fuel system - return line #3002861
01/07/22 01:03 PM
01/07/22 01:03 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
For those of you that run a return line fuel system with a fuel cell. Where do does the return line enter the tank compared to the supply line? If your is on the top of the fuel cell do you have a hose/line so the return is submerged?
Re: fuel system - return line [Re: DusterKid] #3002866
01/07/22 01:13 PM
01/07/22 01:13 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Mine is on top, but not submerge twocents
Re: fuel system - return line [Re: DusterKid] #3002878
01/07/22 02:11 PM
01/07/22 02:11 PM
N
NITROUSN Offline
NITROUSN  Offline
N
On my cars I always get it as far away from the supply port as possible. I also extend it down into the fuel about 3 or 4 inches from the bottom of the tank.
Re: fuel system - return line [Re: NITROUSN] #3002883
01/07/22 02:34 PM
01/07/22 02:34 PM
Keymar, MD
Keymar, MD
What do you use to extend the line? Alum fuel line?
Re: fuel system - return line [Re: DusterKid] #3002895
01/07/22 03:23 PM
01/07/22 03:23 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Most of the time just a bulkhead fitting and a short most likely 8an hose in the tank.
Re: fuel system - return line [Re: DusterKid] #3002924
01/07/22 04:38 PM
01/07/22 04:38 PM
It is your choice, soft aluminum tubing flared to AN 37 degree flare with a AN female fitting or AN hose with a female fitting on it work up scope
I haven't ran the return line on my new car yet but I'm thinking a aluminum line ending up about two inches from the bottom wrench
Re: fuel system - return line [Re: Cab_Burge] #3003197
01/08/22 03:18 PM
01/08/22 03:18 PM
moparx Offline
moparx  Offline
and now for the old guy DUM question of the day..........
i have read, and been told many times by many different people, the return line should be LARGER, SAME SIZE, and SMALLER in diameter.
these have been on successful installations, so if it is successful and works, it must be ok.
i like the idea of larger, or possibly the same size. less likely to cause residual heat buildup in the fuel system.
it is also quite possible a smaller line would work if there were not much fuel being returned to the tank.
so, any return line is better than nothing, depending of course, the system design itself ? shruggy
beer
Re: fuel system - return line [Re: moparx] #3003222
01/08/22 05:07 PM
01/08/22 05:07 PM
It may need to be determine by the fuel pump makers, call them to make sure scope
Re: fuel system - return line [Re: Cab_Burge] #3003231
01/08/22 05:49 PM
01/08/22 05:49 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
I would use the same size line so it is not an unintended restriction.
Return to the tank below the fuel level prevents aeration.
Re: fuel system - return line [Re: Cab_Burge] #3003302
01/08/22 10:29 PM
01/08/22 10:29 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
iagree
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: fuel system - return line [Re: BloFish] #3003484
01/09/22 03:17 PM
01/09/22 03:17 PM
moparx Offline
moparx  Offline
iagree
unfortunately, i have been told conflicting sizes by both the manufacturers and the dealers, depending on what day i called ! runaway
just for curiosity's sake, i crawled under my bus to see what kind of setup it had, and it's return line was smaller than the feed. [they are both plastic lines-99 model year] i realize this is just a 3.3 six cylinder, and it's factory designed for that, but that confuses me even more. [if that is even possible ! laugh2]
beer
Re: fuel system - return line [Re: moparx] #3003495
01/09/22 04:23 PM
01/09/22 04:23 PM
ohio
dragon Offline
dragon  Offline
ohio
Just thinking wouldn't a bigger return line be better because it would reduce pressure going back to the tank reduce stiring up thing in the tank a smaller line would more presure comeing out to keep up with the return flow ???
Re: fuel system - return line [Re: dragon] #3003543
01/09/22 07:01 PM
01/09/22 07:01 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
The pressure in the return line is already lower than the feed side. I would think larger to be unnecessary, but personally I wouldn't go smaller than the feed.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: fuel system - return line [Re: A39Coronet] #3004012
01/11/22 02:08 AM
01/11/22 02:08 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Aeromotive directed me to make the return line the same size as the supply. I’m at -8 on both, with -6 from the regulator to the carb. Return is routed to the top front of the cell, but not extended. May be a good idea as it could cut down on aeration.
Re: fuel system - return line [Re: StealthWedge67] #3004443
01/12/22 07:53 AM
01/12/22 07:53 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I wouldn't think fuel would hold the aeration in a moderately sized tank. It's already in there sloshing around.
Re: fuel system - return line [Re: A39Coronet] #3006464
01/18/22 11:33 AM
01/18/22 11:33 AM
an8sec70cuda Offline
I have a stock tank w/ a sump for the pickup. I use the stock 3/8" pickup tube as my return, so it's submerged.
I use a -10 feed and a -8 return...as directed by Aeromotive back in 2011 when I installed this system. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
Re: fuel system - return line [Re: an8sec70cuda] #3006658
01/19/22 01:12 AM
01/19/22 01:12 AM
wine country
8
8urvette Offline
8urvette  Offline
wine country
Holley told me -10 feed then use -6 return. The fpr is setup that way too.
This is a MPFI fuel injection setup. However I have a -8 in place for the return. So yes there is a bottle neck from regulator, but I already had -8 installed from the last setup.
Re: fuel system - return line [Re: moparx] #3006696
01/19/22 05:48 AM
01/19/22 05:48 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
beer
Found out it depends on the regulated pressure and pump volume.
Have a setup with the older Mallory 250 GPH pump and by-pass regulator, both -8 AN supply and return.
At idle, the fuel pressure would creep up one or two PSI, go from 7 to 8 or 9 psi.
The pump also has a by-pass, so I set the pumps by-pass to just dump a small amount of fuel back into the fuel cell.
Anyhow, I think High Volume pump and low regulated pressure like 6-7 psi, the return needs to be same size or larger than supply line.
Also, non-boosted carb, the fuel pressure is normally just referenced (or regulated) to atmosphere, so fuel line pressure to vented bowl should stay the same under different loads.
Anyhow, the pressure in the return line has to be lower than the regulated pressure, and pressure is a function on fuel volume, line diameter, and line length. Because the regulated pressure is only a few psi, the return line can't have much pressure in it, or pressure will start to increase.
On my EFI stuff, it is different. The normal 225 lph pump is only about 60 GPH, and "regulated" pressure is 3 or 4 bar = 43.5 psi or 58 psi. By "regulated", that is usually referenced to manifold pressure, so the regulated pressure stays the same across the fuel injector (on return type EFI), but if you have a pressure gauge in the line it only shows the 3 or 4 bar pressure when the engine is not running. Under vacuum the gauge pressure will look lower because the gauge is referenced to atmosphere not manifold pressure.
Anyhow, the largest EFI pump I tested on my car was the Walbro 450 lph (about 119 GPH) at 4 bar with 3/8" supply and 5/16" return and the smaller return line was not a problem.
Because the regulated pressure is way higher, a small amount of pressure in the return line is not an issue.
Re: fuel system - return line [Re: 451Mopar] #3006759
01/19/22 12:20 PM
01/19/22 12:20 PM
NC
440Jim Offline
440Jim  Offline
NC
The return regulator (carb) I have says to check the return line size by running all fuel bypassed (unscrewed 4 turns) with carb lines plugged (no flow on needle/seat).
The pressure at the regulator port should be less than 3 psi. Mine was 1.8 psi
Thinking about it. If the pressure is too high, it will push open the needle and seat at idle. And the regulator needs some margin to avoid fluctuation.
