66 Plymouth Belvedere rear suspension discussion #3010519
01/30/22 01:00 PM
01/30/22 01:00 PM
Wisconsin
Garceau Offline OP
Garceau  Offline OP
Wisconsin
Primarily a decent HP, good torque street cruiser.
I don't suspect this to see the track often or more than a little testing here or there. But very little track use.
But it's in need or rear suspension upgrade of some sort.
I have not really messes with rear leaf suspension in 25 years. Everything I've built as of late is narrowed, 4 Lin and coil overs. So please forgive my ignorance.
Thoughts on Suoer Stock springs, cal Trac type set up, any other types I should look at?
Not building this to be an auto cross type car. Weekend cruiser, straight line acceleration etc.
Appreciate it folks
Re: 66 Plymouth Belvedere rear suspension discussion [Re: Garceau] #3010528
01/30/22 01:29 PM
01/30/22 01:29 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
From what you describe just a new set of HD 4 speed Dana springs.
Re: 66 Plymouth Belvedere rear suspension discussion [Re: cudaman1969] #3010535
01/30/22 01:43 PM
01/30/22 01:43 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
My '66 Charger is pretty close to what you describe. I run the 3800lb. SS springs with the front eye in the top hole of the bracket, and the MP shocks they recommend for that set up. Drives good on the street, and hooked up good with drag radials when I took it to the track. twocents
Re: 66 Plymouth Belvedere rear suspension discussion [Re: bobby66] #3010614
01/30/22 06:06 PM
01/30/22 06:06 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
X3. From what you're describing, you can do alot worse than factory hi po stuff.
Angry white pureblood male
Re: 66 Plymouth Belvedere rear suspension discussion [Re: ruderunner] #3010946
01/31/22 09:25 PM
01/31/22 09:25 PM
Wisconsin
Garceau Offline OP
Garceau  Offline OP
Wisconsin
Thanks. Some options for sure.
Car will see mostly cruising. Only about 450hp but good torque. Needs some head work to let the cubes breath some.
Appreciate the input
