Newby seeks Mopar guru wisdom re. elusive misfire
#300639
04/26/09 11:57 PM
04/26/09 11:57 PM
Posts: 34 Highland, CA
Mosin
Highland, CA
Greetings All, I have been going simultaneously broke and insane trying to diagnose a misfire between 3000-3500 RPM on my 440-3. The 440 is powering a restored '76 Winnebago Brave ("Pandora" - photo atached) which had a complete engine rebuild last year/~12K miles ago. At that time the stock carb and ignition were replaced with the aftermarket components listed below (MSD, Edelbrock etc). It all ran brilliantly until a few months ago when I began to notice this misfire. Ever since I have been in diagnosis hell. I have obtained about as much info and assistance as the engine builder and the MSD techs can provide, and spent countless hours over the past month trying out different theories, settings, and configurations by trial and error. Most recently MSD sent me a new dizzy under warranty, thinking that was the culprit, but I installed it last week and the misfire still persists. More on the condition: It is a smooth, almost rev-limiter feeling misfire that occurs only under a load between ~3000-3500 RPM. It isn't constant or exact, as sometime the misfire won't begin until ~3500, while other times I can sense it as low as ~3000. The engine starts and idles perfectly, and pulls smooth and strong up to the point of misfire. Here are the relevant engine and component specs: 440-3 w/ 12K low-RPM motorhome miles since stock rebuild with rv cam grind. Edelbrock #1411 750cfm (calibrated up to #1407 750cfm specs.. I am 99.9% sure carb/fuel issue/s have nothing to do with this after trying several different compensatory carb configs/adjustments...larger mains/secs/needles/seats, stronger step-up springs, etc. No difference) Edelbrock Performer 440 intake Hedman Elite Headers/Flowmaster 50 Accel 0576S shorty plugs @ .040 (same result with fresh Champion RV12YC @ .035) MSD PB/RTR Dizzy #8387 (Second one. 99.9% sure it's not the dizzy) MSD 8.5mm wires w/ 90 deg boots (om out perfectly @~40-50/ft. This is the second new diagnostic set… it is not the wires or boots) MSD Blaster 2 #8202 (second one... threw still more money at the problem and now I have a spare... it isn't the coil) MSD 6AL (MOPAR version #P4876728) no rev pill. The same condition happens witout the 6AL box, so it isn't the 6AL box or wiring: all of MSD's rules for power, ground, and EMI separation have been followed religiously. I sum, I have no idea where to go from here. I'm thinking perhaps weak or broken valve spring/s or a cam issue or timing chain/assy/gears, but I have no reason to suspect these beyond lack of any other possible explanation. Based on the above description of the misfire, can we rule any of these in or out? If it is something mechanical like springs I am going to need genuine Mopar guru assistance. I am in Southern California (Inland Empire) if anyone has any references/leads. TIA for any responses! Mosin
Re: FNG seeks Mopar guru wisdom re. elusive misfire
[Re: Mosin]
#300640
04/27/09 12:08 AM
04/27/09 12:08 AM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
Sounds like a vaccum leak,possibly intake gasket leak. Try running an unlit propane torch around the intake to head mating surface. Are the power brakes working normally? Above 3500rpm or under heavy acceleration the miss is not notacable?
[Re: Mosin]
#300641
04/27/09 12:13 AM
04/27/09 12:13 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Had a similar situation a few years back with a 440 in a motorhome, after isolating it to one cylinder found that while a cranking compression test showed the cylinder within 10% of the others a leakdown test showed 30% leakage on that cylinder throught the exhaust valve... pulled that head & had it repaired by the machine shop...fired it up & the engine ran great... for another 4k miles than it started losing the same cylinder, leakage tested at around 18%, pulled the head again & I was there when the machist tried touching up the seat.. it had a low area, that once the seat was cut sealed well by when inspected with a magnifing glass looked "odd/off" found that the factory induction hardened valve seat apparently was very thin & when it was cut left an area of soft cast iron exposed...Installed a hardened seat & it's been fine ever since...
BTW click on the flashing envelope at the top of your screen...
