What do you guys use to keep winshield from foggin up #3009242
01/26/22 02:54 PM
01/26/22 02:54 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
When racing in cool/ damp weather.
Last year i left my driver window down a bit, didnt notice, rained. Guess inside of car had moisture. Couldnt see out of car racing that night in cool weather. Pulled the plug. Sucked.
Have had it happen on other occasions too.
What works ?
Have heard everything from Dawn dish soap to buying a hair dryer with 12v plug, and that RainEx doesn't work very well
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: What do you guys use to keep winshield from foggin up [Re: B3422W5] #3009247
01/26/22 03:02 PM
01/26/22 03:02 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Move out west we don't have that issue laugh2
Re: What do you guys use to keep winshield from foggin up [Re: B3422W5] #3009250
01/26/22 03:05 PM
01/26/22 03:05 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Keep in mind that the "fog" is moisture. It cannot be prevented. Any anti-fog coatings merely decrease the surface tension, causing the moisture to form larger globs of water - hence no "fog". The best solution is warm, moving air ... like a defroster !!!
Re: What do you guys use to keep winshield from foggin up [Re: Stanton] #3009252
01/26/22 03:07 PM
01/26/22 03:07 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
All true. And Rain-X does work - just not as people expect it to.
Re: What do you guys use to keep winshield from foggin up [Re: B3422W5] #3009255
01/26/22 03:07 PM
01/26/22 03:07 PM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
Look online there are small 12v RV defrost fan heaters that could be easily used. Another thing my buddy did years ago to his race car. He used 2 marine engine bay bilge fans. Inside the car and duct it out a side 1/4 Lexan window. To pull out burn out smoke and other fumes. Worked really well
Re: What do you guys use to keep winshield from foggin up [Re: B3422W5] #3009331
01/26/22 06:30 PM
01/26/22 06:30 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I just turn the defroster on, the heat comes in handy too. whistling biggrin
Re: What do you guys use to keep winshield from foggin up [Re: justinp61] #3009380
01/26/22 08:04 PM
01/26/22 08:04 PM
birdtracker Offline
birdtracker  Offline
one trick is to burn a candle. I had one that was rather large that worked well. I also have a bus fan mounted on the passenger side to circulate the air. Birdtracker
Re: What do you guys use to keep winshield from foggin up [Re: birdtracker] #3009383
01/26/22 08:13 PM
01/26/22 08:13 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Rains makes a anti fogger. Spray it on wipe off. Stays on your window for weeks. I’ve been using it for years in my street rods works great. Most auto parts sell it.
Re: What do you guys use to keep winshield from foggin up [Re: Dabee] #3009409
01/26/22 09:24 PM
01/26/22 09:24 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Nitrous purge helps a lot
....BAD A$$ STREET CAR.....
Re: What do you guys use to keep winshield from foggin up [Re: Dabee] #3009416
01/26/22 09:33 PM
01/26/22 09:33 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
We have a "fogging up" problem at one of the tracks that I run, especially in the later rounds (after about 9 pm). Not only does the inside fog up, but also the dew falls on the outside, and you can't see out at all with lexan w/s & windows. What I do is to put a small electric heater inside the car, close the door AND cover the w/s & roof with an old blanket. I do this as soon as I get back from a run and leave it there until I'm called back to the lanes. Pretty nice at 2am, 50* outside and damp, to get into a nice warm car that you can see out of. Get back to the staging lanes, and everyone else trying to see where they're going.
Brian
Re: What do you guys use to keep winshield from foggin up [Re: B3422W5] #3009440
01/26/22 10:25 PM
01/26/22 10:25 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Add a real heater and back off the burgers to compensate. Soooo much nicer than ANY alternative
