Re: Ring compressor 4.373
[Re: Wirenut]
#3009592
01/27/22 01:50 PM
01/27/22 01:50 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
The adjustable aluminum compressors work great too. I just tighten them up until it measures dead on the bore size I'm working with and it'll work just as good as one of the fixed ones. These style compressors will make you throw away the old flimsy metal ones w/ the hose clamp.
[Re: BigDaddy440]
#3009606
01/27/22 02:27 PM
01/27/22 02:27 PM
Posts: 4,693 Wichita
GY3
Wichita
After 20 years with an adjustable ring tool, I just recently started using the tapered ring compressors, I'm impressed. I'm most impressed when I use them right side up Making a mental note... I just bought one for the first time for an upcoming refresh.
[Re: an8sec70cuda]
#3009762
01/27/22 09:02 PM
01/27/22 09:02 PM
Posts: 43,241 Bend,OR USA
Cab_Burge
[quote=an8sec70cuda. These style compressors will make you throw away the old flimsy metal ones w/ the hose clamp. [/quote] I've worn out several different type ring compressors before starting to buy and use the fix tapered ones, sometimes I make bad decisions on tools I should have bought them years ago
