So, Im guessing the longitudinal stripe would NOT cover these pins / holes if removed???
Pins are spot welded, you'll need to grind them off, as well as fill the holes in the door corners, IIRC when I removed them from my Challenger, there's 2 holes on the doors at each end, one hole at the end of the rear qtr, and one hole at the fender in the front jamb area, along with dozens of stinking pins.... chances of the longitudinal stripe covering your pin/hole removal 50/50?, IMHO I think the pins/holes will fall right between the upper void between the upper border stripe and the middle longitudinal I assume your trying to avoid paint work?
Mike
