Re: 68 Dart GT convertible
[Re: DynoDave]
#3004065
01/11/22 10:23 AM
01/11/22 10:23 AM
Posts: 7,368 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
[Re: JDMopar]
#3005986
01/16/22 04:41 PM
01/16/22 04:41 PM
Posts: 7,368 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
[Re: JDMopar]
#3006144
01/17/22 10:11 AM
01/17/22 10:11 AM
Posts: 7,368 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
Wow.....looks awesome! Did they say what brand of paint it was? Sorry, I posted the info in my QQ1 thread in the Restoration section. I forgot to post them here.
[Re: burdar]
#3006146
01/17/22 10:16 AM
01/17/22 10:16 AM
Posts: 7,368 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
[Re: burdar]
#3006350
01/17/22 11:13 PM
01/17/22 11:13 PM
Posts: 8,489 Candler,NC / Myrtle Beach, SC
JDMopar
Wow.....looks awesome! Did they say what brand of paint it was? Sorry, I posted the info in my QQ1 thread in the Restoration section. I forgot to post them here. Thanks Darren. That will help a bunch when it's time to do my Roadrunner. Looks like it won't be long until you'll be in the "Bolt it together and don't skin it!" phase.
[Re: UCUDANT]
#3016246
02/17/22 10:54 AM
02/17/22 10:54 AM
Posts: 7,368 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
[Re: burdar]
#3016605
02/18/22 05:48 PM
02/18/22 05:48 PM
Posts: 7,368 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
[Re: crowbait]
#3021947
03/08/22 03:07 PM
03/08/22 03:07 PM
Posts: 7,368 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
The car is back home. I need to let the paint sit for about 120 days before I can wax it. I'll probably wait that long before I start bolting on parts to the exterior. Until then I'll keep busy by installing things under the car and getting the glass into the doors and 1/4s. Once the glass is in and I make sure the doors don't need to be readjusted, the inner fender splash shields will be installed and undercoating will be sprayed in the wheel wells. Once the outside temps are a little warmer, I'll start installing the butyl sound deadener to the interior floor and inside the doors. Late last week I installed the body plugs and set the tail light wiring in place.(man these A-bodies have a lot of body plugs...way more then my Challengers has) Saturday we had warmer temps so I decided to get the rad support blackout done. I set the old grill and headlight bezels in place so I could see which areas were visible through the grill. I didn't like how the factory blackout went all the way up to the top of the latch support so I decided to leave that area body color. The bottom of the latch support can be seen through the grill so the bottom was sprayed but not the top. That was all the time I had to work on the car on Saturday. That afternoon I went to Disney on Ice with my wife and daughter. Then we rushed home at night to beat the severe thunderstorms and tornados passing through the area. On Sunday I realized that the body shop had filled in the washer bottle mounting holes. I had them fill some extra holes on the inner fender but for some reason they filled all of them. After re-drilling those holes, I mounted the headlight relays to the battery tray and install that. Then I started running the new headlight wiring. The wiring was a little more difficult then I had expected though. I must not have tried fishing the plugs through the headlight bucket support during the test fitment stage. The aftermarket plugs are too thick to pass through the limited space available. I had to get out the cutoff wheel and cut a notch in the bucket support. About 1/4" more room was needed. Now the plugs will easily pass into the back of the headlight area. Once that was done, mounting the buckets and all the adjuster hardware went pretty quick. Later on Sunday I installed the brake/fuel lines and rear axle bumpers. Next thing to work on is cleaning up the gas tank and getting that installed.
[Re: burdar]
#3023515
03/13/22 10:37 AM
03/13/22 10:37 AM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
(man these A-bodies have a lot of body plugs...way more then my Challengers has) Why do you think A-bodies are so light? After re-drilling those holes, I mounted the headlight relays to the battery tray and install that. I had to get out the cutoff wheel and cut a notch in the bucket support. About 1/4" more room was needed. I would have agonized over doing this to a beautiful, newly painted car.
[Re: DynoDave]
#3031571
04/07/22 01:03 PM
04/07/22 01:03 PM
Posts: 7,368 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
Still waiting until the 120 day mark so I can wax the engine compartment and start assembling things in there. For now I've been working on applying the sound deadener to the floor. I was concerned about the garage temps being in the 30s/40s but it installed easily. I was planning on using Kilmat but ordered some stuff called Siless by accident. It's 80 mil, made from butyl and came in the same quantity as Kilmat so I used it. I covered the entire floor pan and up the firewall to where the factory insulation starts. I installed some under the rear seat but just in the middle. That's where the resonance was. The area above the frame rails were solid so I didn't think I needed anything there. The section of the floor pan where the convertible top will sit sounded really hollow so I installed some there as well. I put a couple strips of sound deadener on the seat back brace that spans between the wheel wells. It sounded really hollow too. The metal wire covers along the rocker area were really beat up and rusted through in a few places. Replacements seemed really expensive for what they are so I made my own. I just bought the thinnest sheet metal the metal company carried(20 gauge) and drilled some holes along the length. Then I dimple died it for strength. I thought about different ways to attach it but ended up just using the sound deadener itself to hold the pieces in place. Finally, I put some aluminum tape on all the seams. The edges of the sound deadener are exposed and sticky. I put the tape on it so the carpet doesn't stick to the floor when the temp warms up. I also got the 1/4 windows installed. What a PITA. I downloaded the 67 and 69 service manuals(the 68 manual isn't online) and read how they are supposed to be installed. The instructions left a lot to be desired. I ended up having to completely remove the rear stabilizer and unbolt the front track in order to move the glass forward inside the 1/4 so I could get the rollers attached. Before I could do any of that though, I had to sand/polish the stainless weather stripping channel at the leading edge of the glass. On my Challenger, the stainless was still attached to the glass so I carefully polished it as an assembly. On the Dart though, the glass setting tape had lost its hold and the stainless was loose. The convertible uses rivets to hold the stainless to the lift bracket at the bottom. Once I drilled off the rivet head I was able to tap them out and remove the stainless piece. Here are the rivets holding the stainless to the lift bracket. I discovered that I could drill and tap the lift bracket holes for some 8-32 button head screws. This made reattaching it at the base easy. There was still the issue with the glass setting tape though. A few well respected people on this site said they never really had much luck using that stuff so I was a little nervous. While looking up weatherstrip adhesive online I stumbled on a product called "windshield and glass sealant". Its designed to fix leaks between glass and rubber gaskets. The tube was only $6 so I thought I'd give it a try. The glass setting tape was still well attached to the stainless...it had just come loose from the glass. So, after cleaning the old tape and the glass, I ran a bead of the sealant on the leading edge of the glass. Then I pushed the stainless in place. After attaching the bottom with the allen head screws, I wrapped tape around the glass to hold everything stationary while the sealant dried. So far it seems to be working great. If it fails, I'll just have to install new glass setting tape. The windshield sealant is basically thin, flowable silicone. It's quite a bit thinner then regular clear silicone you find in a big tube. Here are the button head screws used to attach the stainless to the lift bracket.
