Re: New tunnel ram top [Re: Plymouth340] #3006597
01/18/22 07:40 PM
01/18/22 07:40 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Originally Posted by Plymouth340
Originally Posted by LA360
All the tunnel ram intake tops I've seen have a 3D machined insert that the shear plate fitted on to. They usually just featured a radius to transition from the carb to the plenum.
How many different things are you going to try? A sharp edge, versus a radius or taper on the plenum side below the carb? Plenum spacers?
I made this for a friend in 2014, I am still waiting for it to be tested (the customer had some personal issues). No idea if it was good, bad or otherwise.
Alan Jones
Re: New tunnel ram top [Re: LA360] #3006598
01/18/22 07:41 PM
01/18/22 07:41 PM
LA360 Offline
LA360  Offline
This is the top finished on an Indy intake
Alan Jones
Re: New tunnel ram top [Re: LA360] #3006781
01/19/22 01:23 PM
01/19/22 01:23 PM
moparx Online content
moparx  Online Content
nice work LA. up
beer
Re: New tunnel ram top [Re: Cab_Burge] #3056246
07/05/22 01:06 PM
07/05/22 01:06 PM
CEDAR RAPIDS
Plymouth340 Offline OP
CEDAR RAPIDS
[quote=Cab_Burge]Try it and let us know your results wrench :up
Good luck, it looks really good bow up [/quot
\ It picked up a tenth in 1/4 .......8.90 @ 153
Re: New tunnel ram top [Re: Plymouth340] #3056416
07/05/22 05:51 PM
07/05/22 05:51 PM
\ It picked up a tenth in 1/4 .......8.90 @ 153 bow up Thanks for sharing that information!
Re: New tunnel ram top [Re: Cab_Burge] #3056420
07/05/22 05:58 PM
07/05/22 05:58 PM
Chesterfield Twp. Mi.
John Burdine Offline
a tenth at that level is nothing to sneeze at.
Re: New tunnel ram top [Re: John Burdine] #3056472
07/05/22 09:17 PM
07/05/22 09:17 PM
CEDAR RAPIDS
CEDAR RAPIDS
ya very happy with the APD Carbs.....never had to touch them out of the box
Re: New tunnel ram top [Re: Plymouth340] #3056555
07/06/22 08:58 AM
07/06/22 08:58 AM
Shelby Twp. Mi
HardcoreB Online content
HardcoreB  Online Content
Shelby Twp. Mi
Nice! Can you give us some details of the car/engine? What were your incrementals? At 153 MPH there's probably more ET in it too!
Re: New tunnel ram top [Re: HardcoreB] #3056655
07/06/22 12:45 PM
07/06/22 12:45 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
So there were more changes than just the top of the manifold?
We made these tapered plates for tunnel ram set ups last year. Did a little testing on the Stratus and saw some improvement but did not have time to fully flog on them. Maybe on the dyno one day.
Re: New tunnel ram top [Re: LA360] #3056831
07/06/22 05:55 PM
07/06/22 05:55 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
If I could buy a top like that, I would probably go with an Indy TR....
Re: New tunnel ram top [Re: Dragula] #3057302
07/07/22 10:42 PM
07/07/22 10:42 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Do the shear plates have the ribbing to shear off the fuel from the walls?
It appears the anti-reversion plates have a trough around the openings to reverse the direction of flow.
The other ones posted look like a diffuser style with a tapered opening. A pressure recovery like the downside of a venturi.
Does that summarize the differences?
Floyd Lippencott IV
Re: New tunnel ram top [Re: mr_340] #3058043
07/10/22 07:57 PM
07/10/22 07:57 PM
LA360 Offline
LA360  Offline
I don't know exactly as to what is going on, whether a boundary layer is being created or whatever. Some spacers will have a smooth tapered surface, others are machined with steps. Everyone has a different way of thinking. In many cases, I believe it comes down to what might be easy to machine, or as silly as it sounds, what is visially appealing to the purchaser.
"It appears the anti-reversion plates have a trough around the openings to reverse the direction of flow."
Most that you see will have that trough or groove that you are refering too. I have been meaning to test without it, or adding a pocket instead
I think Darin Morgan described them best, by refering to them as transition spacers. A means of transitioning from the carb to the manifold
Alan Jones
Re: New tunnel ram top [Re: Al_Alguire] #3058738
07/12/22 11:36 PM
07/12/22 11:36 PM
CEDAR RAPIDS
CEDAR RAPIDS
No
Re: New tunnel ram top [Re: Plymouth340] #3058896
07/13/22 01:40 PM
07/13/22 01:40 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Cool, just saw a reference to some APD carbs too.
