2011 ram no start #3009731
01/27/22 07:54 PM
01/27/22 07:54 PM
S E Michigan
E
ekim Offline OP
ekim  Offline OP
E
S E Michigan
i bought this new, with the old style v6 now has 187000 miles and starting a few months ago wierd electrical issues came up. check engine light would come on for a day and then go off by itself. then the low tire light would come on for an hour and then go off, one time it flashed on then went right back off, (the tires had enough air in them) then the radio would only get a few of the presets
this morning, coldest day yet 4 deg f it cranked for about 1/4 second and and just stopped cranking as if it blew a circut breaker. i wiggled the at shifter but nothing, dome light and dash lights come on but no cranking, any thoughts? maybe neutral saf switch?
i wanted to try it in neutral but i have no idea how to get it out of park. thanks
Re: 2011 ram no start [Re: ekim] #3009761
01/27/22 08:59 PM
01/27/22 08:59 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Don't know if you can find the fault codes on your RAM like this but it is possible on a lot of earlier RAM and Chrysler products. Then you might try rebooting by disconnecting the battery for ten minutes or less?
Re: 2011 ram no start [Re: A12] #3009777
01/27/22 09:43 PM
01/27/22 09:43 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Get the battery tested. The newer vehicles go stupid if the battery is weak.
Re: 2011 ram no start [Re: ekim] #3009834
01/27/22 11:48 PM
01/27/22 11:48 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Original battery????
Re: 2011 ram no start [Re: ekim] #3009852
01/28/22 01:44 AM
01/28/22 01:44 AM
On the open road
Hrtbkr Offline
Hrtbkr  Offline
On the open road
A buddy just went through this with his '11.
It turned out to be the fuel pump relay.
The recommended fix was to replace the entire fuse block.
He found a relay bypass kit instead.
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: 2011 ram no start [Re: Hrtbkr] #3009857
01/28/22 04:51 AM
01/28/22 04:51 AM
S E Michigan
E
ekim Offline OP
ekim  Offline OP
E
S E Michigan
i forgot to say it is a 3 month old battery
Re: 2011 ram no start [Re: ekim] #3009871
01/28/22 08:46 AM
01/28/22 08:46 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Start here https://www.youtube.com/watch?v=44yn04pKdSk If it cranks by by jumping the relay the bcm isn't controlling the start relay. As I remember the bcm ground is on the left fender well near the hood hinge. A poor BCM ground would explain the weird behavior. If that doesn't do it you need to scan it for faults.
Doug
Re: 2011 ram no start [Re: dvw] #3009899
01/28/22 11:41 AM
01/28/22 11:41 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Get a volt meter on it and see what the reading is. Check right on the posts first and see if its around 12.6 and go from there.
Re: 2011 ram no start [Re: NITROUSN] #3010007
01/28/22 03:58 PM
01/28/22 03:58 PM
moparx Offline
moparx  Offline
i'm not too familiar with how the under hood main fuse box is in relation to the battery, but i have fixed a few new[er] vehicles wiring problems by looking for the "green death" in the wiring bundle or under/by the battery tray.
it seems the battery gasses over time, degrade the insulation and connections close by the battery, causing all kinds of goofy stuff to happen.
look close at all the ground connections [if any] by the battery as well. they may look good on the top side, but hide "green death" under them, and possibly creeping up the wire as well, under the insulation.
just something else to look at.
hopefully, it will be a relatively easy fix.
beer
Re: 2011 ram no start [Re: moparx] #3010083
01/28/22 07:44 PM
01/28/22 07:44 PM
S E Michigan
E
ekim Offline OP
ekim  Offline OP
E
S E Michigan
loose battery cable
thanks
Re: 2011 ram no start [Re: ekim] #3010270
01/29/22 02:11 PM
01/29/22 02:11 PM
moparx Offline
moparx  Offline
well that was an easy fix ! up
glad for ya it wasn't anything bad. [especially if it is cold where you are at !]
beer
