Fuel Sending Unit #3005222
01/14/22 12:16 PM
01/14/22 12:16 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Need a fuel sending unit for a 1967 Plymouth Belvedere 3/8 line. Which brand have you guys had good luck with? I've found some and they vary a good bit in price, wasn't sure if the cheap ones are any good or not.
Re: Fuel Sending Unit [Re: DusterKid] #3005239
01/14/22 01:00 PM
01/14/22 01:00 PM
moparx Offline
moparx  Offline
i have tried a couple from van's auto and they have worked pretty good.
just install them without the gasket, then manipulate them with a rod of some sort while your buddy watches the dash gauge to confirm the gauge is close to what you raise and lower the float arm to.
my charger has one, and a buddy's dart has one.
as both of these tanks have a side fill neck, it was easy to move the float arm and see what was going on.
make sure you check the retainer ring thickness. if it's thinner than your original, use your original retainer ring.
beer
Re: Fuel Sending Unit [Re: moparx] #3005379
01/14/22 10:02 PM
01/14/22 10:02 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
I have yet to find any that work out of the box in the last 20 years. Beleive me we have replaced a buttload of sending units. I have resorted to using the METER MATCH as it is a lot less labor intensive.
I also want to mention Be very careful manipulating the sending unit with the key on and a tank that has had fuel in it. A neighbor had one blow while doing so. Fortunately he got away with some flash burns but it could have been a lot worse, especially if the tank wasn't mounted in the car. it did appear to have gained several gallons of capacity eek
Re: Fuel Sending Unit [Re: TJP] #3005380
01/14/22 10:06 PM
01/14/22 10:06 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
beer
Damn.
Re: Fuel Sending Unit [Re: bobby66] #3005382
01/14/22 10:10 PM
01/14/22 10:10 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I bought a sending unit from Kramers Auto about 4 years ago and it still reads accurate. He tests them and recalibrates them before shipping them out.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