Re: Newby seeks Mopar guru wisdom re. elusive misfire
[Re: goldmember]
#300642
04/27/09 12:26 AM
04/27/09 12:26 AM
Mosin
Highland, CA
Thanks! Will do. Would MAPP gas serve the same purpose? If so, assuming I am trying this at idle, what should I be looking for to denote a leak? (i.e. stutter, backfire, explosion? )
The brakes seem to be working fine and not leaking vacuum as far as I can tell. I will triple check tomorrow.
Sorry if that wasn't clear: the misfire is only noticeable under load. In park it will rev straight up to 3500 every time with no misfire. As a Mopar newby I have ben afraid to rev it past that point out of gear, and consider 4K a redline while driving... usually cruising at around ~3300 RPM. Thus, 3500-3600 RPM IS a heavy load on this rig... like ~75 MPH on a straightaway or peak of a hill climb. And this is why the problem is driving me insane. Here I have this epic rig (you wouldn't believe how much time and $ I have invested in this breadbox) and I can't break 55 MPH on the freeway (3000 RPM) witout it breaking up!!
[Re: 1_WILD_RT]
#300643
04/27/09 12:39 AM
04/27/09 12:39 AM
Mosin
Highland, CA
Had a similar situation a few years back with a 440 in a motorhome.......Installed a hardened seat & it's been fine ever since.
Thanks for the insight/tip. I was fearing a compression test was next if external parts (or vacuum as per the above) weren't the source of the problem... and I am interpreting that a leakdown would be in order as well? I'm going to need Mopar guru intervention if this is the case. I'm learning and amassing parts and tools quickly, but not that quickly.
[Re: Mosin]
#300644
04/27/09 12:45 AM
04/27/09 12:45 AM
goldmember
Gainesville,FL
I guess my reading comp tonight is of a 1st grader.LOL Lots of things could be the problem,but the vaccum leak I'd doubt now that I read more carefully. It very well could be valvetrain related,weak or broken valvespring would be possible. You could drive it at the missfire point for several miles and pull the plugs checking them to find the cylinder with the problem.Leakdown testing might also reveal the troubled cylinder.Using a propane torch to locate a vaccum leak will cause the idle speed to pick up rpm as the leak is passed over,no explosions needed.
[Re: goldmember]
#300645
04/27/09 01:18 AM
04/27/09 01:18 AM
Posts: 10,304 Someplace you aren't
SomeCarGuy
Long shot- Looks like #5 and #7 plug wires are close or touching right as they leave the dizzy.
I want my fair share
[Re: SomeCarGuy]
#300647
04/27/09 01:46 AM
04/27/09 01:46 AM
Mosin
Highland, CA
Long shot-
I have been vexing about the wire paths for weeks, trying as many different adjustments as I can think of. #5 and #7 aren't touching but they are indeed close... on the same separator like an inch away at one point. Actually since those photos were taken a few days ago I bought and mounted a third set of new MSD wires (black MSD Streetfires to save a little $ this time) just to make absolutely sure it wasn't the wires. Aditional separators have been added as well. No difference. With that said, I ran basically the same path, so I will try to totally reroute #5 and #7 and see what happens.
[Re: Mosin]
#300650
04/27/09 07:12 AM
04/27/09 07:12 AM
Posts: 531 Virginia
JimG
Virginia
Just a wild shot here, but I have seen camshafts with a wiped lobe create a symptom similar to what you describe. Perhaps the others here can elaborate on whether they agree if this could be the culprit. To test for this, a dial indicator (on a magnetic base) would be used to check the lift of each valve while rotating the engine by hand. Good luck. Cool retro motorhome, BTW! You see 45' Prevosts every day, but not 70's Winnebagos! Jim
[Re: JimG]
#300651
04/27/09 07:37 AM
04/27/09 07:37 AM
RapidRobert
In this order I would #1 advance the initial timing 5-10 degrees from where it is now & take her out then retard it 5-10 degrees from where it was originally & try it(rotor phasing). #2 I would hook a can of gas to the pump inlet & take it out.(fuel starvation) #3 I would do a compression and especially a leakdown test(as mentioned). and what is your initial timing at?
