1971 B Body Seat Tracks #3004430
01/12/22 04:15 AM
01/12/22 04:15 AM
Oak Forest, Texas
markshemiworld Offline OP
Oak Forest, Texas
Okay so I have a situation…
I have a 1971 satellite that was cloned into a roadrunner. The former owner switched from a bench seat into buckets from a Cuda (not sure what year). When they switched to the buckets they didn’t install the reinforcements in the floor pans for the bucket seats causing one of the bolts to tear through the floor pan. Also, when I found this I noticed some goofy brackets they had to install on the inside (transmission hump side) of the seat brackets to make them level to the B body floor pan. I’m hoping that somebody here can tell me if there is a good solution to fixing this problem without having to buy new seats? These buckets are in great shape, and I can get the reproduction reinforcement plates (bought from Mancini Racing) welded in place as the factory had designed. Any solutions out there? Or maybe somebody has some 1971 B-Body seat tracks?
Thanks ahead of time!
Re: 1971 B Body Seat Tracks [Re: markshemiworld] #3004432
01/12/22 05:20 AM
01/12/22 05:20 AM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
Well, the front floor pans on ebodies and 71 b bodies is the same. I’ve believe the 71 b body tracks are taller about an inch. You could space them up and be good to go.
Re: 1971 B Body Seat Tracks [Re: fastmark] #3004471
01/12/22 09:56 AM
01/12/22 09:56 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Can you post pics of the tracks?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 1971 B Body Seat Tracks [Re: fastmark] #3004520
01/12/22 12:32 PM
01/12/22 12:32 PM
Oak Forest, Texas
Oak Forest, Texas
I will try and post some pictures here shortly. They appear to be factory E-Body tracks. They have a bent Z shaped bar used as a spacer on the transmission tunnel side track only. In pictures they appear to be at least 2” shorter than factory B body tracks. If I wanted to make a proper spacer how could I do that?
Thanks!
Re: 1971 B Body Seat Tracks [Re: markshemiworld] #3005447
01/15/22 04:34 AM
01/15/22 04:34 AM
Oak Forest, Texas
Oak Forest, Texas
So here are some pictures of the drivers side. Does anybody recognize what tracks these are from? And do you think it would be okay to swap some E body tracks in there after the floor has been welded up with the factory bucket seat plates?
Re: 1971 B Body Seat Tracks [Re: markshemiworld] #3005448
01/15/22 04:45 AM
01/15/22 04:45 AM
Oak Forest, Texas
Oak Forest, Texas
Hopefully the images are going to attach!
Re: 1971 B Body Seat Tracks [Re: markshemiworld] #3005449
01/15/22 04:47 AM
01/15/22 04:47 AM
Oak Forest, Texas
Oak Forest, Texas
Looks like they are uploading properly. Just had to resize them.
E1C8B104-F665-4F8A-8AFB-B9FD37ACCCB8.jpeg81875386-956B-4B42-BFCE-AC475B43C641.jpegEDAF3FDC-0A43-40B0-BBA5-0473CB416AFF.jpeg
Re: 1971 B Body Seat Tracks [Re: markshemiworld] #3005455
01/15/22 07:21 AM
01/15/22 07:21 AM
Abilene, Texas
Abilene, Texas
Those are not 70-74 ebody tracks. I don’t know what they are. May not even be Mopar.
Re: 1971 B Body Seat Tracks [Re: fastmark] #3005560
01/15/22 01:47 PM
01/15/22 01:47 PM
Oak Forest, Texas
Oak Forest, Texas
Well then I take that as good news! Plan is to try some E body tracks later today and if they work reasonably then I’ll have the support plates welded in next week
Re: 1971 B Body Seat Tracks [Re: markshemiworld] #3005844
01/16/22 05:16 AM
01/16/22 05:16 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Look at this ad from FBBO and you'll see how the 71/74 B body tracks are
https://www.forbbodiesonly.com/moparforum/threads/1972-74-b-body-bucket-seats.146736/
Or this from eBay
https://www.ebay.com/itm/303993315918
Inners are incorrectly mounted on the eBay ad thought! Maybe need to be changed between buckets from side to side.
