Angle grinders #3008545
01/24/22 03:07 PM
01/24/22 03:07 PM
Moved to N.E. Tennessee
GomangoCuda Offline OP
Need a new 4 1/2" angle grinder. Prefer with cord. Any suggestions on what to buy or what to avoid. What are you using? Love it or hate it?
Thanks.
Re: Angle grinders [Re: GomangoCuda] #3008560
01/24/22 04:18 PM
01/24/22 04:18 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I have a Hitachi angle grinder that I've had for probably 7-8 years. I don't use it often, but when i use it, I use it hard. It has served me well thus far.
Re: Angle grinders [Re: GomangoCuda] #3008562
01/24/22 04:22 PM
01/24/22 04:22 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Skil.
I've got four set up with four different wheels. I use them constantly and they occasionally accidently get dropped from about 3 feet onto concrete. Of the four on the go, I go through about one per year which means they each last about four years.
Every Christmas these go on sale (in Canada) for $29.95 and I buy one for a spare. If I didn't need it the previous year I obviously don't buy another. They also come with a decent warranty so I sometimes put the spare into service and get a new one on warranty.
I also like where the locking switch is - its not somewhere you'll accidently be hitting it off all the time. They're light and comfortable enough to use with one hand.
You just can't do any better for the price.
Re: Angle grinders [Re: GomangoCuda] #3008570
01/24/22 04:40 PM
01/24/22 04:40 PM
How big of a motor do you need for grinding/cutting steel? I see some grinders with 6 or 7 amp motors and some with 11 amp?
If Doc was here I know where he'd say to buy one. whistling I found out the hard way that you can forget about getting parts for anything they sell. whiney
Re: Angle grinders [Re: GomangoCuda] #3008587
01/24/22 06:20 PM
01/24/22 06:20 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
We beat the heck out of our Makita grinders in the steel mill and I was allowed to bring my tools home when I retired so I’m still beating on it. I have one set up with a cut off wheel and one for grinding
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Angle grinders [Re: DusterKid] #3008645
01/24/22 09:04 PM
01/24/22 09:04 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My Bosch grinders have held up very well, both were bought used many years ago.
Re: Angle grinders [Re: justinp61] #3008654
01/24/22 09:46 PM
01/24/22 09:46 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
I have a Makita I bought over 15 yrs ago. Honestly, I don't use it 8 hrs a day, everyday, but I've used it hard, dropped it more than I care to admit, set it on fire once (my fault, not the grinder blush) , and it got soaked in the rain a couple of times. Still no issues. Never had a problem bumping the switch off either, if anything, the placement has enabled me to turn it off quickly when needed.
shruggy
John
Re: Angle grinders [Re: SattyNoCar] #3008657
01/24/22 09:52 PM
01/24/22 09:52 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
Mikita is reasonably priced and holds up to well.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Angle grinders [Re: BloFish] #3008668
01/24/22 10:31 PM
01/24/22 10:31 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Craftsman Professional tools were nice. Have a grinder & drill for year now.
Both 15+ years old.
But can't vouch for what's being made today.
Re: Angle grinders [Re: GomangoCuda] #3008671
01/24/22 10:40 PM
01/24/22 10:40 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I have a 35 year old Makita, haven't used it a ot in the last 10 or so years but it's been USED!!!
Also have a 5 or so year old Craftsman one that's hardly seen any use if any. Still in the box. PM me if interested. bought it when I had 4 employees, their gone and I'm downsizing wink
Re: Angle grinders [Re: TJP] #3008683
01/24/22 11:37 PM
01/24/22 11:37 PM
I'll take a good look at Makita. At my age I won't wear out any grinder that isn't junk. I hate junk. Thanks for the recommendations. Which style do you like? The long ones have a handle on the end and the short ones you hold around the motor. Is heat an issue with the short ones?
Re: Angle grinders [Re: BloFish] #3008685
01/24/22 11:39 PM
01/24/22 11:39 PM
Superfreak
Superfreak
This^^^^^^
Re: Angle grinders [Re: TJP] #3008691
01/24/22 11:55 PM
01/24/22 11:55 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I used a Dewalt 11 amp in my welding shop, got used every work day before I retired. Sometimes some very heavy duty grinding. The average life was around 5 years in my welding shop, before the cord got killed, or the brushes wore out (you used to be able to get brushes, but it was getting harder to get them 4 years ago). I also can't speak for what they are selling these days.
At the welding shop, the 11 amp motors had a longer life cycle, especially if your doing a lot of grinding. The smaller motors would slow down on rpm the longer they were ran without a stop. The 11 amp grinders are a bit more heavy then the lower amp motored grinders, you use both hands with the 11 amp grinder, but that also gives you more control.
I can also tell you the grinding wheel you are using makes a big difference as well, the cheap wheels put a lot more dust into the air, and they grind away a lot faster then the higher quality grinding wheels do. A higher amp grinder and a good made in the USA wheel will be a different grinding experience then a china grinder with HF grinding wheels. The more you grind, the better you will understand. Gene
Re: Angle grinders [Re: GomangoCuda] #3008693
01/25/22 12:17 AM
01/25/22 12:17 AM
SattyNoCar Offline
SattyNoCar  Offline
I have the short one you hold around the motor. Heat has never been an issue (and I'm in TX).
John
Re: Angle grinders [Re: SattyNoCar] #3008738
01/25/22 09:52 AM
01/25/22 09:52 AM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
I bought a cheap one at Northern Tool for a project. I figured if it wore out after a few uses I would have gotten my money out of it. That was probably 15 years ago and it still works just fine.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: Angle grinders [Re: Soopernaut] #3008746
01/25/22 10:24 AM
01/25/22 10:24 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Dewalt 10.5/11 Amp....about the only thing that holds up in heavy use....Ryobi grinders are pretty good believe it or not....Makita and Milwaukee are last on my list
Re: Angle grinders [Re: DAYCLONA] #3008753
01/25/22 10:36 AM
01/25/22 10:36 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
The biggest pain for me with a side grinder is the switch. Have an old Makita with the "death switch". Decided to change, bought a Metabo. Clumsy to use. My advice, go somewhere that has a number of vendors displayed and try the switches. When you find one YOU like, that's a keeper.
Re: Angle grinders [Re: GomangoCuda] #3008790
01/25/22 11:42 AM
01/25/22 11:42 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Short one, never had a problem of any kind with it.
Re: Angle grinders [Re: 6PakBee] #3008841
01/25/22 01:34 PM
01/25/22 01:34 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Agreed, seems the clown engineers who design these things never used one!, The Dewalt 10.5/11 amp model has the "safety style" paddle switch located down under on the center main body where one would hold it and your fingers are always on it....
Re: Angle grinders [Re: DAYCLONA] #3010180
01/29/22 08:19 AM
01/29/22 08:19 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
We've been getting Dewalts lately for our weld shop where I work. We get the 13 amp I believe so it's like a 6" grinder but we use 4.5" discs. The main welder and the finish laborer can kill the brushes in 5 months! eek All parts are readily available at Ereplacement. The only thing I found I really dislike in ALL brands is the soft start modules / tachometers can go bad and replacements aren't cheap. twocents
