Re: anyone using an 8.8 Ford in a B body?
[Re: Mr T2U]
#3009088
01/26/22 08:14 AM
01/26/22 08:14 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
the biggest advantage is the 8 3/4 will use a little less HP to turn over the 8.8 and that really isn't a consideration in this conversation.
Horsepower lost to friction wise, does the Ford 8.8 have design features that make it lower loss than a Ford 9 inch diff?
[Re: 360view]
#3009091
01/26/22 08:36 AM
01/26/22 08:36 AM
Posts: 4,920 new berlin wisconsin
Mr T2U
from what i am told the ring gear/ pinion gear friction is less in the 8 3/4 than in the 8.8.
also the ford 9" is probably one of the worse rears made in pinion / ring gear friction. the biggest advantage and why so many people install it is the strength in both the gears and the large bearings in the axles and ease of changing gears like the 8 3/4. availability of both parts and service techs to repair it and price of the parts is also a consideration of the ford 9".
perception is 90% of reality
[Re: Mr T2U]
#3009412
01/26/22 09:28 PM
01/26/22 09:28 PM
Posts: 1,212 Minn
SportF
Minn
also the ford 9" is probably one of the worse rears made in pinion / ring gear friction. the biggest advantage and why so many people install it is the strength in both the gears and the large bearings in the axles and ease of changing gears like the 8 3/4. availability of both parts and service techs to repair it and price of the parts is also a consideration of the ford 9". I really really wish someone would test the 9" and give us an ACTUAL percentage loss against a few other rears. This "rumor" idea/statement about power loss has never been tested rear for rear, yet this idea just hangs around and around. The magazine that tested rears drove it via the engine and there is so much not scientific about that its hard to believe they actual took the time to do it.
[Re: SportF]
#3009433
01/26/22 10:08 PM
01/26/22 10:08 PM
Posts: 20,176 Park Forest, IL
slantzilla
Park Forest, IL
also the ford 9" is probably one of the worse rears made in pinion / ring gear friction. the biggest advantage and why so many people install it is the strength in both the gears and the large bearings in the axles and ease of changing gears like the 8 3/4. availability of both parts and service techs to repair it and price of the parts is also a consideration of the ford 9". I really really wish someone would test the 9" and give us an ACTUAL percentage loss against a few other rears. This "rumor" idea/statement about power loss has never been tested rear for rear, yet this idea just hangs around and around. The magazine that tested rears drove it via the engine and there is so much not scientific about that its hard to believe they actual took the time to do it. Mark Williams had a display at Indy one year with a 9" setup tied to an electric motor. The purpose was to show how much power it took to accelerate the ring gear through a 1/4 mile run. It was 1/3 hp.
[Re: SportF]
#3009439
01/26/22 10:22 PM
01/26/22 10:22 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
The lower pinion position in relation to the ring gear means more contact but also more drag. If you had a pinion that intersected the ring gear at the 9:00 position instead of well below centerline like all other axles, it would have the least drag, the smallest pinion, the weakest rating and the most noise.
[Re: Kern Dog]
#3009444
01/26/22 10:43 PM
01/26/22 10:43 PM
Posts: 1,212 Minn
SportF
Minn
I realize that, but does that mean 0.002 percent lose, or does it mean 10% loss? See, no one can tell you that, its just the same statement that its a power loss.
Some of the best race advice I got was "If everybody is doing it, its probably a pretty good idea". Well, when you go to the track and look at the cars that are going 5 seconds and faster in the 1/8, there is no dana's down there. None.
So, take a rear, put a load sensor on the input, and a dyno brake on the output and compare them subtracting the bearing preload while you are at it. Then, we'd all know. But, right now, everybody doesn't know (yeah, I said it that way on purpose).
Where is Roadkill garage or some other car show that would do that?
[Re: SportF]
#3009484
01/27/22 06:59 AM
01/27/22 06:59 AM
Posts: 5,812 ohio
ruderunner
ohio
I know a facility that has the equipment to do that. Willingness?
Angry white pureblood male
[Re: ruderunner]
#3009496
01/27/22 07:55 AM
01/27/22 07:55 AM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
The 8.8 out will long outlive an 8.75 when it comes to power. Lots and lots of guys running 8s in the 1/4 on mildly built 8.8s, some manual transmission cars even.
68 Barracuda Formula S 340
[Re: SportF]
#3009500
01/27/22 08:24 AM
01/27/22 08:24 AM
Posts: 8,162 USA
360view
USA
Silly me almost paid for a Quickchange differential to be installed in a 1995 Ram.
$1400 plus $1100 installation about the year 1999.
Quickchange and 9” Ford are cousins, if I remember correctly.
