Is it possible to convert a518 or 46rh to 24 splines? #3007818
01/22/22 12:06 PM
01/22/22 12:06 PM
Montreal PQ, Canada
74_360_Cuda Offline OP
Montreal PQ, Canada
Looking to put an overdrive on my 408 e body 3:91 but I want to keep my externaly balanced flex plate and my beloved
Lupo torque converter. I know that they have made non lock-up a518 for a couple of years but they are hard to find. Is it possible to convert a 46rh ton non lock-up 24 spline input shaft? If so, Is there an existing guideline of what needs to be done and can I re-use parts from my 727? BTW I am not interested in the gear vendor. Thanks.
Re: Is it possible to convert a518 or 46rh to 24 splines? [Re: 74_360_Cuda] #3007822
01/22/22 12:15 PM
01/22/22 12:15 PM
A727Tflite Offline
A727Tflite  Offline
Change the input shaft/rear clutch piston support and reaction shaft support at a minimum.
There are some differences at the back of the input shaft where it mates to the intermediate shaft compared to the 727 so you need to make sure you get a very late 727 for parts or find the 89-93 46RH for parts.
If you can’t find them PM me as I may have what you need.
Re: Is it possible to convert a518 or 46rh to 24 splines? [Re: A727Tflite] #3007832
01/22/22 12:48 PM
01/22/22 12:48 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
if i remember right, 91/92 518's are non lockup.2 wire connector. i know my 91 is for sure. there was a 92 2 wire for sale close to me. not sure what he wanted for it.
Re: Is it possible to convert a518 or 46rh to 24 splines? [Re: trw1982] #3007843
01/22/22 01:11 PM
01/22/22 01:11 PM
moparx Offline
moparx  Offline
a few years back, member Mr. P body [i think ?] did a build where he wanted to use a 727 converter in an A518 that was a lock up.
it was a pretty thorough parts breakdown on what to change out in the A518.
unfortunately, i couldn't begin to tell a guy how to find the thread, or even how many years ago it was.
beer
Re: Is it possible to convert a518 or 46rh to 24 splines? [Re: trw1982] #3007960
01/22/22 07:31 PM
01/22/22 07:31 PM
A727Tflite Offline
A727Tflite  Offline
1993 was the last year for non lockup 46. With the launch of the BR truck we went to lockup.
Re: Is it possible to convert a518 or 46rh to 24 splines? [Re: A727Tflite] #3007979
01/22/22 08:23 PM
01/22/22 08:23 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
And weren’t they diesel only?
Re: Is it possible to convert a518 or 46rh to 24 splines? [Re: A727Tflite] #3007982
01/22/22 08:34 PM
01/22/22 08:34 PM
Montreal PQ, Canada
Montreal PQ, Canada
Thanks, I don't have a 46rh core yet, so you if I understand correctly you are saying that if I find a core from 89-93 it would be more interchangeable with my 727 parts? Not sure of my 727 year but probably arround 1974.
Re: Is it possible to convert a518 or 46rh to 24 splines? [Re: trw1982] #3007983
01/22/22 08:36 PM
01/22/22 08:36 PM
Montreal PQ, Canada
Montreal PQ, Canada
Thanks, Would be interested if it is still for sale but would require shipping to Canada.
Re: Is it possible to convert a518 or 46rh to 24 splines? [Re: moparx] #3007984
01/22/22 08:37 PM
01/22/22 08:37 PM
Montreal PQ, Canada
Montreal PQ, Canada
beer
Thanks, I will make some research
Re: Is it possible to convert a518 or 46rh to 24 splines? [Re: A727Tflite] #3008176
01/23/22 01:37 PM
01/23/22 01:37 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Are you the same "Transman" that writes for the TDR [turbo diesel registry]?
Carl Kessel
Re: Is it possible to convert a518 or 46rh to 24 splines? [Re: CKessel] #3008201
01/23/22 02:31 PM
01/23/22 02:31 PM
A727Tflite Offline
A727Tflite  Offline
No sir. At least I don’t think so.
Re: Is it possible to convert a518 or 46rh to 24 splines? [Re: A727Tflite] #3008246
01/23/22 04:56 PM
01/23/22 04:56 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
After I asked, then I remembered that guy goes by 'Transengineer".
Carl Kessel
Re: Is it possible to convert a518 or 46rh to 24 splines? [Re: CKessel] #3008276
01/23/22 06:35 PM
01/23/22 06:35 PM
A727Tflite Offline
A727Tflite  Offline
Transgender?
That’s definitely not me. confused smile smile
Re: Is it possible to convert a518 or 46rh to 24 splines? [Re: 74_360_Cuda] #3008282
01/23/22 06:59 PM
01/23/22 06:59 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
The core 46rh you are looking for has a dual pin wiring plug. The lockup versions had three pins on the harness. Can't go just by the year.
Re: Is it possible to convert a518 or 46rh to 24 splines? [Re: mgoblue9798] #3008296
01/23/22 07:34 PM
01/23/22 07:34 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The non lock-up units still pop up in the pick-a-part salvage yards. The last one I bought, the yard pulled for $175, all in. After a full rebuild, JV bell conversion, A&A forward manual valve body, and Ultimate Concepts converter, it is behind the Hemi in my Cuda. One of the best things I have ever done. Didn't take any surgery and works great with the Slapstick.
I didn't really consider the GearVendors due to the OD ratio. It is not nearly as advantageous as the 518.
Master, again and still
Re: Is it possible to convert a518 or 46rh to 24 splines? [Re: DaveRS23] #3008478
01/24/22 12:49 PM
01/24/22 12:49 PM
moparx Offline
moparx  Offline
i did the math one time, and all things considered, trans rebuild, driveshaft change, JW bell, converter, for an A518 against the same doings with a 727 with adding a gear vendors unit, and the A518 came out way ahead of the cost of the 727 plus a gear vendors unit.
beer
Re: Is it possible to convert a518 or 46rh to 24 splines? [Re: moparx] #3008557
01/24/22 04:04 PM
01/24/22 04:04 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
beer
AND the GV is .78 & the 46rh is .69 , so far I love the 46rh in my Charger
Re: Is it possible to convert a518 or 46rh to 24 splines? [Re: CSK] #3008939
01/25/22 06:28 PM
01/25/22 06:28 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I have a fresh 46rh I ended up not using. Small block pattern. Come with fresh converter. Monster transmission did the trans.
Abe Lincoln
