cam button #3005872
01/16/22 11:41 AM
01/16/22 11:41 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Just installed a roller cam in my 511 and using a stock chain cover. Which cam button should i use?
Re: cam button [Re: mopar dave] #3005914
01/16/22 12:48 PM
01/16/22 12:48 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
None or nylon. Plenty of debate.
The cam “shouldn’t” move forward
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: cam button [Re: B3422W5] #3005916
01/16/22 12:52 PM
01/16/22 12:52 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I use the Comp Cams nylon one. You'll have to carve on it a little to get the fitment correct but it works great.
'63 Dodge 330
11.19 @ 121 mph
Re: cam button [Re: B3422W5] #3005924
01/16/22 01:13 PM
01/16/22 01:13 PM
Mt Morris Michigan
Mt Morris Michigan
Didn't know you could go without on a BB with Roller. I guess the chain would hold it from moving.
Re: cam button [Re: mopar dave] #3005926
01/16/22 01:21 PM
01/16/22 01:21 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Read on another thread Keith Black never used them building engines.
1.41 best 60 foot
6.56 at 104.17
Re: cam button [Re: B3422W5] #3005949
01/16/22 02:19 PM
01/16/22 02:19 PM
Mt Morris Michigan
Mt Morris Michigan
Thats interesting to know. Thanks
Re: cam button [Re: mopar dave] #3005996
01/16/22 06:24 PM
01/16/22 06:24 PM
birdtracker Offline
birdtracker  Offline
I used Comp chain and button in mine. There is a slight witness mark on the inside of my steel cover. Birdtracker
Re: cam button [Re: B3422W5] #3006030
01/16/22 08:40 PM
01/16/22 08:40 PM
it won't with standard flat tappet lifters up
It can and will with rollers lifters whiney scope
Re: cam button [Re: Cab_Burge] #3006048
01/16/22 09:13 PM
01/16/22 09:13 PM
Mt Morris Michigan
Mt Morris Michigan
What holds the cam button in? Is it a press fit?
Re: cam button [Re: mopar dave] #3006054
01/16/22 09:25 PM
01/16/22 09:25 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
the button sits in the recess between the 3 bolts, it can't fall out once the cover is bolted on. Should have .005-,010 clearance.
Joe
Without Data, you’re just another guy with an opinion.
Re: cam button [Re: mopar dave] #3006062
01/16/22 09:37 PM
01/16/22 09:37 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Resistance from cam turning the oil pump drive moves cam backward
Re: cam button [Re: cudaman1969] #3006066
01/16/22 09:42 PM
01/16/22 09:42 PM
up iagree
Re: cam button [Re: B3422W5] #3006244
01/17/22 04:01 PM
01/17/22 04:01 PM
Idaho
LaRoy Engines Offline
Idaho
Here is a thread I was involved in.......post 59 and 60 may be of some interest....Cam buttons
Re: cam button [Re: mopar dave] #3006290
01/17/22 07:08 PM
01/17/22 07:08 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I just turn oout a button out of aluminum on my lathe, that fits, seems like everyone I buy for a mopar does not fit right, or is the length is wrong. And I never tried it on a mopar, but I know for a fact that on small block chevy's and ford's if you leave out the thrust button on a roller, major engine damage does happen, fixed a couple in my time.
Re: cam button [Re: cudaman1969] #3006303
01/17/22 08:20 PM
01/17/22 08:20 PM
Mt Morris Michigan
Mt Morris Michigan
Yes, i used to run small blocks. They have a cam plate that limits cam movement. Big Blocks don't have that. I measured the center hole in the cam gear. It measures .736", will i need a special button to fit?
Re: cam button [Re: mopar dave] #3006386
01/18/22 02:41 AM
01/18/22 02:41 AM
BigFish69 Offline
BigFish69  Offline
mancini has them that you can shim the button to your clearance
Re: cam button [Re: B3422W5] #3006409
01/18/22 05:53 AM
01/18/22 05:53 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
All of the Hemi engines they built probably had a mechanical fuel injection pump driven by the gear drive. The hub for driving the pump was bolted onto the cam gear right where you would put a cam button. Iirc there were shims between that hub and the round cover to control cam thrust. Therefore a traditional cam button was not only impossible but also unneeded. The pump drive and gear drive cover served the same purpose.
I have not had one of these apart for 45 years so I may have missed some detail but you get the drift. Injected engines would not/could not use a traditional cam button and didn't need one. Everybody else does.
Re: cam button [Re: BigFish69] #3006426
01/18/22 09:16 AM
01/18/22 09:16 AM
Mt Morris Michigan
Mt Morris Michigan
I found a few things over at Hughes Engines as well. Thanks
