Re: what years had the best transfer cases?Can they be upgraded?
[Re: migsBIG]
#3008069
01/23/22 05:06 AM
01/23/22 05:06 AM
Posts: 19,956 in a cattle trailer down by th...
Guitar Jones
The NP205 t/case is the strongest from a factory. Now if you want ultimate strength then the aftermarket Atlas is the one to get.
I raise chickens, so I am literally a chicken tender.
The Scamp is sold, now just two old trucks and one newer one. '92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#3008121
01/23/22 11:48 AM
01/23/22 11:48 AM
Posts: 8,664 Buford, GA
I_bleed_MOPAR
Buford, GA
 205 is gear-to-gear whereas a 203 is chain-drive. Atlas would be about the top of the line but really overkill for a stock, street-driven truck. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car  )
[Re: migsBIG]
#3008235
01/23/22 04:11 PM
01/23/22 04:11 PM
Posts: 244 Alberta
440_Offroader
Alberta
I have never had a problem with any NP203 transfer cases, but maybe I've been lucky? The last few years (77-79) of the NP203 had a better chain, so that might be an upgrade. I've always liked the AWD of these (all the rage these days), even though everyone seems to want to part time them. If you do change to a different transfer case, I believe the output shaft in the transmission is shorter when coupled to a NP203. You'll need to change the rear shaft in the transmission to hook it up to anything else. A part time transfer case, you'll probably want locking hubs too. That's changing from the knuckles out. So, here's an idea for you. My project truck has a 203/205 doubler transfer case. It uses the NP203 range box, an adapter, and a NP205. This way you don't have to do anything to the transmission, and you get 1:1, 2:1, and a 4:1 ratios. You already have the NP203, so you just need the adapter and a NP205. This combination is only 1/2" longer than a NP203, so you might not even have to modify your driveshaft.
[Re: 440_Offroader]
#3008236
01/23/22 04:16 PM
01/23/22 04:16 PM
Posts: 18,288 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I have never had a problem with any NP203 transfer cases, but maybe I've been lucky? The last few years (77-79) of the NP203 had a better chain, so that might be an upgrade. I've always liked the AWD of these (all the rage these days), even though everyone seems to want to part time them. If you do change to a different transfer case, I believe the output shaft in the transmission is shorter when coupled to a NP203. You'll need to change the rear shaft in the transmission to hook it up to anything else. A part time transfer case, you'll probably want locking hubs too. That's changing from the knuckles out. So, here's an idea for you. My project truck has a 203/205 doubler transfer case. It uses the NP203 range box, an adapter, and a NP205. This way you don't have to do anything to the transmission, and you get 1:1, 2:1, and a 4:1 ratios. You already have the NP203, so you just need the adapter and a NP205. This combination is only 1/2" longer than a NP203, so you might not even have to modify your driveshaft. How can it only be 1/2 inch different. I vision it more. Got any pics of it?
[Re: I_bleed_MOPAR]
#3008324
01/23/22 08:55 PM
01/23/22 08:55 PM
Posts: 14,441 Central Florida
larrymopar360
I'm tired...Very tired.
Central Florida
 205 is gear-to-gear whereas a 203 is chain-drive. Atlas would be about the top of the line but really overkill for a stock, street-driven truck. Tim I LOVE overkill
Facts are stubborn things.
[Re: I_bleed_MOPAR]
#3008337
01/23/22 09:32 PM
01/23/22 09:32 PM
Posts: 21,304 San Jose,CA
migsBIG
San Jose,CA
to be honest, this truck would never be used for off-road or severe use, so if the 203 is upgradeable, I'm fine with that. I don't think I will add jumbo tires on it, probable under 31" all terrain. If there are no real weak spots, then I could assume just freshening it up, maybe a source for a stronger chain, better bearing and such? Appreciate the info.
[Re: NITROUSN]
#3008379
01/23/22 10:52 PM
01/23/22 10:52 PM
Posts: 244 Alberta
440_Offroader
Alberta
I don't have any pictures of the 203/205. The chain case part of the NP203 is pretty big, similar size of the whole NP205. You just have to swap over the gear reduction section, and add the adapter thickness. It may be a little more than 1/2", but it's very minimal. migsBIG, I think a rebuild of your transfer case would be good enough, for your application. They are pretty tough.
[Re: Kern Dog]
#3008499
01/24/22 01:28 PM
01/24/22 01:28 PM
migsBIG
San Jose,CA
[Re: 440_Offroader]
#3008500
01/24/22 01:30 PM
01/24/22 01:30 PM
migsBIG
San Jose,CA
I don't have any pictures of the 203/205. The chain case part of the NP203 is pretty big, similar size of the whole NP205. You just have to swap over the gear reduction section, and add the adapter thickness. It may be a little more than 1/2", but it's very minimal. migsBIG, I think a rebuild of your transfer case would be good enough, for your application. They are pretty tough. Thanks for the info.
[Re: Kern Dog]
#3009615
01/27/22 02:41 PM
01/27/22 02:41 PM
migsBIG
San Jose,CA
I built a jig to support the case in the funky angle that it is in while in the truck. I welded a peg to the bottom so it would fit in a floor jack. A few years ago when I converted my 4 speed Power Wagon to a 727, I used the car lift and transmission jack. I now wish that I kept the 4 speed in it. Check if you can change the shift in the 727 with an appropriate kit that works with the trucks gearing. Alot of automatic car/light truck transmissions get swapped in and that makes for improper shifting. Torque converter could need to be swapped too. I've seen it a dozen different times while helping my buddies at their transmission shops.
[Re: Kern Dog]
#3009847
01/28/22 01:08 AM
01/28/22 01:08 AM
migsBIG
San Jose,CA
