Re: Who has broken a cast 440 crank?
[Re: Cab_Burge]
#3007777
01/22/22 07:25 AM
01/22/22 07:25 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Seen a few broken forged cranks, but never a cast one? My mates 70 R/T Charger was driving around with a totally sheared crank. It made a strange rattling noise but seemed OK? I’ve also seen a hemi Barton 572 crank in three pieces too. That didn’t run too good though... But some folks do run cast as they is lighter and are not prone to breakage. Where the limit is, we may never know. Too many steel cranks around for big blocks, unlike Ford guys... If you read about the 360 small block guys, they love ‘em lol... I saw a dropped valve 360 engine that was destroyed and the crank was fine...
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
[Re: lewtot184]
#3007850
01/22/22 01:33 PM
01/22/22 01:33 PM
Posts: 8,241 fredericksburg,va
cudaman1969
fredericksburg,va
i have a friend who was a ford racer and ford steel cranks are rare. He used cast cranks without issue but thought that limiting rpm was the key to longevity. i have noticed that some cast cranks have fillets, which is good, but mopar doesn't. A friends 460 cast crank broke at speed not a pretty sight. Everything, cam, rods, cam journals, the whole center of engine were in small pieces in the oil pan. 69 Mustang running 6.20s all steel, so he was making some heat.
[Re: 69dart]
#3007961
01/22/22 07:34 PM
01/22/22 07:34 PM
Posts: 3,069 Michigan
A727Tflite
So nobody has broken a cast 440 crank? Maybe we had it backwards all along and the cast one is better than the forged one. Using a cast crank just teaches you to tip toe. Plenty of stocker guys using them.
[Re: AndyF]
#3008074
01/23/22 07:44 AM
01/23/22 07:44 AM
Posts: 6,389 nielsville, minn.
quickd100
nielsville, minn.
Mazzolini used to run a cast crank in his Super Stock car just to save some weight. That was a buzz saw of an engine. Personally I wouldn't do it but the NHRA guys are a little crazy. They would sell their mom into slavery for a tenth. Andy you exaggerate a bit there, .05 and their Mothers, sisters, daughters are gone!
[Re: 73DAD]
#3008764
01/25/22 10:56 AM
01/25/22 10:56 AM
Posts: 1,605 westerly, ri. usa
440lebaron
westerly, ri. usa
i will be running a cast crank in my 400 stocker this year, keep you posted, my machine shop has not seen any 400's break stock rods or cranks. i did break a scat 4.15 (offset ground 4.25) in my 540 super gas car (trans brake 5500 rpm)
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: hemienvy]
#3010082
01/28/22 07:44 PM
01/28/22 07:44 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Are they really cast steel or cast iron ? Inquiring minds............. True 100% cast iron is very soft compared to cast steel used for crankshafts. Now if it is a cast Eagle 360 crank it is cast out of playdough.
