Re: One piece oil pan gasket for small block
[Re: DusTed74]
#3009659
01/27/22 04:16 PM
01/27/22 04:16 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I just picked up 2 of them from O'Rielly's last week, $42 Fel-Pro you can order them from Rock Auto and they are only $23
1993 Dodge Dakota with V8, doesn't matter which one 318 or 360, both are Magnums and use the same pan gasket.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: DusTed74]
#3009695
01/27/22 06:13 PM
01/27/22 06:13 PM
Posts: 1,760 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Hmm...interesting...because as long as I remember, the one-piece gasket for the non-Magnum setups was basically made from "unobtanium"!!! I looked at the JEGS item, and sure enough it says this will work with non-Magnum engines...but can anyone actually confirm this? @DusTed74 I have a previously bought SCE gasket here, part# 269091, and I thought this would for my '76 360...it would not. If you are looking for that fit let me know.
[Re: Diplomat360]
#3009710
01/27/22 07:19 PM
01/27/22 07:19 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
Hmm...interesting...because as long as I remember, the one-piece gasket for the non-Magnum setups was basically made from "unobtanium"!!! I looked at the JEGS item, and sure enough it says this will work with non-Magnum engines...but can anyone actually confirm this? @DusTed74 I have a previously bought SCE gasket here, part# 269091, and I thought this would for my '76 360...it would not. If you are looking for that fit let me know. Do a search here on Moparts and google for One Piece 360 gasket. But talked about before. I got a the SCE one and it does not work on a LA 360 by itself. The ends are all wrong.
[Re: cudaman1969]
#3009783
01/27/22 10:03 PM
01/27/22 10:03 PM
autoxcuda
So Cal
Magnums have a groove on the rear main cap, the LA 360 is flat, I think. I made mine for the 340 So you machined that groove in there? I thought there was something about the corners of the cap to the block meeting area. Like you had to add angle wedges to make up for difference?
[Re: autoxcuda]
#3009807
01/27/22 10:45 PM
01/27/22 10:45 PM
Posts: 8,285 fredericksburg,va
cudaman1969
fredericksburg,va
Nope, just not a true circle more of an arch. Oil pipe Straight down from the pump (well a little curve) and bigger diameter. Copied a magnum cap.
