1964 D100 Hot rod truck #2369530
09/12/17 04:47 PM
09/12/17 04:47 PM
Eastern Ontario
shaker340 Offline OP
Eastern Ontario
For my fellow Moparts members, I am near done this truck. More to follow as I finish up some tuning and cosmetic details. Its got a 440 with 727, 3:23 8 3/4 rear, a seven inch drop in front and axle flip in the rear.
Mike
2008 Challenger SRT8
1940 Chrysler Royal coupe
Re: 1964 D100 Hot rod truck [Re: shaker340] #2369574
09/12/17 05:37 PM
09/12/17 05:37 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I bet it rides like a truck. Just kidding it looks great.
Re: 1964 D100 Hot rod truck [Re: shaker340] #2369657
09/12/17 07:44 PM
09/12/17 07:44 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Now how am I supposed to stay focused looking for another motor with you putting up early D100 porn!!! laugh
Those pic's will be stuck in my head for the next 21 days. runaway
Beautiful truck by the way! wave & good luck with the finishing of the build.
PS: If you ever decide to sale, send me a PM. callme popcorn
Re: 1964 D100 Hot rod truck [Re: shaker340] #2369732
09/12/17 10:06 PM
09/12/17 10:06 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
How did you do the 7" drop in the front end? Is the front end still on leaf springs?
Love those dual headlight trucks. Wish Dodge would have kept then through the the 71 version. I had a 66, a 68, and a 70. Gene
Re: 1964 D100 Hot rod truck [Re: shaker340] #2369898
09/13/17 06:09 AM
09/13/17 06:09 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
beautiful!
1981 Dodge D150 360 auto
Re: 1964 D100 Hot rod truck [Re: basketcase] #2369928
09/13/17 09:18 AM
09/13/17 09:18 AM
Eastern Ontario
Eastern Ontario
Poorboy, the front end is a mustang style kit from Rod Weimer. Its a 5 inch drop with 2 inch drop spindles.
Mike
Re: 1964 D100 Hot rod truck [Re: shaker340] #2369930
09/13/17 09:30 AM
09/13/17 09:30 AM
Eastern Ontario
Eastern Ontario
A few more pics of the truck. Note the fuel tank is moved from the cab into the box. I also removed the entire inner liner and built a new frame and floor. I made the tubs to fit the inside of the box sides.
The box is a 1966. I preferred the tail lights than what was on a 64.
Re: 1964 D100 Hot rod truck [Re: shaker340] #2369931
09/13/17 09:31 AM
09/13/17 09:31 AM
Eastern Ontario
Eastern Ontario
And more
Re: 1964 D100 Hot rod truck [Re: shaker340] #2369967
09/13/17 11:06 AM
09/13/17 11:06 AM
E
earlymopar Offline
earlymopar  Offline
E
Nice work and great looking truck. I'm curious about the edge trim on your floor (looks good btw). What are those off of or where did you get them? I have a 65 series 1 (also 4-head light) and it doesn't have edge trim on the OEM rubber mat so I've been thinking of making my own.
- EM
Re: 1964 D100 Hot rod truck [Re: earlymopar] #2369976
09/13/17 11:23 AM
09/13/17 11:23 AM
Eastern Ontario
Eastern Ontario
The carpet trim was made by exline custom auto. They make parts for these sweptline trucks. I have molded carpet in mine.
Mike
Re: 1964 D100 Hot rod truck [Re: shaker340] #2370015
09/13/17 12:19 PM
09/13/17 12:19 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Sweet!
Re: 1964 D100 Hot rod truck [Re: shaker340] #2370071
09/13/17 01:26 PM
09/13/17 01:26 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Are you going to make a finish panel to go in the gas tank opening?
Re: 1964 D100 Hot rod truck [Re: shaker340] #2370098
09/13/17 02:03 PM
09/13/17 02:03 PM
Eastern Ontario
Eastern Ontario
stumpy, yes its the orange panel lying in the bed. It will have some Aluminum diamond plate on it as well as two handles. The floor of the bed and backside of tailgate will be covered in the Aluminum diamond plate too.
Mike
Re: 1964 D100 Hot rod truck [Re: earlymopar] #2370153
09/13/17 03:28 PM
09/13/17 03:28 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
- EM
They were a factory option but it is difficult to find good used ones. As mentioned, Kenny Exline makes aftermarket ones.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: 1964 D100 Hot rod truck [Re: shaker340] #2392843
10/25/17 11:06 AM
10/25/17 11:06 AM
OH
Red383 Offline
Red383  Offline
OH
Originally Posted By shaker340
The carpet trim was made by exline custom auto. They make parts for these sweptline trucks. I have molded carpet in mine.Mike
Where did you get your molded carpet? How did it fit?
Sweet truck!
Re: 1964 D100 Hot rod truck [Re: Red383] #2393274
10/26/17 09:33 AM
10/26/17 09:33 AM
Eastern Ontario
Eastern Ontario
Thanks for kind words. You can get the carpet from here; http://www.stockinteriors.com/AutoCarpet.asp?Itemid=689&MakeId=33&ModelId=160
The fit was very good.
Mike
Re: 1964 D100 Hot rod truck [Re: shaker340] #2393298
10/26/17 10:54 AM
10/26/17 10:54 AM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Beautiful Sweptline & great job on the engine bay! Is your Swepty heater delete? I like how clean your firewall is & I may do the same for my 68 D100 that's almost finished. Also, how do you like the mustang 2 front end & was it hard to install? Mine has a custom 3" lowered I beam front & it may be too low for comfort, so considered the Fatman front end, but its pretty pricey.
Re: 1964 D100 Hot rod truck [Re: Triggerfish] #2393353
10/26/17 12:41 PM
10/26/17 12:41 PM
Eastern Ontario
Eastern Ontario
Triggerfish, thanks for compliments. Yours looks great too. Mine was not a heater delete, I relocated them, take a closer look at the engine bay beside the air cleaner, there are two holes for the heater core. I moved the heater box to be a center mounted, as it looks better on the inside of the cab too.
All of the electronic ignition stuff is under the dash and the starter relay stuff is down low on the frame. I wanted very clean clutter free firewall look.
I used Rod Weimer mustang 2, and it works very nice. Good instructions to install, so was not difficult. A little massaging to make everything work but worth it.
Mike
Re: 1964 D100 Hot rod truck [Re: shaker340] #2393736
10/27/17 09:54 AM
10/27/17 09:54 AM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
Awesome looking little Truck...
Re: 1964 D100 Hot rod truck [Re: shaker340] #3004614
01/12/22 02:45 PM
01/12/22 02:45 PM
Sacramento, Ca
422Cuda Offline
422Cuda  Offline
Sacramento, Ca
Mike
Hey Mike, this front clip looks great and it doesn’t seem like you had to butcher the frame up like the other swaps. Do you have pics of the install process? And what did you have to do to the frame to get it to fit? I just bought my first Swepty and am looking to upgrade the front suspension. Any help alone greatly appreciated.
Thanks,
Matt
