Re: cam button
[Re: mopar dave]
#3005914
01/16/22 12:48 PM
01/16/22 12:48 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
None or nylon. Plenty of debate. The cam “shouldn’t” move forward
Re: cam button
[Re: B3422W5]
#3005916
01/16/22 12:52 PM
01/16/22 12:52 PM
Posts: 4,694 Wichita
GY3
Wichita
I use the Comp Cams nylon one. You'll have to carve on it a little to get the fitment correct but it works great.
Re: cam button
[Re: mopar dave]
#3005926
01/16/22 01:21 PM
01/16/22 01:21 PM
B3422W5
Portage,michigan
Read on another thread Keith Black never used them building engines.
Re: cam button
[Re: B3422W5]
#3006030
01/16/22 08:40 PM
01/16/22 08:40 PM
Posts: 43,262 Bend,OR USA
Cab_Burge
None or nylon. Plenty of debate. The cam “shouldn’t” move forward it won't with standard flat tappet lifters It can and will with rollers lifters
Re: cam button
[Re: mopar dave]
#3006054
01/16/22 09:25 PM
01/16/22 09:25 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
What holds the cam button in? Is it a press fit? the button sits in the recess between the 3 bolts, it can't fall out once the cover is bolted on. Should have .005-,010 clearance. Joe
Without Data, you’re just another guy with an opinion.
Re: cam button
[Re: B3422W5]
#3006244
01/17/22 04:01 PM
01/17/22 04:01 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
Here is a thread I was involved in.......post 59 and 60 may be of some interest.... Cam buttons
Re: cam button
[Re: B3422W5]
#3006409
01/18/22 05:53 AM
01/18/22 05:53 AM
Posts: 4,741 Moved to N.E. Tennessee
GomangoCuda
All of the Hemi engines they built probably had a mechanical fuel injection pump driven by the gear drive. The hub for driving the pump was bolted onto the cam gear right where you would put a cam button. Iirc there were shims between that hub and the round cover to control cam thrust. Therefore a traditional cam button was not only impossible but also unneeded. The pump drive and gear drive cover served the same purpose. I have not had one of these apart for 45 years so I may have missed some detail but you get the drift. Injected engines would not/could not use a traditional cam button and didn't need one. Everybody else does.
