Page 1 of 4 1 2 3 4
Are all 6 pack cams low taper design? #3006033
01/16/22 08:48 PM
01/16/22 08:48 PM
New York
R/T1968R/T Offline OP
New York
Was it just the 69 single bolt type that was low taper or all 69-71s? I have a 3 bolt 6 pack cam from 1970, wondering what lifters I should use. Or use the core and get it reground.
Re: Are all 6 pack cams low taper design? [Re: R/T1968R/T] #3006046
01/16/22 09:10 PM
01/16/22 09:10 PM
I'm pretty sure all the street hemi and race hemi cams where low taper also, not sure about the six pack cams in 1970/1971 confused
Re: Are all 6 pack cams low taper design? [Re: R/T1968R/T] #3006047
01/16/22 09:11 PM
01/16/22 09:11 PM
What are you going to do about the lifters ?
Re: Are all 6 pack cams low taper design? [Re: Cab_Burge] #3006052
01/16/22 09:22 PM
01/16/22 09:22 PM
New York
New York
Well if its low taper Im out of luck...Maybe have it reground.
Re: Are all 6 pack cams low taper design? [Re: R/T1968R/T] #3006057
01/16/22 09:29 PM
01/16/22 09:29 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Iirr the 69 was just a regular 440 with the 6 barrel intake and carbs. 70 was when all the internal changes came.
Re: Are all 6 pack cams low taper design? [Re: R/T1968R/T] #3006058
01/16/22 09:29 PM
01/16/22 09:29 PM
I'm not sure how much angle on the lifter bottoms there are between stock and low taper confused
Not sure how to measure them either realcrazy
i have had several sets of the early (Pre 1968) Mopar solid Hemi lifters reconditioned by a company in Seatle, WA work
Maybe you can have yours done too locally scope
Re: Are all 6 pack cams low taper design? [Re: Cab_Burge] #3006079
01/16/22 10:55 PM
01/16/22 10:55 PM
A727Tflite Offline
A727Tflite  Offline
I think the low taper was a 21” radius while the standard was 18”. But it’s been a long time.
Re: Are all 6 pack cams low taper design? [Re: A727Tflite] #3006108
01/17/22 12:53 AM
01/17/22 12:53 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Here is the '69 TSB. Note the comments for the camshaft and the tappets.
Re: Are all 6 pack cams low taper design? [Re: 6PakBee] #3006445
01/18/22 10:34 AM
01/18/22 10:34 AM
God's Country Maryland
GODSCOUNTRY340 Offline
What's the reason for low taper design?
Re: Are all 6 pack cams low taper design? [Re: GODSCOUNTRY340] #3006454
01/18/22 11:09 AM
01/18/22 11:09 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Okay, I am going from memory so take this all with a bag of salt. The standard 440 valve gear was good for about 5800 rpm. Chrysler wanted to raise this to about 6200 rpm. So they installed heavier springs on the Six-Pack motors. Heavier spring...more cam load....a low taper lobe provides more contact area and maintains engine durability with the higher loading. Again, I'm going from memory and I only have two functioning brain cells left.
Re: Are all 6 pack cams low taper design? [Re: 6PakBee] #3006456
01/18/22 11:15 AM
01/18/22 11:15 AM
Kirkland, Washington
Pacnorthcuda Offline
That’s really interesting. Two things come to mind..
1) By what criteria were the crankshafts “selected”?
2) Magnafluxing rods…did they scrap those that failed, or were they used in 440-4 motors?
Not to get off topic here…
Re: Are all 6 pack cams low taper design? [Re: 6PakBee] #3006457
01/18/22 11:16 AM
01/18/22 11:16 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
If yours are gone, mine are too. It was also the rationale for the HD rocker arms which Direct Connection later claimed they'd reinforced the wrong end, FWTW.
From this thread I assume low taper lifters are made of unobtainium? Which would make an NOS 6 pack camshaft a paper weight?
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Are all 6 pack cams low taper design? [Re: 6PakBee] #3006473
01/18/22 11:51 AM
01/18/22 11:51 AM
A727Tflite Offline
A727Tflite  Offline
Correct. And made of the standard material. I believe they had a slightly unique oil band for some reason, and I think a better retaining ring. I have some, I’ll post a pic when I find them.
Re: Are all 6 pack cams low taper design? [Re: A727Tflite] #3006519
01/18/22 01:25 PM
01/18/22 01:25 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I purchased an A12 new in 69, my good friend was the salesman for a MOPAR dealer in Ohio.
He specialized in Hi-Po stuff then as it was a moneymaker for him and the dealer.
I remember reading the notice posted above from Chrysler when it was published, but some of the other mods others have posted are not in my memory.
Not saying they couldn't be true, but........
Joe
PS, I just turned 80 last month so I'm among the old fart gang LOL
Re: Are all 6 pack cams low taper design? [Re: jlatessa] #3006547
01/18/22 02:23 PM
01/18/22 02:23 PM
moparx Offline
moparx  Offline
Joe, hurry up and get a pad and pencil out, start writing stuff down before you forget, or the cobwebs take control like they have of me ! laugh2
beer
Re: Are all 6 pack cams low taper design? [Re: moparx] #3006556
01/18/22 03:11 PM
01/18/22 03:11 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Back in around 1978 I bought everything I could for a 1970-71 440 Six Pack. I owned two A12 69 Runners then and nothing was available for that motor around that time. I got this for a 1970 motor from the Dealership I use to spend most of my paycheck at. Crank, Rods, Piston, Rockers, Cam Shaft lifters, timing chain and lots of small parts. Bearings I bought at the local speed shop. I also bought rocker shafts but do not remember is they were Six Pack specific from the dealer. All this was still available at the Dealer. Built the motor myself and decided to sell it to a guy that had a 1970 440-6 Cuda. He finally only wanted the short block. I took the intake carbs, cam lifters, rockers, heads and valve cover off the motor and still have all that. I always thought the Six Pack Lifters were still available in places maybe not the dealership. I guess I have a lot of Scrap metal the way people have posted but I will like build another motor and put it in my Challenger Convertible.
1971 HEMI E BODY REGISTRY
Re: Are all 6 pack cams low taper design? [Re: hemicar1971] #3006568
01/18/22 04:44 PM
01/18/22 04:44 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i think any wedge that came with street hemi valve springs used the low taper lobe. the street hemi spring was a high rate spring and significantly stiffer than a hipo wedge spring. i believe all this is 6pak specific.
Re: Are all 6 pack cams low taper design? [Re: lewtot184] #3006596
01/18/22 07:37 PM
01/18/22 07:37 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I've never seen any reference that stock B or RB engines in any configuration used a Hemi valve spring. shruggy
Re: Are all 6 pack cams low taper design? [Re: 6PakBee] #3006611
01/18/22 09:10 PM
01/18/22 09:10 PM
work iagree up
I use to race in NHRA stock classes, the first year we won our class(A/SA) at the Winternationals we had to remove one the cylinder head to allow the tech guys to measure the CC and valve spring pressures on the bench. The next year they allow any valve springs you wanted to use as long as your valves didn't open any more than their specs for your motor wrench
The stock 1968 and 1970 street hemi valve springs had right at 125 lbs. on the seats and 325 Lbs. open at .484 valve opening on the intakes and I think right at .446 on the exhaust valves, maybe a tiny bit more or less. work
Re: Are all 6 pack cams low taper design? [Re: Cab_Burge] #3006618
01/18/22 10:03 PM
01/18/22 10:03 PM
fredericksburg,va
fredericksburg,va
Flat faced lifters.. goes against saying lifters have to have a crown don’t it.
Page 1 of 4 1 2 3 4