[Re: Mosin]
#300654
04/27/09 09:58 AM
04/27/09 09:58 AM
Posts: 2,022 s. e. pa.
calrobb2000
s. e. pa.
hi the 750 edel carbs are knowen to have some issues,might try a holley . week fuel psi under load install a fuell psi gauge and drive 4lbs minium under load 7 psi max at idle . week valvespring ? bad cam lobe , remove valvecovers and watch for i valve not moving as much as others at idle, of its kind intakes should all move app same amount also all ex same amount ? partialy cloged fuell filter , restricting flow at speed ? bent pushrod ? bad fuel pump pushrod , there are some defective ones out there wearing short early . fuel pump cam lobe woren off ?
[Re: Mosin]
#300655
04/27/09 10:19 AM
04/27/09 10:19 AM
calrobb2000
s. e. pa.
hi 750 edes have problems sometimes try a holley ? badd ignition switch , bypass it and test ? fuel filter partialy cloged restricting flow , install a psi gauge ,and drive 4lb min 7 lb max ! bad cam lobe , remove valve covers start and watch for movement on all similar distance ? bent pushrod ? weak valvespring ? badd fuelpump pushrod ,woren off there are some soft ones out there ? bad fuel pump cam lobe ?
[Re: calrobb2000]
#300656
04/27/09 11:32 AM
04/27/09 11:32 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Did they install a NEW oil pump drive or re-use it on a new bushing? What about the fuel pump push rod? I've had bad distributor drives do that at different RPMS. Pull the distributor and using a large flat blade screwdriver, try and wiggle the oil pump drive side to side and back and forth while it's installed. If it moves at all, replace it and the bushing.
[Re: moper]
#300657
04/27/09 05:14 PM
04/27/09 05:14 PM
Posts: 11,786 Portage,michigan
B3422W5
Portage,michigan
Hi..
I doubt seriously its the routing on the plug wires. I can lterally wrap my MSD wires together and no miss at 7500rpm in my race car.
Cant see it being mechanical, a valve spring doesnt know if its undfer load or not, all it knows is RPM,right?..If you can rev it in neutral, and no misfire i would think its got to be spark or fuel related.
my first thought would have been the 6al, but you SEEM to have eliminated that.
My second thought would be fuel pump,filter,or some sort of undervoltage issue
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: moper]
#300658
04/27/09 05:30 PM
04/27/09 05:30 PM
Mosin
Highland, CA
I can't thank you guys enough for the responses. Prioritizing from the simplest to the most complex, I am formulating my next offensive in Operation Mopar Misfire. Re. FUEL: Many great points above that got me thinking about the system from tank to intake. I have noticed that after the engine warms up the fuel press drops from ~6.5 to around 4 or fluctuates therein, but I read in a few places that this was a common effect of the gauge heating up. (?) I will run from a gas can to eliminate the tanks and dual-tank switch (it's original, and might be only opening/switching partially?), bypass my Holley press regulator, and flow straight to the carb. And speaking of the carb, I neglected to mention the carb history, since I didn't think it was relevant before. In short, I drove the first ~11K miles on this engine with an Eddy AVS 650, which gave great gas mileage, but always produced a lean stumble off idle. When I swapped the AVS 650 (#1806) out for the Performer 750 (#1411) the condition improved somewhat, but the stumble was still noticeable. Then I saw that the #1411 is jetted way lean compared to the non-electric choke #1407, so I matched the 1407 main rods/jets, went up to .110 secondaries (from .107) and the thing ran like a bat out of hell. I don't remember any 3000-3500 misfires immediately after making this swap and adjustments, but they definitely began soon after. So, if the steps to eliminate fuel pressure/flow to the carb don't work, I am going to throw on the AVS 650 again and see if that changes the condition. I will also check the dist. drive gear, and do a propane test around the intake. I will do this all sequentially (probably these two first, then the fuel/carb) and take good notes. I might even strap a vid cam to the passenger seat so I don't crash watching the fuel press gauge. If those steps don't produce any results, I will go back to my #1411/750cfm and ponder the tools and time I will need to learn how to do comp and leakdown tests OR locate a Mopar specialist in SoCal that is willing to lay hands on Pandora. Does anyone know of such a shop/individual? Many thanks again!
