One piece oil pan gasket for small block #3009652
01/27/22 03:59 PM
01/27/22 03:59 PM
WI. U.S.A.
DusTed74 Offline OP
DusTed74  Offline OP
WI. U.S.A.
Does anyone out there know where that I can get one of these. It is an early 360 engine.
Jegs have the part number but they are out of stock.. 555-210495
Any help would be appreciated.
Thanks................Ted
Re: One piece oil pan gasket for small block [Re: DusTed74] #3009659
01/27/22 04:16 PM
01/27/22 04:16 PM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
I just picked up 2 of them from O'Rielly's last week, $42 Fel-Pro you can order them from Rock Auto and they are only $23
1993 Dodge Dakota with V8, doesn't matter which one 318 or 360, both are Magnums and use the same pan gasket.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: One piece oil pan gasket for small block [Re: DusTed74] #3009695
01/27/22 06:13 PM
01/27/22 06:13 PM
Windsor, ON, Canada
Diplomat360 Online content
Diplomat360  Online Content
Windsor, ON, Canada
Hmm...interesting...because as long as I remember, the one-piece gasket for the non-Magnum setups was basically made from "unobtanium"!!!
I looked at the JEGS item, and sure enough it says this will work with non-Magnum engines...but can anyone actually confirm this?
@DusTed74 I have a previously bought SCE gasket here, part# 269091, and I thought this would for my '76 360...it would not. If you are looking for that fit let me know.
Re: One piece oil pan gasket for small block [Re: Diplomat360] #3009710
01/27/22 07:19 PM
01/27/22 07:19 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Do a search here on Moparts and google for One Piece 360 gasket. But talked about before.
I got a the SCE one and it does not work on a LA 360 by itself. The ends are all wrong.
Re: One piece oil pan gasket for small block [Re: autoxcuda] #3009732
01/27/22 07:55 PM
01/27/22 07:55 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Magnums have a groove on the rear main cap, the LA 360 is flat, I think. I made mine for the 340
Re: One piece oil pan gasket for small block [Re: cudaman1969] #3009734
01/27/22 07:57 PM
01/27/22 07:57 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Other pic
Re: One piece oil pan gasket for small block [Re: cudaman1969] #3009783
01/27/22 10:03 PM
01/27/22 10:03 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
So you machined that groove in there?
I thought there was something about the corners of the cap to the block meeting area. Like you had to add angle wedges to make up for difference?
Re: One piece oil pan gasket for small block [Re: autoxcuda] #3009807
01/27/22 10:45 PM
01/27/22 10:45 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Nope, just not a true circle more of an arch. Oil pipe Straight down from the pump (well a little curve) and bigger diameter. Copied a magnum cap.
