1970 Challenger RT/SE ???? #3005375
01/14/22 09:54 PM
01/14/22 09:54 PM
It's a dry heat
gtx6970 Online content OP
gtx6970  Online Content OP
It's a dry heat
On a 1970 Challenger
if equipped are the body side moldings stick / glue on .
Or do they have the welded pins along the body line
Re: 1970 Challenger RT/SE ???? [Re: gtx6970] #3005389
01/14/22 10:29 PM
01/14/22 10:29 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1970 Barracuda/'cuda are stick on up
1970 Challenger is a combination of holes & pins on the fenders/doors/quarters
Re: 1970 Challenger RT/SE ???? [Re: 6bblgt] #3005432
01/15/22 01:28 AM
01/15/22 01:28 AM
It's a dry heat
It's a dry heat
Well that sucks.
Thanks Dan
Re: 1970 Challenger RT/SE ???? [Re: 6bblgt] #3005439
01/15/22 01:51 AM
01/15/22 01:51 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Quote
Pins were for areas where there was no rear surface readily accessible.
Re: 1970 Challenger RT/SE ???? [Re: PhillyRag] #3005516
01/15/22 12:11 PM
01/15/22 12:11 PM
It's a dry heat
It's a dry heat
So, Im guessing the longitudinal stripe would NOT cover these pins / holes if removed???
Re: 1970 Challenger RT/SE ???? [Re: gtx6970] #3005795
01/16/22 01:13 AM
01/16/22 01:13 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Pins are spot welded, you'll need to grind them off, as well as fill the holes in the door corners, IIRC when I removed them from my Challenger, there's 2 holes on the doors at each end, one hole at the end of the rear qtr, and one hole at the fender in the front jamb area, along with dozens of stinking pins.... chances of the longitudinal stripe covering your pin/hole removal 50/50?, IMHO I think the pins/holes will fall right between the upper void between the upper border stripe and the middle longitudinal I assume your trying to avoid paint work?
Mike
Re: 1970 Challenger RT/SE ???? [Re: DAYCLONA] #3005956
01/16/22 02:35 PM
01/16/22 02:35 PM
It's a dry heat
It's a dry heat
Thanks Mike.
Yes.
Am looking at a car that has the mldgs.
I had a feeling the stripe idea wasn't going to work for my intentions.
