Re: Viscous Fan Clutch
[Re: earlymopar]
#3008110
01/23/22 11:21 AM
01/23/22 11:21 AM
Posts: 12,082 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Long before they go completely out, they get looser at low speed. I have fought some over temp problems in the past that turned out to be the clutch not moving the fan well enough at low engine speed. Consequently, I replace my fan clutch every few years. For the $50 or so, it is cheap insurance.
Having said that, I personally haven't had fan clutches make any real noise as you described. I am not saying that they can't, just that I haven't experienced it myself.
How old is the fan clutch and with the engine off, how tight or loose is the clutch when you move the fan? There certainly should be no fore/aft movement when moving the fan.
Master, again and still
