Re: Where can I find flexplate to crank bolts? [Re: B1duster] #3009689
01/27/22 05:37 PM
01/27/22 05:37 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
Thanks for the offer, but we found some at an engine machine shop. That would be the cheaper way to go though.
Re: Where can I find flexplate to crank bolts? [Re: rapom] #3010080
01/28/22 07:22 PM
01/28/22 07:22 PM
B.C. Canada
hankcrank Offline
hankcrank  Offline
B.C. Canada
I made my own using short grade 8 bolt NFT'1/2" or 7/16" which ever size you need and made the tops thinner with a lathe. More availability and cheaper.
Re: Where can I find flexplate to crank bolts? [Re: hankcrank] #3011834
02/03/22 11:03 AM
02/03/22 11:03 AM
If you are OK with good used there is a ton of em for sale on FABO
