal, it's too hot for the SiBR and it will crack. What he said… Absolutely correct. the first time i tried it, I was trying to “weld” with it. cracka shacka lacka.
[Re: TRENDZ]
#3010956
01/31/22 09:45 PM
01/31/22 09:45 PM
TRENDZ
Milwaukee WI
[u][/u]…and it is absolutely miserable to cut/ machine.
[Re: 67_Satellite]
#3010993
01/31/22 11:35 PM
01/31/22 11:35 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I'm not a professional welder by any stretch of the imagination. I welded my 304 s.s. manifolds together with 308 wire and no back purging. Did have 75/25 Argon& co2 gas. They're still working and crack free after 11 years. Was I just lucky, or is the back purging really not that critical. This is what "sugaring" looks like when you don't purge the tube. Scabs, scale, damaged material. The weld is weaker. The outside weld doesn't run as nice and doesn't look as nice as one that has coverage on both sides either. SS needs straight Argon.
[Re: RTSE4ME]
#3011019
02/01/22 02:10 AM
02/01/22 02:10 AM
gregsdart
I am going to try Silicon bronze mig on a 20ga sheet metal project with .023 wire. You have any issues with feeding the soft wire? The shorter the mig cable the better. It is recomended to use a liner of plastic(?) Or is it teflon? Ask one of the welder manufacturer techs. I run .030 wire and keep the cable to the mig gun as bend free as i can. It took some adjustment to get my deal going. I am using a steel liner.
[Re: gregsdart]
#3011031
02/01/22 07:05 AM
02/01/22 07:05 AM
Posts: 10,027 MN
JERICOGTX
MN
I am going to try Silicon bronze mig on a 20ga sheet metal project with .023 wire. You have any issues with feeding the soft wire? The shorter the mig cable the better. It is recomended to use a liner of plastic(?) Or is it teflon? Ask one of the welder manufacturer techs. I run .030 wire and keep the cable to the mig gun as bend free as i can. It took some adjustment to get my deal going. I am using a steel liner. .030 is some very heavy wire. I would for sure switch to .023. Makes a big difference.
69 GTX
68 Road Runner
[Re: EchoSixMike]
#3011265
02/01/22 07:08 PM
02/01/22 07:08 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Brazing is plenty strong, all the old time and even current SCCA race cars are brazed. Aircraft are brazed. Bicycles made with preposterously thin 4130 are brazed. S/F....Ken M "Always avoid brazing 4130 steel. The reason to not braze chromemoly is that this steel has a definite grain structure that actually opens up at medium red brazing temperatures. When brazing alloy is melted onto the steel surface, it flows easily into the many small cracks and crevices in the chromemoly steel. Then, as the braze joint cools, the brass will not compress and it forces major cracks to form in the 4130 steel. Often, a brazed 4130 steel part will crack completely in two before your eyes as it cools." Performance Welding, Richard Finch, c. 1997, pg. 130. The only place SiBR is typically used on a race car today is putting sheet metal in and header flanges. Aircraft were brazed - 100 years ago. Then TIG was invented. Some hobby planes may still be. Conversation was stainless headers. Burns has some great header construction articles.
