hemi oil pan #3006779
01/19/22 01:21 PM
01/19/22 01:21 PM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
hi
need measurement of hemi oil pan 6 qt stock
rear of sump to rear edge and front of sump to front edge, I can notch front cross member, but cannot move center tie rod link, 1975 b body 400 stocker
called milidon, they said would not fit
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: hemi oil pan [Re: 440lebaron] #3006826
01/19/22 03:20 PM
01/19/22 03:20 PM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
'66-'69 or '70-'71?
Re: hemi oil pan [Re: 6PakBee] #3006834
01/19/22 03:25 PM
01/19/22 03:25 PM
!970/1971 was 6 quarts only, the 1966 to 1969 were not 6 quarts tsk
Re: hemi oil pan [Re: 440lebaron] #3006835
01/19/22 03:26 PM
01/19/22 03:26 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Originally Posted by 440lebaron
hi
https://engine-swaps.com/Pages/ProductsType/OilPanSchematics.html
Re: hemi oil pan [Re: CSK] #3006853
01/19/22 04:21 PM
01/19/22 04:21 PM
NC
440Jim Offline
440Jim  Offline
NC
It is hard for me to measure with the engine in the car. Maybe someone can get more exact measurements.
The rear of the sump is angled. About 10" at the bottom, and roughly 9.6" at the height of the steering linkage.
The front is very hard to measure in the car; roughly 4" from the front of the sump at the top, more at bottom of sump.
This is in my Cuda. It was so long ago I don't remember the brand I purchased. But I did add a swinging door to help (a little) with deceleration and oil moving forward.
Hemi_oilpan_baffle1-2.jpgHemiOilPan-inCar (1)label.jpgHemiOilPan-inCar (2)a.jpg
Re: hemi oil pan [Re: 440Jim] #3006858
01/19/22 04:34 PM
01/19/22 04:34 PM
NC
440Jim Offline
440Jim  Offline
NC
FWIW, this is the current Moroso 5qt pan.#20766
Re: hemi oil pan [Re: 440Jim] #3006859
01/19/22 04:42 PM
01/19/22 04:42 PM
NC
440Jim Offline
440Jim  Offline
NC
Re: hemi oil pan [Re: 440Jim] #3006863
01/19/22 05:11 PM
01/19/22 05:11 PM
westerly, ri. usa
westerly, ri. usa
THANKS looks like hemi pan will clear my tie rod, definitely will have to notch k-frame, wix makes a 2 qt filter (1773), maybe can use with stock 5/4 qt pan, would like to get more oil in pan, nhra stocker has to have stock style pan
rule states I can notch crossmember for oil pan removal
Re: hemi oil pan [Re: Cab_Burge] #3006926
01/19/22 07:43 PM
01/19/22 07:43 PM
North Dakota
North Dakota
I guess I'm through asking clarifying questions. wave
Re: hemi oil pan [Re: 440lebaron] #3006928
01/19/22 07:46 PM
01/19/22 07:46 PM
The pan you have looks like the 1966 to 1969 Hemi pan based on how it hangs down below the K member, the Hemi cars and some of the 440 cars had a skid plate welded on them to help prevent those oil pans from dragging and hitting over speed bumps when going fast scope
Look at Summit for their 1970/1971 hemi and six Pack 6-quart oil pans and the stock 3/8-inch RB oil pick up scope The sump is longer and shallower so no need for the skid plate and works really well on street cars, I use them all the time now for any 1966 to 1971 B and E body B, RB or 426 Street Hemi motors I build up
I had one on my old pump gas Duster stoker motor, it ran as fast as 134.+ MPH at 9.993 ET in the 1/4 mile with no oiling issues as long as it had the oil level above the add mark before making a run, if I ran it at one quart low it would start to loose oil pressure about 200 ft after the finish line letting after letting off tsk
Summit oil pan part # G3511, Melling pick up part # 63-S4 scope
Re: hemi oil pan [Re: Cab_Burge] #3006961
01/19/22 08:52 PM
01/19/22 08:52 PM
VA
dragon slayer Offline
VA
down Sorry Cab you are wrong. 66-67 was one pan 5qt. 68 they moved to the 6 Qt pan. 68-9 same pan. 70-71 went to the hemi/6pack 6qt pan. Different shape probably because of sway bar change. But 68-71 are 6 qt pans.
Re: hemi oil pan [Re: dragon slayer] #3007020
01/19/22 10:59 PM
01/19/22 10:59 PM
N
NITROUSN Offline
NITROUSN  Offline
N
So is that considered a 7 quart system? 6 in the pan and one in the filter?
Re: hemi oil pan [Re: NITROUSN] #3007048
01/20/22 12:36 AM
01/20/22 12:36 AM
You call it the way you like up grin
Re: hemi oil pan [Re: dragon slayer] #3007051
01/20/22 12:39 AM
01/20/22 12:39 AM
I'll look in my 1969 Dodge FSM in the morning and see what they said the oil capacity was for the Street Hemi was when it was published: work:
I don't remember ever hearing of a stock street hemi oil pan holding 6 quarts in them until 1970 work
Re: hemi oil pan [Re: Cab_Burge] #3007095
01/20/22 08:45 AM
01/20/22 08:45 AM
VA
VA
Maybe this will help both of you.
Attached PDF document
68 Hemi Dip Stick.pdf (66 downloads)
Re: hemi oil pan [Re: dragon slayer] #3007126
01/20/22 11:00 AM
01/20/22 11:00 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
That settles that, good find.
Joe
Re: hemi oil pan [Re: jlatessa] #3007201
01/20/22 02:05 PM
01/20/22 02:05 PM
My 1969 Dodge service manual does show 6 quarts oil pan capacity, I was WRONG realcrazy blush
Re: hemi oil pan [Re: Cab_Burge] #3007570
01/21/22 12:42 PM
01/21/22 12:42 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
It takes a big man to admit that , Cab.
And a bigger man to admit it on the internet. laugh2
I'm not even exaggerating when I say that you have forgotten more than I know about these things.
