Air Cleaner Size #3004666
01/12/22 06:04 PM
01/12/22 06:04 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Looking to add an air cleaner to my car. It's a Duster with a 440. Using a Victor 440 intake with a 1" spacer (adjustable resistor plate to use for index class racing). Car was built almost 30 years ago and has a snorkel style hood scoop. The hood has a decent size hole, but I'm limited to about a 9" diameter and 3 1/2-4" tall air cleaner. Engine is a stock stroke 440 and I shift at 6,000, trap around 63-6400. I don't want to choke the engine down, but worried that a 3-3 1/2" air filter element might be to small with the 9" diameter. How small of an air filter have you guys used on your combos that haven't effected the overall performance?
Re: Air Cleaner Size [Re: DusterKid] #3004674
01/12/22 06:27 PM
01/12/22 06:27 PM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
I'm not as hardcore as some in this particular forum but I know that Car Craft did an article on various sizes and the losses of air filters on a pretty robust engine- it was on a dyno though. Carb inlet size is only so big- it is more about smoothing and directing airflow than filter size- carbs need a flat flange surface leading into the carb itself . For a snorkle style scoop, you may be able to get some additional filter area by going with an oval air cleaner.
I did a quick search and found these two references. May not have been the same article I was thinking of but it is a start. I thought this was interesing:
Car Craft April 2002, Filter Test....Page 72 & 73
1. K&N #E-3403, 7"X3"....49.5 SQ.IN..........520 Horsepower..........0.8Hg vac
2. K&N #E-3770, 14"X6"...230.9 SQ.IN........520 Horsepower..........0.6Hg vac
HOT ROD - JUNE 2002 - "AIR FILTERS SHOOTOUT"
Using 14"x3" filters, each half covered with duct tape before the test began, using only 1/2 the filter area.
1. Advanced Flow Eng. (AFE):.... PN 10-10009..$59.56......... 365.9 HP
2. Holley :............................... PN 220-5.......$39.99.........367.2 HP
3. K&N Engeneering:.................. PN3737.........$69.93.........368.7 HP
4. Purolator;............................ PN A60074.....$5.99...........368.7 HP
5. Rush Performance;................. PN 710048.....$44.30.........368.5 HP
I hope this hels.
Re: Air Cleaner Size [Re: DusterKid] #3004676
01/12/22 06:30 PM
01/12/22 06:30 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Largest that will fit. Radius/velocity stack/drop base contour. Low restriction. I used an unoiled K&N that worked fine. Just trying to keep the big chunks out. Cylinder walls actually looked better after I started to use one.
Re: Air Cleaner Size [Re: CMcAllister] #3004729
01/12/22 08:51 PM
01/12/22 08:51 PM
Keymar, MD
Keymar, MD
My plan was to go with a K&N Racing Filter non oil gray gauze. They make a 5" one that I thought would fit. I ordered a base and did some measuring and it will end up hitting the side of the scoop before the hood shuts (Dang off set engines), They do make a 3" (Part Number 28-4245 ) one that should fit okay. I stumbled across a air filter calculator but wasn't sure how accurate it was.
Basically you take Engine CI x RPM / 25500 (446 x 6500 / 25500 = 113.68)
Air cleaner diameter x 3.14 (9 x 3.14 = 28.26)
Than take 113.68 / 28.26 = 4.02 and that is roughly how tall of an air filter you need for that diameter.
Re: Air Cleaner Size [Re: DusterKid] #3004737
01/12/22 09:23 PM
01/12/22 09:23 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
IIRC k&n had on their website 20sqin's per 100hp.
Re: Air Cleaner Size [Re: DusterKid] #3004738
01/12/22 09:29 PM
01/12/22 09:29 PM
AndyF Offline
AndyF  Offline
See what Wix has in that size. I've gotten rid of all of my K&N filters and moved everything over to Wix racing filters.
Re: Air Cleaner Size [Re: AndyF] #3004762
01/12/22 10:58 PM
01/12/22 10:58 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Yep, me too.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Air Cleaner Size [Re: BloFish] #3004768
01/12/22 11:22 PM
01/12/22 11:22 PM
gregsdart Offline
gregsdart  Offline
I have run a 14x3 WIX race filter with zero loss on a 900 hp motor. If they don't have a filter in your size, it might be possible to cut enough out of a bigger filter to get what you need. Where there is a will, there is a way.
Re: Air Cleaner Size [Re: AndyF] #3004774
01/12/22 11:59 PM
01/12/22 11:59 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
The shop that dynoed my engine builds a lot of roundy round dirt track engines. The owner told me that the Wix Racing filter loses less than HP than any other filter.
Re: Air Cleaner Size [Re: AndyF] #3004827
01/13/22 10:48 AM
01/13/22 10:48 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Been using the Wix racing air filters for years. We also run the KN filter top. Best of 8.51@156MPH with a 4150 carb on Alcohol
Re: Air Cleaner Size [Re: cl440] #3004892
01/13/22 02:01 PM
01/13/22 02:01 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
One of the filter top ones should be more than enough.
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Air Cleaner Size [Re: DusterKid] #3004974
01/13/22 04:41 PM
01/13/22 04:41 PM
I've tested air cleaners, air cleaner bases and K&N filter tops on an engine dyno and at the track, the K&N filter lids on the engine on the dyno lost 3 to 8 HP (CRS exactly: whiney:) At the track with Hemi hood scoop on one of my old race Dusters the car pick up.3 MPH running it versus a raise center chrome or steel lid: confused:
Every car that I have raced (with and without a scoop) without an air cleaner ran slower and less MPH than with the base only on the carbs. and or with a good air cleaner element up scope
I use drop base air cleaners as large as possible to help run as quick and as fast as possible which insures the motor lives longer and doesn't screw up the ring seal due to dirt and debris getting suck into the motor any time it is running work up
Re: Air Cleaner Size [Re: Cab_Burge] #3005243
01/14/22 01:12 PM
01/14/22 01:12 PM
moparx Offline
moparx  Offline
how big of a drop on the base Cab ?
beer
Re: Air Cleaner Size [Re: moparx] #3005459
01/15/22 08:33 AM
01/15/22 08:33 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We've been using these guys for some time. Lots of options.
http://www.r2cperformance.com/clear-oval--air-cleaner-base-and-lid.aspx
Re: Air Cleaner Size [Re: moparx] #3005612
01/15/22 03:31 PM
01/15/22 03:31 PM
One inch to three inch on the Dominator drop bases, maybe similar on the 4150 bases shruggy
They vary, use the one that works for you scope up