Like an itch ya just gotta scratch, I wanted to know how engine rpm and throttle opening affected vehicle MPG, engine Brake Specific Fuel consumption, and acceleration.
I probably would have done some quarter mile runs with different ratios and 0-60 mph runs at Rockingham.
I could have further amused myself by towing different loads up my favorite steady 4% grade hill.
This might all sound crazy but there is an old SAE paper from a British group that took a vehicle, fitted two Laycock overdrive units in series behind the 5 speed manual transmission, and drove around collecting a huge amount of on road data that they condensed into interesting graphs of speed, engine rpm, manifold vacuum, fuel economy, etc.
The two added gears on the Quickchange diff do add their own increased friction.
[Re: SportF]
#3009622
01/27/22 02:58 PM
01/27/22 02:58 PM
Posts: 6,241 nowhere
Sniper
nowhere
also the ford 9" is probably one of the worse rears made in pinion / ring gear friction. the biggest advantage and why so many people install it is the strength in both the gears and the large bearings in the axles and ease of changing gears like the 8 3/4. availability of both parts and service techs to repair it and price of the parts is also a consideration of the ford 9". I really really wish someone would test the 9" and give us an ACTUAL percentage loss against a few other rears. This "rumor" idea/statement about power loss has never been tested rear for rear, yet this idea just hangs around and around. The magazine that tested rears drove it via the engine and there is so much not scientific about that its hard to believe they actual took the time to do it. Frieberger(?) did that test years ago, D60 vs 12 bolt vs 9". Not sure that article is online though. And Mark Williams claim of a 1/3hp is patently BS.
[Re: 360view]
#3010909
01/31/22 06:12 PM
01/31/22 06:12 PM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
Personally, I find it hard to fork out $500 or more for an 8 3/4 SG center section that is used and my or may not need rebuilding. And (at least to me) forking over $1K or more for a new one is equally hard to swallow. An 8.8 for about $150 or so with 3.73s or 4.10s and a posi is a reasonable alternative. It's not like they were abused in those Exploders. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: I_bleed_MOPAR]
#3011037
02/01/22 08:33 AM
02/01/22 08:33 AM
Posts: 9,835 MI, usa
dvw
MI, usa
The fact that the 9" has more drag is due to the pinion shaft being far below the ring gear centerline. This is also what makes it strong, lots of tooth contact. Power drag isn't enough to worry about unless your trying to run for some type of class record. Dana's have their place. Cheap strong in factory form. Why is everything that is really quick a 9"? Aftermarket support. Tons of parts available. Including center sections designed for 12 bolt Chevy gears. Which have the least drag of nearly any rear axle. A 5 second flat car isn't cheap. So cost generally isn't an issue. But a good 9" isn't cheap. Me? I'm cheap. My car runs well into the 5's. It uses a home built Dana that cost me less than $900 to build. Now a days on the street or general track use? I'd seriously look into the 8.8 Ford for sure. Watch what cars are running them. Plenty of fast stuff. They're modern, plentiful, cheap, disc brakes, factory gear 3.73/4.10. I'd be going to the junkyard if I didn't have 8 3/4 or Dana stuff in the car to start with. Even if you have 8 3/4, the sure grip, gear, and labor exceeds the junkyard cost. of an 8.8. Obviously the spring pads and drive shaft need mods to use an 8.8. But if you didn't have an 8 3/4 you probably needed a better drive shaft anyway. Doug
[Re: Neil]
#3011282
02/01/22 07:40 PM
02/01/22 07:40 PM
Mr T2U
on my 08 mustang i had a 3 link rear suspension. this design doesn't need a pinion snubber.
couldn't tell you where they do this. just thinking maybe you could just bolt the snubber to the floor instead of the axle. the 9" they make a bracket that uses the bolts by the pinion seal to mount it.
[Re: Mr T2U]
#3011313
02/01/22 09:01 PM
02/01/22 09:01 PM
Posts: 5,812 ohio
ruderunner
ohio
A snubber is pretty application specific. Do you have the power and tires to need one? If so, you probably need something stronger than an 8.8 to begin with.
[Re: ruderunner]
#3011318
02/01/22 09:06 PM
02/01/22 09:06 PM
Sniper
nowhere
A snubber is pretty application specific. Do you have the power and tires to need one? If so, you probably need something stronger than an 8.8 to begin with. Oh for crying out loud, the 7 1/4 has a pinion snubber. Let's try to keep the outlandish rhetoric within reasonable bounds.
[Re: Sniper]
#3011664
02/02/22 06:48 PM
02/02/22 06:48 PM
Posts: 5,812 ohio
ruderunner
ohio
Doesn't mean it does anything. They're known to be marginal behind slant sixes.
