70 440 Main Bearings
#3006701
01/19/22 07:22 AM
01/19/22 07:22 AM
Posts: 601 Mass
charge70
Mass
I'm going to be starting the build on my 70 440.It's a stock rebuild but I have a question about which main bearings to use.I have a set of NOS mains which are 1/2 groove and I have a set of Clevites that are full groove.Which ones would be the best to use? I understand the full oiling verses 1/2 oiling to the rods but is full oiling necessary on a street motor.Thanks,John..
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
Re: 70 440 Main Bearings
[Re: charge70]
#3006703
01/19/22 07:54 AM
01/19/22 07:54 AM
Posts: 6,299 nowhere
Sniper
nowhere
I'm going to be starting the build on my 70 440.It's a stock rebuild but I have a question about which main bearings to use.I have a set of NOS mains which are 1/2 groove and I have a set of Clevites that are full groove.Which ones would be the best to use? I understand the full oiling verses 1/2 oiling to the rods but is full oiling necessary on a street motor.Thanks,John.. Chrysler built over 750,000 440's and who knows how many 413's. How many had full groove oiling? That pretty much answers the question for a street motor.
[Re: Sniper]
#3006715
01/19/22 09:39 AM
01/19/22 09:39 AM
Posts: 2,530 God's Country Maryland
GODSCOUNTRY340
Full groove were designed to use for a race engine seeing a lot of track time. If your car is mainly a street car use the half groove, you'll have better oil pressure, especially if you're running hydraulic lifters.
[Re: charge70]
#3006807
01/19/22 02:14 PM
01/19/22 02:14 PM
Posts: 25,925 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The groove in the bottom bearing shell reduces the bearing surface that takes the most pounding.
[Re: charge70]
#3006825
01/19/22 03:20 PM
01/19/22 03:20 PM
Posts: 43,269 Bend,OR USA
Cab_Burge
Are they the wide groove Hemi bearings or the narrow groove truck bearings? I like and us ethe narrow groove bearings on all my BB builds, I've seen way too many street engines,361,383,413 and 426 street wedges, spin rod bearing due to not oiling the rod bearings all the time
[Re: lewtot184]
#3006923
01/19/22 07:26 PM
01/19/22 07:26 PM
Cab_Burge
i'd use a sealed power 4924 main set. That part number is for RB motors with the single groove in the upper bearing only not full groove for not RB motors The part number for the narrow full groove RB set was SLP 4095M at Summit racing but they discontinue them last year I j looked just (2 minutes ago) now on Summit sight and see they show them available again on special order I think I will order some now
[Re: Cab_Burge]
#3006949
01/19/22 08:22 PM
01/19/22 08:22 PM
Posts: 601 Mass
charge70
Mass
The full groove main bearing set I have is Clevite MS-2324P
