Aftermarket Chrome -removing #3004655
01/12/22 05:31 PM
01/12/22 05:31 PM
Massachusetts
Faust Offline OP
Faust  Offline OP
Massachusetts
I am looking at a car (which shall remain nameless) that has had aftermarket chrome added to the pillars and rocker panel area. I'd like to remove it; I'm thinking heat gun. Any better ideas?
Re: Aftermarket Chrome -removing [Re: Faust] #3004663
01/12/22 05:45 PM
01/12/22 05:45 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Those are held in place by double sticky tape so you should be able to do it with a heat gun. The gun will warm the metal trim (stainless most likely) so you may need gloves.
Also you can saw those loose with fishing line. Some how-to videos on YouTube....
Re: Aftermarket Chrome -removing [Re: Neil] #3004664
01/12/22 05:50 PM
01/12/22 05:50 PM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
I've used heat from a hair dryer at the same time I sawed the adhesive with a piece of dental floss. It worked great.
Re: Aftermarket Chrome -removing [Re: Faust] #3004759
01/12/22 10:30 PM
01/12/22 10:30 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
The rocker panel trim may be hiding other issues, whistling
Also don't get too much heat going or it could damage the paint beer
Re: Aftermarket Chrome -removing [Re: TJP] #3004792
01/13/22 01:49 AM
01/13/22 01:49 AM
Massachusetts
Faust Offline OP
Faust  Offline OP
Massachusetts
That had me worried and is why I'm looking for suggestions.
